console.online.net
403 Forbidden
From the USA-servers I tried
Use the routing tool.
https://airvpn.org/routes/?q=https%3A%2F%2Fconsole.online.net%2Fen%2Flogin
All the ones that are 302 (redirect) are not blocked. All the ones that are 403 are blocked. Simply use a server that is not blocked, seems that the majority work fine in many locations.
When you click the link, you will need to wait about 20-30 seconds then refresh in order to get the results.
