Kemokono
Autherization fail after activating Net. lock over Tor
Hi.
I have small problem, I want to run airvpn over Tor, without network lock everything work fine and the connection is established.
After Disconnecting and activating network lock and then Reconnect again --> checking autherization Fail
I have tried several times, I'm using Tor 0.2.6.10 , Portable Eddie for debian.
the following are some logs collected from Tor, eddie and iptables
Eddie log
! 2015.08.29 20:57:44 - Activation of Network Lock - Linux IPTables
I 2015.08.29 20:58:12 - Session starting.
W 2015.08.29 20:58:12 - Unable to understand if IPV6 is active.
I 2015.08.29 20:58:12 - Checking authorization ...
. 2015.08.29 21:00:12 - Checking authorization ..., 1° try failed (curl: (7) Can't complete SOCKS4 connection to 0.0.0.0:53. (91), request rejected or failed.)
. 2015.08.29 21:02:12 - Checking authorization ..., 2° try failed (curl: (7) Can't complete SOCKS4 connection to 0.0.0.0:53. (91), request rejected or failed.)
. 2015.08.29 21:04:12 - Checking authorization ..., 3° try failed (curl: (7) Can't complete SOCKS4 connection to 0.0.0.0:53. (91), request rejected or failed.)
. 2015.08.29 21:06:12 - Checking authorization ..., 4° try failed (curl: (7) Can't complete SOCKS4 connection to 0.0.0.0:57. (91), request rejected or failed.)
W 2015.08.29 21:06:12 - Authorization check failed, continue anyway ({1])
I 2015.08.29 21:06:12 - Cancel requested.
! 2015.08.29 21:06:12 - Session terminated.
. 2015.08.29 21:06:13 - Deactivation of Network Lock
Tor Log "note the time"
Aug 29 20:58:47.000 [notice] We tried for 15 seconds to connect to '[scrubbed]' using exit $413CC12C263CDC7AB~Bak04 at 69.66.199.116. Retrying on a new circuit.
Aug 29 21:00:12.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:80. Giving up. (waiting for circuit)
Aug 29 21:02:12.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:80. Giving up. (waiting for circuit)
Aug 29 21:04:12.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:80. Giving up. (waiting for circuit)
Aug 29 21:06:12.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:80. Giving up. (waiting for circuit)
Iptables -L output
# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere
ACCEPT     all  --  255.255.255.255      anywhere
ACCEPT     all  --  192.168.0.0/16       192.168.0.0/16
ACCEPT     all  --  10.0.0.0/8           10.0.0.0/8
ACCEPT     all  --  172.16.0.0/12        172.16.0.0/12
ACCEPT     icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
DROP       all  --  anywhere             anywhere
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
ACCEPT     all  --  anywhere             server85.web-hosting.com
ACCEPT     all  --  anywhere             server78.web-hosting.com
ACCEPT     all  --  anywhere             104.243.24.237
ACCEPT     all  --  anywhere             104.243.24.235
ACCEPT     all  --  anywhere             173.44.55.180.static.quadranet.com
ACCEPT     all  --  anywhere             173.44.55.178.static.quadranet.com
ACCEPT     all  --  anywhere             96.47.229.60.static.quadranet.com
ACCEPT     all  --  anywhere             96.47.229.58.static.quadranet.com
ACCEPT     all  --  anywhere             173.44.55.156.static.quadranet.com
ACCEPT     all  --  anywhere             173.44.55.154.static.quadranet.com
ACCEPT     all  --  anywhere             199.241.147.36
ACCEPT     all  --  anywhere             199.241.147.34
ACCEPT     all  --  anywhere             unknown-client.static.huge-dns.com
ACCEPT     all  --  anywhere             164.23.100.94.static.swiftway.net
ACCEPT     all  --  anywhere             162.23.100.94.static.swiftway.net
ACCEPT     all  --  anywhere             www.yundc.com
ACCEPT     all  --  anywhere             156.33.255.149.static.swiftway.net
ACCEPT     all  --  anywhere             154.33.255.149.static.swiftway.net
ACCEPT     all  --  anywhere             84.154.21.46.in-addr.arpa
ACCEPT     all  --  anywhere             82.154.21.46.in-addr.arpa
ACCEPT     all  --  anywhere             46-163-220-91.urdn.com.ua
ACCEPT     all  --  anywhere             44-163-220-91.urdn.com.ua
ACCEPT     all  --  anywhere             103.254.153.100
ACCEPT     all  --  anywhere             103.254.153.68
ACCEPT     all  --  anywhere             62.102.148.176
ACCEPT     all  --  anywhere             62.102.148.136
ACCEPT     all  --  anywhere             62.102.148.170
ACCEPT     all  --  anywhere             62.102.148.139
ACCEPT     all  --  anywhere             62.102.148.178
ACCEPT     all  --  anywhere             62.102.148.135
ACCEPT     all  --  anywhere             62.102.148.180
ACCEPT     all  --  anywhere             62.102.148.134
ACCEPT     all  --  anywhere             62.102.148.182
ACCEPT     all  --  anywhere             62.102.148.133
ACCEPT     all  --  anywhere             62.102.148.184
ACCEPT     all  --  anywhere             62.102.148.132
ACCEPT     all  --  anywhere             62.102.148.174
ACCEPT     all  --  anywhere             62.102.148.137
ACCEPT     all  --  anywhere             62.102.148.188
ACCEPT     all  --  anywhere             62.102.148.130
ACCEPT     all  --  anywhere             62.102.148.186
ACCEPT     all  --  anywhere             62.102.148.131
ACCEPT     all  --  anywhere             94.185.85.172
ACCEPT     all  --  anywhere             94.185.85.170
ACCEPT     all  --  anywhere             185.57.80.148
ACCEPT     all  --  anywhere             185.57.80.146
ACCEPT     all  --  anywhere             lh20638.voxility.net
ACCEPT     all  --  anywhere             91.109.116.66
ACCEPT     all  --  anywhere             91.109.114.3
ACCEPT     all  --  anywhere             hosted-by-i3d.net
ACCEPT     all  --  anywhere             .
