woot
speed/connection issues
hello,
i have some major speed issues while using airvpn, ever since i started using it i have increasing connection/speed issues. this is bascially the second day now thay i cannot browse the internet using your service. the client connects automatically to the best server, it takes it over a minute, sometimes it even switches a server in the process, connects. for a short while (a minute or two) i have a normal download speed, the it rapidly declines to a few kilobytes, eventually to drop to absolute zero. the client tries reconnecting, does latency checks, connects again and the whole process repeats. there are days that it works fine, but there are days that it just stops working for an extended period of time. just to post this message i had to reconnect twice..
my log file:
I 2015.08.18 18:13:32 - AirVPN client version: 2.8.8, System: Windows, Name: Microsoft Windows NT 6.2.9200.0, Architecture: x64
. 2015.08.18 18:13:32 - Reading options from C:\Users\Maciej\AppData\Local\AirVPN\AirVPN.xml
. 2015.08.18 18:13:33 - Data Path: C:\Users\Maciej\AppData\Local\AirVPN
. 2015.08.18 18:13:33 - App Path: C:\Program Files\AirVPN
. 2015.08.18 18:13:33 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.08.18 18:13:33 - Command line arguments (1): path="home"
. 2015.08.18 18:13:33 - Operating System: Microsoft Windows NT 6.2.9200.0
I 2015.08.18 18:13:40 - OpenVPN Driver - TAP-Windows Adapter V9
I 2015.08.18 18:13:40 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.08.18 18:13:40 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.08.18 18:13:40 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)
I 2015.08.18 18:13:40 - IPV6: Available
! 2015.08.18 18:13:40 - Ready
I 2015.08.18 18:13:42 - Session starting.
I 2015.08.18 18:13:42 - Installing tunnel driver
I 2015.08.18 18:13:45 - Checking authorization ...
! 2015.08.18 18:13:47 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:13:49 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:13:49 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:13:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:13:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:13:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:13:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:13:49 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:13:49 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:13:49 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:13:49 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=7136940c dfdf1353
. 2015.08.18 18:13:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:13:55 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:13:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:13:55 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:13:55 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:13:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:13:55 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:13:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:13:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:13:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:13:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:13:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:14:00 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:14:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2015.08.18 18:14:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:14:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.134 255.255.0.0'
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:14:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:14:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:14:03 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:14:03 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:14:03 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:14:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.134/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:14:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.134/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:14:03 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:14:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:14:08 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:14:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:14:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:14:08 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:14:08 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:14:08 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:14:08 - Starting Management Interface
. 2015.08.18 18:14:08 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:14:08 - Flushing DNS
I 2015.08.18 18:14:08 - Checking route
! 2015.08.18 18:14:08 - Connected.
. 2015.08.18 18:14:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:14:08 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.08.18 18:16:13 - Disconnecting
. 2015.08.18 18:16:13 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:16:13 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:16:13 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:16:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:16:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:16:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:16:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:16:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:16:21 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:16:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:16:21 - Connection terminated.
I 2015.08.18 18:16:24 - Checking authorization ...
. 2015.08.18 18:16:34 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:16:45 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:16:55 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:17:05 - Checking authorization ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:17:05 - Authorization check failed, continue anyway ({1])
! 2015.08.18 18:17:05 - Connecting to Chara (Netherlands, Alblasserdam)
. 2015.08.18 18:17:06 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:17:06 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:17:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:17:06 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:17:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:17:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:17:06 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:17:06 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:17:06 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.132:443
. 2015.08.18 18:17:13 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.132:443, sid=c674e107 8f2d59b9
. 2015.08.18 18:17:59 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.18 18:17:59 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:18:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.18 18:18:04 - Disconnecting
. 2015.08.18 18:18:04 - Connection terminated.
I 2015.08.18 18:18:07 - Checking authorization ...
