chloemon
Connection to server impossible
I'm as guest on a corporate network whose characteristics I don't know.
I have access to internet via usual http ports (80, 8080, 443) but most ports are blocked.
I subscribed to AirVPN with the intention to "recover" full access to the internet.
I'm under Windows 7, using the AirVPN windows application.
It cannot connect to a server.
Please find below my logs. It may help you help me.
Thanks for any tips !
! 2015.09.08 13:53:26 - Activation of Network Lock - Windows Firewall
I 2015.09.08 13:53:48 - Session starting.
I 2015.09.08 13:53:49 - IPv6 disabled.
I 2015.09.08 13:53:49 - Checking authorization ...
! 2015.09.08 13:53:49 - Connecting to Becrux (Czech Republic, Zlin)
. 2015.09.08 13:53:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.08 13:53:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.08 13:53:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.08 13:53:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.08 13:53:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:53:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:53:50 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.08 13:53:50 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.08 13:53:50 - OpenVPN > UDPv4 link remote: [AF_INET]50.7.211.250:443
. 2015.09.08 13:54:22 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.09.08 13:54:22 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.09.08 13:54:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.09.08 13:54:27 - Disconnecting
. 2015.09.08 13:54:27 - Connection terminated.
I 2015.09.08 13:54:30 - Checking authorization ...
! 2015.09.08 13:54:31 - Connecting to Becrux (Czech Republic, Zlin)
. 2015.09.08 13:54:31 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.08 13:54:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.08 13:54:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.08 13:54:31 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.08 13:54:31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:54:31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:54:31 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.08 13:54:31 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.08 13:54:31 - OpenVPN > UDPv4 link remote: [AF_INET]50.7.211.250:443
. 2015.09.08 13:55:03 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.09.08 13:55:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.09.08 13:55:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.09.08 13:55:08 - Disconnecting
. 2015.09.08 13:55:08 - Connection terminated.
I 2015.09.08 13:55:11 - Checking authorization ...
! 2015.09.08 13:55:12 - Connecting to Becrux (Czech Republic, Zlin)
. 2015.09.08 13:55:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.08 13:55:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.08 13:55:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.08 13:55:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.08 13:55:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:55:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:55:12 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.08 13:55:12 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.08 13:55:12 - OpenVPN > UDPv4 link remote: [AF_INET]50.7.211.250:443
. 2015.09.08 13:55:44 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.09.08 13:55:44 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.09.08 13:55:50 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.09.08 13:55:50 - Disconnecting
. 2015.09.08 13:55:50 - Connection terminated.
I 2015.09.08 13:55:53 - Checking authorization ...
! 2015.09.08 13:55:53 - Connecting to Becrux (Czech Republic, Zlin)
. 2015.09.08 13:55:53 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.09.08 13:55:53 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.09.08 13:55:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.09.08 13:55:53 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.09.08 13:55:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:55:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.09.08 13:55:53 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2015.09.08 13:55:53 - OpenVPN > UDPv4 link local: [undef]
. 2015.09.08 13:55:53 - OpenVPN > UDPv4 link remote: [AF_INET]50.7.211.250:443
