irishtechnomonster
ANSWERED Eddie 2.10.3 UI Won't Load on Raspbian
Ok so the problem was with the version of mono-runtime (3.2.8) installed by default. To fix the problem, I removed airvpn and mono and started from scratch. First I added the repository for version 3.12.1 of mono (Note: >v3.12.1 will not work), and then I reinstalled... Hope this helps someone!
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
sudo echo "deb http://download.mono-project.com/repo/debian wheezy/snapshots/3.12.0 main" | sudo tee /etc/apt/sources.list.d/mono-xamarin.list
sudo apt-get update
sudo apt-get install mono-runtime mono-utils libmono-system-runtime2.0-cil libmono-winforms2.0-cil libmono-corlib2.0-cil
sudo dpkg -i /path/to/airvpn_linux_x64_debian.deb