! 2015.08.18 18:18:09 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:18:11 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:18:11 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:18:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:18:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:18:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:18:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:18:11 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:18:11 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:18:11 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:18:13 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=daafd7d4 b29ba032
. 2015.08.18 18:18:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:18:28 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:18:28 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:18:28 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:18:28 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:18:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:18:28 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:18:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:19:11 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
. 2015.08.18 18:19:11 - OpenVPN > TLS Error: TLS handshake failed
. 2015.08.18 18:19:11 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2015.08.18 18:19:11 - OpenVPN > Restart pause, 2 second(s)
! 2015.08.18 18:19:12 - Disconnecting
. 2015.08.18 18:19:12 - Connection terminated.
I 2015.08.18 18:19:15 - Checking authorization ...
! 2015.08.18 18:19:17 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:19:18 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:19:18 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:19:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:19:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:19:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:19:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:19:18 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:19:18 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:19:18 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:19:20 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=edade39d 7c562006
. 2015.08.18 18:20:18 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
. 2015.08.18 18:20:18 - OpenVPN > TLS Error: TLS handshake failed
. 2015.08.18 18:20:18 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2015.08.18 18:20:18 - OpenVPN > Restart pause, 2 second(s)
! 2015.08.18 18:20:18 - Disconnecting
. 2015.08.18 18:20:18 - Connection terminated.
I 2015.08.18 18:20:21 - Checking authorization ...
! 2015.08.18 18:20:22 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:20:23 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:20:23 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:20:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:20:23 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:20:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:20:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:20:23 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:20:23 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:20:23 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:20:23 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=126bc28f cedf9d39
. 2015.08.18 18:20:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:20:29 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:20:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:20:29 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:20:29 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:20:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:20:29 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:20:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:20:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:20:40 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:20:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:20:40 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:20:40 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:20:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2015.08.18 18:20:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:20:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.134 255.255.0.0'
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:20:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:20:43 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:20:43 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:20:43 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:20:43 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:20:43 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.134/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:20:43 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.134/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:20:43 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:20:48 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:20:48 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:20:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.08.18 18:20:48 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:20:48 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:20:48 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:20:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:20:48 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:20:48 - Starting Management Interface
. 2015.08.18 18:20:48 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:20:48 - Flushing DNS
I 2015.08.18 18:20:48 - Checking route
W 2015.08.18 18:20:58 - Checking route, 1° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:21:08 - Checking route, 2° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:21:18 - Checking route, 3° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:21:28 - Checking route, 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:21:38 - Checking route, 5° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:21:38 - Upłynął limit czasu operacji
! 2015.08.18 18:21:38 - Disconnecting
. 2015.08.18 18:21:38 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:21:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.08.18 18:21:38 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:21:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:21:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:21:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:21:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:21:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:21:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:21:43 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:21:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:21:43 - Connection terminated.
I 2015.08.18 18:21:46 - Checking authorization ...
. 2015.08.18 18:21:56 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:22:06 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:22:16 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:22:26 - Checking authorization ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:22:26 - Authorization check failed, continue anyway ({1])
! 2015.08.18 18:22:26 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:22:27 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:22:27 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:22:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:22:27 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:22:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:22:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:22:27 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:22:27 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:22:27 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:22:37 - Updating systems & servers data ...
. 2015.08.18 18:22:47 - Updating systems & servers data ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:22:57 - Updating systems & servers data ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:22:59 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.18 18:22:59 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:23:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.18 18:23:04 - Disconnecting
. 2015.08.18 18:23:04 - Connection terminated.
I 2015.08.18 18:23:07 - Checking authorization ...
. 2015.08.18 18:23:07 - Updating systems & servers data ..., 3° try failed (Upłynął limit czasu operacji)
! 2015.08.18 18:23:10 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:23:12 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:23:12 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:23:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:23:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:23:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:23:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:23:12 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:23:12 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:23:12 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:23:12 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=91687c04 15d63557
. 2015.08.18 18:23:17 - Updating systems & servers data ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:23:17 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Upłynął limit czasu operacji)
. 2015.08.18 18:23:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:23:24 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:23:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:23:24 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:23:24 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:23:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:23:24 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:23:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:24:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:24:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:24:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:01 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:24:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2015.08.18 18:24:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:24:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.134 255.255.0.0'
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:24:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:24:05 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:24:05 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:24:05 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:24:05 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:24:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.134/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:24:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.134/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:24:05 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:24:10 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:24:10 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:24:10 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:24:10 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:24:10 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:24:10 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:24:10 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:24:10 - Starting Management Interface
. 2015.08.18 18:24:10 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:24:10 - Flushing DNS
I 2015.08.18 18:24:10 - Checking route
. 2015.08.18 18:24:18 - Updating systems & servers data ...
