syris
Need Help Forwarding Ports Through PfSense AirVPN Client
I've managed to set up an OpenVPN connection between my home pfsense router and AirVPN and have set it up so that part of the network (vLAN 10) only uses the VPN for gateway. However I am unable to correctly forward ports. I first configured the port on airvpn. Then in PfSense used NAT to forward same port to the relevant servers private IP. However ports are sill showing closed.