ACCEPT     all  --  anywhere             217.195.49.119
ACCEPT     all  --  anywhere             217.195.49.100
ACCEPT     all  --  anywhere             217.195.49.104
ACCEPT     all  --  anywhere             217.195.49.107
ACCEPT     all  --  anywhere             217.195.49.113
ACCEPT     all  --  anywhere             217.195.49.101
ACCEPT     all  --  anywhere             217.195.49.147
ACCEPT     all  --  anywhere             217.195.49.102
ACCEPT     all  --  anywhere             hst-46-166-165-240.balticservers.eu
ACCEPT     all  --  anywhere             hst-46-166-165-124.balticservers.eu
ACCEPT     all  --  anywhere             103-10-197-188.pacswitch.com
ACCEPT     all  --  anywhere             103-10-197-186.pacswitch.com
ACCEPT     all  --  anywhere             78.129.153.59
ACCEPT     all  --  anywhere             78.129.153.40
ACCEPT     all  --  anywhere             84.39.116.181
ACCEPT     all  --  anywhere             84.39.116.179
ACCEPT     all  --  anywhere             84.39.117.58
ACCEPT     all  --  anywhere             84.39.117.56
ACCEPT     all  --  anywhere             82.145.37.204
ACCEPT     all  --  anywhere             82.145.37.202
ACCEPT     all  --  anywhere             no-rdns-yet.ukservers.com
ACCEPT     all  --  anywhere             incanet01-03.dedie.ate.info
ACCEPT     all  --  anywhere             incanet01-01.dedie.ate.info
ACCEPT     all  --  anywhere             95.215.62.93
ACCEPT     all  --  anywhere             95.215.62.91
ACCEPT     all  --  anywhere             46.182.35.49
ACCEPT     all  --  anywhere             46.182.35.14
ACCEPT     all  --  anywhere             hosted-by.leaseweb.com
ACCEPT     all  --  anywhere             46.165.208.69
ACCEPT     all  --  anywhere             46.165.208.65
ACCEPT     all  --  anywhere             46.165.208.70
ACCEPT     all  --  anywhere             50.7.211.252
ACCEPT     all  --  anywhere             50.7.211.250
ACCEPT     all  --  anywhere             91.214.169.70
ACCEPT     all  --  anywhere             airvpn.dserver.softronics.ch
ACCEPT     all  --  anywhere             s02-zh-ch.regika.com
ACCEPT     all  --  anywhere             198.144.158.15
ACCEPT     all  --  anywhere             198.144.158.11
ACCEPT     all  --  anywhere             137.63.71.52
ACCEPT     all  --  anywhere             137.63.71.50
ACCEPT     all  --  anywhere             199.19.94.195
ACCEPT     all  --  anywhere             104.254.90.196
ACCEPT     all  --  anywhere             104.254.90.194
ACCEPT     all  --  anywhere             104.254.90.188
ACCEPT     all  --  anywhere             104.254.90.186
ACCEPT     all  --  anywhere             test.economyydigital.com
ACCEPT     all  --  anywhere             199.19.94.132
ACCEPT     all  --  anywhere             184-75-221-4.amanah.com
ACCEPT     all  --  anywhere             184-75-221-2.amanah.com
ACCEPT     all  --  anywhere             199.19.94.65
ACCEPT     all  --  anywhere             sifu3.bependias.info
ACCEPT     all  --  anywhere             199.19.95.189
ACCEPT     all  --  anywhere             hosted-by.irandatahost.net
ACCEPT     all  --  anywhere             104.254.90.252
ACCEPT     all  --  anywhere             104.254.90.250
ACCEPT     all  --  anywhere             104.254.90.244
ACCEPT     all  --  anywhere             104.254.90.242
ACCEPT     all  --  anywhere             199.21.149.70
ACCEPT     all  --  anywhere             199.21.149.44
ACCEPT     all  --  anywhere             104.254.90.236
ACCEPT     all  --  anywhere             104.254.90.234
ACCEPT     all  --  anywhere             184.75.214.164
ACCEPT     all  --  anywhere             184.75.214.162
ACCEPT     all  --  anywhere             104.254.90.204
ACCEPT     all  --  anywhere             104.254.90.202
ACCEPT     all  --  anywhere             199.19.94.18
ACCEPT     all  --  anywhere             199.19.94.12
ACCEPT     all  --  anywhere             162.219.176.4
ACCEPT     all  --  anywhere             162.219.176.2
ACCEPT     all  --  anywhere             airvpn.org
ACCEPT     all  --  anywhere             ec2-54-225-156-17.compute-1.amazonaws.com
ACCEPT     all  --  anywhere             ec2-54-246-124-152.eu-west-1.compute.amazonaws.com
ACCEPT     all  --  anywhere             ec2-54-93-175-114.eu-central-1.compute.amazonaws.com
ACCEPT     all  --  anywhere             255.255.255.255
Any Ideas ?
Is there anyway to activate network lock after connection get established ?
Thanks,