W 2015.08.18 18:24:20 - Checking route, 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:24:28 - Updating systems & servers data ..., 1° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:24:30 - Checking route, 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:24:38 - Updating systems & servers data ..., 2° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:24:40 - Checking route, 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:24:40 - Systems & servers data update completed
! 2015.08.18 18:24:40 - Connected.
. 2015.08.18 18:24:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:24:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.08.18 18:24:41 - Disconnecting
. 2015.08.18 18:24:41 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:24:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:24:41 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:24:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:24:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:24:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:24:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:24:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:24:46 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:24:46 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:24:46 - Connection terminated.
! 2015.08.18 18:24:46 - Session terminated.
I 2015.08.18 18:24:48 - Session starting.
I 2015.08.18 18:24:48 - Installing tunnel driver
I 2015.08.18 18:24:48 - Checking authorization ...
! 2015.08.18 18:24:51 - Connecting to Matar (Netherlands, Alblasserdam)
. 2015.08.18 18:24:52 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:24:52 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:24:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:24:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:24:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:52 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:24:52 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:24:52 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.137:443
. 2015.08.18 18:24:53 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.137:443, sid=19907898 42dbeef2
. 2015.08.18 18:24:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:24:54 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:24:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:24:54 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:24:54 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:24:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:24:54 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:24:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:24:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:24:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:24:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:24:57 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:24:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.137:443
. 2015.08.18 18:24:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:24:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.10.75 255.255.0.0'
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:24:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:24:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:24:59 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:24:59 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:24:59 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:24:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.10.75/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:24:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.10.75/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:24:59 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:25:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:25:04 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.137 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:25:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:25:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:25:04 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:25:04 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:25:04 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:25:04 - Starting Management Interface
. 2015.08.18 18:25:04 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:25:04 - Flushing DNS
I 2015.08.18 18:25:04 - Checking route
! 2015.08.18 18:25:07 - Connected.
. 2015.08.18 18:25:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:25:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.08.18 18:27:01 - OpenVPN > Authenticate/Decrypt packet error: packet HMAC authentication failed
! 2015.08.18 18:28:42 - Disconnecting
. 2015.08.18 18:28:42 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:28:42 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:28:42 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:28:53 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:28:53 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2015.08.18 18:28:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.137 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:28:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:28:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:28:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:28:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:28:56 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:28:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:28:56 - Connection terminated.
I 2015.08.18 18:28:59 - Checking authorization ...
. 2015.08.18 18:29:09 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:29:19 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:29:29 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:29:39 - Checking authorization ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:29:39 - Authorization check failed, continue anyway ({1])
! 2015.08.18 18:29:39 - Connecting to Tauri (Germany, Frankfurt)
. 2015.08.18 18:29:39 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:29:39 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:29:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:29:40 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:29:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:29:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:29:40 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:29:40 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:29:40 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.65:443
. 2015.08.18 18:29:42 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.65:443, sid=e902bb97 7390b570
. 2015.08.18 18:29:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:29:49 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:29:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:29:49 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:29:49 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:29:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:29:49 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:29:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:30:41 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
. 2015.08.18 18:30:41 - OpenVPN > TLS Error: TLS handshake failed
. 2015.08.18 18:30:41 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2015.08.18 18:30:41 - OpenVPN > Restart pause, 2 second(s)
! 2015.08.18 18:30:41 - Disconnecting
. 2015.08.18 18:30:41 - Connection terminated.
I 2015.08.18 18:30:44 - Checking authorization ...
! 2015.08.18 18:30:44 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:30:46 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:30:46 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:30:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:30:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:30:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:30:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:30:46 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:30:46 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:30:46 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:30:46 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=89fa5d8b 4006eed0
. 2015.08.18 18:30:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:30:46 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:30:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:30:46 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:30:46 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:30:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:30:46 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:30:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:31:46 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
. 2015.08.18 18:31:46 - OpenVPN > TLS Error: TLS handshake failed
. 2015.08.18 18:31:46 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2015.08.18 18:31:46 - OpenVPN > Restart pause, 2 second(s)
! 2015.08.18 18:31:46 - Disconnecting
. 2015.08.18 18:31:46 - Connection terminated.
