triplehyper
Utorrent AirVPN and IPV6 Leak
Does utorrent together with AirVPN leak ipv6?
With AirVPN connected I did an ipv6 test at https://ipleak.net
"Add this Magnet Link to your torrent client and wait for the results below"
Then it shows "Annonced IPV6: fe80::ffff:ffff:fffe"
Strange when I test it out with qBittorent there wan't any ipv6 to be announced.
What is fe80::ffff:ffff:fffe btw? I assume it's not my real mac address am I right? Because it looks very common on google result.
Prior to using AirVPN, when using other VPN providers why didn't I see any ipv6 announced. So what's up with Eddie?
Oh I'm using utorrent 2.2.1
Some info about my setup:
I have enabled network lock (Actually I imported it's rules and merged it into my existing firewall policy. Then I disabled "Network Lock" So essentially I should have my "Network Lock on" right?)
I have Eddie set to disable ipv6
I have manually disabled ipv6 in windows and the registry
Sorry for the noob questions. Just want to hear from your input and to be sure.
