urbanconcrete
OpenWRT - Need help...
While i'm not at home i would like to use a Nexx WT3020H running "Chaos Calmer r46780".
I got the VPN Connection  up and running. I don't pull any route...Now i'm stuck.
I'f got the following interfaces:
internet=eth0.2 -> the connection to the isp router
openvpn=tun0 -> the vpn client
br-lan= which i want to keep as a backup to connect to the box (if possible)
wlan0=now used to configure the box
I want to set up a wireless network, all traffic going via tun0.
I have some kind of idea, but if someone with openwrt knowledgewould review it, it would be nice
Maybe i have a starting point. A git repository of another vpn service, for the Nexx WT3020H.
But even if i use the following config, i does not work...
The dev tun0 is up and running. I cant connect to the wireless network...even it shows up...
/etc/config/firewall
config defaults
    option syn_flood '1'
    option input 'ACCEPT'
    option output 'ACCEPT'
    option forward 'REJECT'
config zone
    option name 'lan'
    option forward 'ACCEPT'
    option network 'lan'
config zone
    option name 'wan'
    option input 'REJECT'
    option masq '1'
    option mtu_fix '1'
    option network 'wan wan6 vpn'
config forwarding
    option src 'lan'
    option dest 'wan'
config rule
    option name 'Allow-DHCP-Renew'
    option src 'wan'
    option proto 'udp'
    option dest_port '68'
    option target 'ACCEPT'
    option family 'ipv4'
config rule
    option name 'Allow-Ping'
    option src 'wan'
    option proto 'icmp'
    option icmp_type 'echo-request'
config rule
    option name 'Allow-IGMP'
    option src 'wan'
    option proto 'igmp'
config rule
    option name 'Allow-DHCPv6'
    option src 'wan'
    option proto 'udp'
    option src_ip 'fe80::/10'
    option src_port '547'
    option dest_ip 'fe80::/10'
    option dest_port '546'
    option family 'ipv6'
config rule
    option name 'Allow-MLD'
    option src 'wan'
    option proto 'icmp'
    list icmp_type '130/0'
    list icmp_type '131/0'
    list icmp_type '132/0'
    list icmp_type '143/0'
config rule
    option name 'Allow-ICMPv6-Input'
    option src 'wan'
    option proto 'icmp'
    list icmp_type 'echo-request'
    list icmp_type 'echo-reply'
    list icmp_type 'destination-unreachable'
    list icmp_type 'packet-too-big'
    list icmp_type 'time-exceeded'
    list icmp_type 'bad-header'
    list icmp_type 'unknown-header-type'
    list icmp_type 'router-solicitation'
    list icmp_type 'neighbour-solicitation'
    list icmp_type 'router-advertisement'
    list icmp_type 'neighbour-advertisement'
    option limit '1000/sec'
config rule
    option name 'Allow-ICMPv6-Forward'
    option src 'wan'
    option dest '*'
    option proto 'icmp'
config include
    option path '/etc/firewall.user'
/etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fde2:ff53:2024::/48'
config interface 'lan'
        option ifname 'eth0.1'
        option force_link '1'
        option type 'bridge'
        option ipaddr '10.30.20.1'
        option netmask '255.255.255.0'
        option ip6assign '60'
config interface 'wan'
        option ifname 'eth0.2'
        option proto 'dhcp'
config interface 'wan6'
        option proto 'dhcpv6'
config switch
        option name 'switch0'
        option reset '1'
        option enable_vlan '1'
config switch_vlan
        option device 'switch0'
        option vlan '1'
        option ports '1 2 3 4 6t'
config switch_vlan
        option vlan '2'
        option ports '0 6t'
config interface 'vpn'
        option proto 'none'
        option ifname 'tun0'
	option auto '1'
etc/config/wireless
config wifi-device 'radio0'
        option type 'mac80211'
        option channel '11'
        option hwmode '11g'
        option path '10180000.wmac'
        option htmode 'HT20'
        option txpower '20'
        option country '00'
config wifi-iface
        option device 'radio0'
        option mode 'ap'
        option ssid 'THE_SSID'
        option encryption 'psk2'
        option key 'THE_WPA_KEY'