I 2015.08.18 18:31:49 - Checking authorization ...
! 2015.08.18 18:31:50 - Connecting to Phaet (Netherlands, Alblasserdam)
. 2015.08.18 18:31:51 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:31:51 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:31:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:31:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:31:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:31:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:31:52 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:31:52 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:31:52 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.148:443
. 2015.08.18 18:31:52 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.148:443, sid=1e1a8b1b ef0c5cc3
. 2015.08.18 18:31:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:31:52 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:31:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:31:52 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:31:52 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:31:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:31:52 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:31:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:31:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:31:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:31:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:31:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:31:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:31:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.148:443
. 2015.08.18 18:31:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:31:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.233 255.255.0.0'
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:31:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:31:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:31:58 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:31:58 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:31:58 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:31:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.4.233/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:31:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.4.233/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:31:58 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:32:03 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:32:03 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:32:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2015.08.18 18:32:03 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:32:03 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:32:03 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:32:03 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:32:03 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:32:03 - Starting Management Interface
. 2015.08.18 18:32:03 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:32:03 - Flushing DNS
I 2015.08.18 18:32:03 - Checking route
! 2015.08.18 18:32:04 - Connected.
. 2015.08.18 18:32:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:32:04 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.08.18 18:35:33 - Disconnecting
. 2015.08.18 18:35:33 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:35:33 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:35:33 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:35:38 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:35:38 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:35:38 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:35:38 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:35:38 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:35:38 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:35:38 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:35:38 - Connection terminated.
I 2015.08.18 18:35:41 - Checking authorization ...
. 2015.08.18 18:35:51 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:36:01 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:36:11 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:36:21 - Checking authorization ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:36:21 - Authorization check failed, continue anyway ({1])
! 2015.08.18 18:36:21 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2015.08.18 18:36:22 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:36:22 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:36:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:36:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:36:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:36:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:36:22 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:36:22 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:36:22 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.214.162:443
. 2015.08.18 18:36:23 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.162:443, sid=5f625878 80b5e043
. 2015.08.18 18:37:22 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
. 2015.08.18 18:37:22 - OpenVPN > TLS Error: TLS handshake failed
. 2015.08.18 18:37:22 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2015.08.18 18:37:22 - OpenVPN > Restart pause, 2 second(s)
! 2015.08.18 18:37:22 - Disconnecting
. 2015.08.18 18:37:22 - Connection terminated.
I 2015.08.18 18:37:25 - Checking authorization ...
! 2015.08.18 18:37:26 - Connecting to Phaet (Netherlands, Alblasserdam)
. 2015.08.18 18:37:27 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:37:27 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:37:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:37:27 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:37:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:37:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:37:27 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:37:27 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:37:27 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.148:443
. 2015.08.18 18:37:29 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.148:443, sid=90a4c1fb a3326ba0
. 2015.08.18 18:37:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:37:29 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:37:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:37:29 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:37:29 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:37:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:37:29 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:37:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:37:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:37:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:37:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:37:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:37:32 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:37:32 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.148:443
. 2015.08.18 18:37:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:37:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.233 255.255.0.0'
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:37:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:37:34 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:37:34 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:37:35 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:37:35 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:37:35 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.4.233/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:37:35 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.4.233/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:37:35 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:37:39 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:37:39 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:37:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:37:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:37:39 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:37:39 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:37:39 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:37:39 - Starting Management Interface
. 2015.08.18 18:37:39 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:37:39 - Flushing DNS
I 2015.08.18 18:37:39 - Checking route
! 2015.08.18 18:37:40 - Connected.
. 2015.08.18 18:37:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:37:40 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.08.18 18:41:14 - Disconnecting
. 2015.08.18 18:41:14 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:41:14 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:41:14 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:41:24 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.148 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:41:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:41:24 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:41:24 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:41:24 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:41:24 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:41:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:41:24 - Connection terminated.
