Tucco196
Problems to connect
Hi, I just started using AirVPN a couple days ago, and I have had some difficulties to connect to any server, the client keeps trying and trying, sometimes never connects, sometimes it does, when it does it works great, no dissconects or anything, but if i turn it off it's another hour trying to connect.
This is the log, hope u can help
I 2015.08.26 02:30:11 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2015.08.26 02:30:11 - Reading options from C:\Users\Carlos\AppData\Local\AirVPN\AirVPN.xml
. 2015.08.26 02:30:12 - Data Path: C:\Users\Carlos\AppData\Local\AirVPN
. 2015.08.26 02:30:12 - App Path: C:\Program Files\AirVPN
. 2015.08.26 02:30:12 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.08.26 02:30:12 - Command line arguments (1): path="home"
. 2015.08.26 02:30:12 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2015.08.26 02:30:12 - Updating systems & servers data ...
I 2015.08.26 02:30:12 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.08.26 02:30:12 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.08.26 02:30:12 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.08.26 02:30:12 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.08.26 02:30:12 - Ready
. 2015.08.26 02:30:12 - Systems & servers data update completed
I 2015.08.26 02:30:42 - Session starting.
I 2015.08.26 02:30:42 - IPv6 disabled.
I 2015.08.26 02:30:42 - Checking authorization ...
! 2015.08.26 02:30:43 - Connecting to Yildun (United States, Miami)
. 2015.08.26 02:30:43 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.08.26 02:30:43 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.08.26 02:30:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.26 02:30:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.26 02:30:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.26 02:30:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.26 02:30:43 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.08.26 02:30:43 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.26 02:30:43 - OpenVPN > UDPv4 link remote: [AF_INET]173.44.55.178:443
. 2015.08.26 02:30:43 - OpenVPN > TLS: Initial packet from [AF_INET]173.44.55.178:443, sid=a3f33716 a3379bec
. 2015.08.26 02:30:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.26 02:30:43 - OpenVPN > Validating certificate key usage
. 2015.08.26 02:30:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.26 02:30:43 - OpenVPN > VERIFY KU OK
. 2015.08.26 02:30:43 - OpenVPN > Validating certificate extended key usage
. 2015.08.26 02:30:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.26 02:30:43 - OpenVPN > VERIFY EKU OK
. 2015.08.26 02:30:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.26 02:30:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.26 02:30:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.26 02:30:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.26 02:30:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.26 02:30:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.08.26 02:30:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]173.44.55.178:443
. 2015.08.26 02:30:46 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.26 02:30:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.15.81 255.255.0.0'
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.26 02:30:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.26 02:30:46 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.26 02:30:46 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.26 02:30:46 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DA467D7D-3569-4EB5-9993-76BE4130306A}.tap
. 2015.08.26 02:30:46 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.08.26 02:30:46 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.15.81/255.255.0.0 [sUCCEEDED]
. 2015.08.26 02:30:46 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.15.81/255.255.0.0 on interface {DA467D7D-3569-4EB5-9993-76BE4130306A} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.26 02:30:46 - OpenVPN > Successful ARP Flush on interface [15] {DA467D7D-3569-4EB5-9993-76BE4130306A}
. 2015.08.26 02:30:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:30:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:30:51 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:30:52 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:30:52 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:30:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:30:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:30:56 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:30:57 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:30:57 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:30:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:30:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:30:57 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:30:58 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:30:58 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:30:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:30:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:30:59 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:30:59 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:30:59 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:00 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:00 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:00 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:01 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:01 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:01 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:02 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:02 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:02 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:03 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:03 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:03 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:04 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:04 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:04 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:05 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:05 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:05 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:06 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:06 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:06 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:07 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:07 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:07 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:08 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:08 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:09 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:10 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:10 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:10 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:11 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:11 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:11 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:12 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:12 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:12 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:13 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:13 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:14 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:15 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:15 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:15 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:16 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:16 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:16 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:17 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:17 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:17 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:17 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:17 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:18 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:18 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:18 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:19 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:19 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:19 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.08.26 02:31:20 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.08.26 02:31:20 - AirVPN Windows Interface Hack executed (Local Area Connection 4)
. 2015.08.26 02:31:20 - AirVPN Windows Interface Hack executed (Local Area Connection 2)
. 2015.08.26 02:31:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down
. 2015.08.26 02:31:21 - OpenVPN > C:\Windows\system32\route.exe ADD 173.44.55.178 MASK 255.255.255.255 192.168.0.1
. 2015.08.26 02:31:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.08.26 02:31:21 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.26 02:31:21 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.08.26 02:31:21 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.26 02:31:21 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.08.26 02:31:21 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.26 02:31:21 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.08.26 02:31:21 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=3 t=4 pr=3 a=43981 h=0 m=10/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 10.4.0.0 255.255.0.0 10.4.2.132 p=0 i=15 t=3 pr=2 a=2016 h=0 m=276/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 10.4.2.132 255.255.255.255 10.4.2.132 p=0 i=15 t=3 pr=2 a=2016 h=0 m=276/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 10.4.255.255 255.255.255.255 10.4.2.132 p=0 i=15 t=3 pr=2 a=2016 h=0 m=276/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=43989 h=0 m=306/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=43989 h=0 m=306/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=43989 h=0 m=306/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.123.181 p=0 i=7 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.123.242 p=0 i=12 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.123.181 255.255.255.255 169.254.123.181 p=0 i=7 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.123.242 255.255.255.255 169.254.123.242 p=0 i=12 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.123.181 p=0 i=7 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.123.242 p=0 i=12 t=3 pr=2 a=43709 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 173.44.55.178 255.255.255.255 192.168.0.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.2 p=0 i=3 t=3 pr=2 a=43981 h=0 m=266/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=10/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 192.168.0.2 255.255.255.255 192.168.0.2 p=0 i=3 t=3 pr=2 a=43981 h=0 m=266/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.2 p=0 i=3 t=3 pr=2 a=43981 h=0 m=266/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=43989 h=0 m=306/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.2.132 p=0 i=15 t=3 pr=2 a=43987 h=0 m=276/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.2 p=0 i=3 t=3 pr=2 a=43986 h=0 m=266/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.123.181 p=0 i=7 t=3 pr=2 a=43713 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.123.242 p=0 i=12 t=3 pr=2 a=43713 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=43989 h=0 m=306/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.2.132 p=0 i=15 t=3 pr=2 a=43987 h=0 m=276/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.2 p=0 i=3 t=3 pr=2 a=43986 h=0 m=266/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.123.181 p=0 i=7 t=3 pr=2 a=43713 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.123.242 p=0 i=12 t=3 pr=2 a=43713 h=0 m=286/0/0/0/0
. 2015.08.26 02:31:21 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.08.26 02:31:21 - OpenVPN > TAP-Windows Adapter V9
. 2015.08.26 02:31:21 - OpenVPN >   Index = 15
. 2015.08.26 02:31:21 - OpenVPN >   GUID = {DA467D7D-3569-4EB5-9993-76BE4130306A}
. 2015.08.26 02:31:21 - OpenVPN >   IP = 10.4.2.132/255.255.0.0
. 2015.08.26 02:31:21 - OpenVPN >   MAC = 00:ff:da:46:7d:7d
. 2015.08.26 02:31:21 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.08.26 02:31:21 - OpenVPN >   DHCP SERV = 10.4.255.254/255.255.255.255
. 2015.08.26 02:31:21 - OpenVPN >   DHCP LEASE OBTAINED = Wed Aug 26 01:57:44 2015
. 2015.08.26 02:31:21 - OpenVPN >   DHCP LEASE EXPIRES  = Thu Aug 25 01:57:44 2016
. 2015.08.26 02:31:21 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2015.08.26 02:31:21 - OpenVPN > TAP-Win32 Adapter OAS #2
. 2015.08.26 02:31:21 - OpenVPN >   Index = 12
. 2015.08.26 02:31:21 - OpenVPN >   GUID = {A45F2060-660F-4913-8047-59DD38BBC94D}
. 2015.08.26 02:31:21 - OpenVPN >   IP = 169.254.123.242/255.255.0.0
. 2015.08.26 02:31:21 - OpenVPN >   MAC = 00:ff:a4:5f:20:60
. 2015.08.26 02:31:21 - OpenVPN >   Index = 7
. 2015.08.26 02:31:21 - OpenVPN >   GUID = {1041A74D-3659-484A-ABBC-4BEF3B1E194E}
. 2015.08.26 02:31:21 - OpenVPN >   IP = 169.254.123.181/255.255.0.0
. 2015.08.26 02:31:21 - OpenVPN >   MAC = 00:ff:10:41:a7:4d
. 2015.08.26 02:31:21 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30)
. 2015.08.26 02:31:21 - OpenVPN >   Index = 3
. 2015.08.26 02:31:21 - OpenVPN >   GUID = {EF3B52EF-6E46-4729-AE18-0A2E1DD22E7B}
. 2015.08.26 02:31:21 - OpenVPN >   IP = 192.168.0.2/255.255.255.0
. 2015.08.26 02:31:21 - OpenVPN >   MAC = 90:2b:34:33:85:99
. 2015.08.26 02:31:21 - OpenVPN >   GATEWAY = 192.168.0.1/255.255.255.255
. 2015.08.26 02:31:21 - OpenVPN >   DHCP SERV = 192.168.0.1/255.255.255.255
. 2015.08.26 02:31:21 - OpenVPN >   DHCP LEASE OBTAINED = Wed Aug 26 02:28:56 2015
. 2015.08.26 02:31:21 - OpenVPN >   DHCP LEASE EXPIRES  = Wed Aug 26 03:28:56 2015
. 2015.08.26 02:31:21 - OpenVPN >   DNS SERV = 10.213.5.15/255.255.255.255 10.213.2.12/255.255.255.255
. 2015.08.26 02:31:21 - Starting Management Interface
. 2015.08.26 02:31:21 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
! 2015.08.26 02:31:21 - Disconnecting
I 2015.08.26 02:31:21 - DNS of a network adapter forced (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
. 2015.08.26 02:31:21 - Management - Send 'signal SIGTERM'
. 2015.08.26 02:31:21 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
I 2015.08.26 02:31:21 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.08.26 02:31:21 - Flushing DNS
. 2015.08.26 02:31:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.26 02:31:21 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.26 02:31:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.26 02:31:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 173.44.55.178 MASK 255.255.255.255 192.168.0.1
. 2015.08.26 02:31:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.26 02:31:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.08.26 02:31:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.26 02:31:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.26 02:31:26 - OpenVPN > Closing TUN/TAP interface
. 2015.08.26 02:31:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.26 02:31:26 - Connection terminated.
I 2015.08.26 02:31:26 - DNS of a network adapter restored to original settings (Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30))
I 2015.08.26 02:31:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.08.26 02:31:27 - Cancel requested.
I 2015.08.26 02:31:27 - IPv6 restored.
! 2015.08.26 02:31:27 - Session terminated.