I 2015.08.18 18:41:27 - Checking authorization ...
. 2015.08.18 18:41:37 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:41:47 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:41:57 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
! 2015.08.18 18:41:58 - Connecting to Matar (Netherlands, Alblasserdam)
. 2015.08.18 18:42:00 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:42:00 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:42:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:42:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:42:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:42:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:42:00 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:42:00 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:42:00 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.137:443
. 2015.08.18 18:42:06 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.137:443, sid=f0274ea6 d974b398
. 2015.08.18 18:42:52 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.18 18:42:52 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:42:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.18 18:42:57 - Disconnecting
. 2015.08.18 18:42:57 - Connection terminated.
I 2015.08.18 18:43:15 - Checking authorization ...
! 2015.08.18 18:43:18 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:43:19 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:43:19 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:43:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:43:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:43:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:43:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:43:19 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:43:19 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:43:19 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:43:19 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=879b8050 af21f81c
. 2015.08.18 18:43:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:43:51 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:43:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:43:51 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:43:51 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:43:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:43:51 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:43:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:43:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:43:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:43:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:43:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:43:58 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:43:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2015.08.18 18:44:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:44:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.134 255.255.0.0'
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:44:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:44:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:44:00 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:44:00 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:44:00 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:44:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.134/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:44:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.134/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:44:00 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:44:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:44:05 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:44:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.08.18 18:44:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:44:05 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:44:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:44:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:44:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:44:05 - Starting Management Interface
. 2015.08.18 18:44:05 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:44:05 - Flushing DNS
I 2015.08.18 18:44:05 - Checking route
W 2015.08.18 18:44:15 - Checking route, 1° try failed (Upłynął limit czasu operacji)
! 2015.08.18 18:44:19 - Connected.
. 2015.08.18 18:44:19 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:44:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.08.18 18:47:08 - Disconnecting
. 2015.08.18 18:47:08 - Management - Send 'signal SIGTERM'
. 2015.08.18 18:47:08 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.08.18 18:47:08 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:47:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:47:13 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.08.18 18:47:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:47:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:47:13 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:47:13 - OpenVPN > Closing TUN/TAP interface
. 2015.08.18 18:47:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.08.18 18:47:13 - Connection terminated.
! 2015.08.18 18:47:13 - Session terminated.
I 2015.08.18 18:47:20 - Session starting.
I 2015.08.18 18:47:20 - Installing tunnel driver
I 2015.08.18 18:47:20 - Checking authorization ...
. 2015.08.18 18:47:30 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:47:40 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:47:50 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
! 2015.08.18 18:47:50 - Connecting to Aquilae (Germany, Frankfurt)
. 2015.08.18 18:47:52 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:47:52 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:47:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:47:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:47:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:47:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:47:52 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:47:52 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:47:52 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.70:443
. 2015.08.18 18:47:52 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=60d5d953 57881f43
. 2015.08.18 18:48:26 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.18 18:48:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.18 18:48:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.18 18:48:32 - Disconnecting
. 2015.08.18 18:48:32 - Connection terminated.
I 2015.08.18 18:48:35 - Checking authorization ...
. 2015.08.18 18:48:45 - Checking authorization ..., 1° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:48:55 - Checking authorization ..., 2° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:49:05 - Checking authorization ..., 3° try failed (Upłynął limit czasu operacji)
. 2015.08.18 18:49:15 - Checking authorization ..., 4° try failed (Upłynął limit czasu operacji)
W 2015.08.18 18:49:15 - Authorization check failed, continue anyway ({1])
! 2015.08.18 18:49:15 - Connecting to Anser (Netherlands, Alblasserdam)
. 2015.08.18 18:49:16 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.18 18:49:16 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.18 18:49:16 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.18 18:49:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.18 18:49:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:49:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:49:16 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.08.18 18:49:16 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.18 18:49:16 - OpenVPN > UDPv4 link remote: [AF_INET]109.202.103.169:443
. 2015.08.18 18:49:18 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.103.169:443, sid=f66039f6 59a89605
. 2015.08.18 18:49:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.08.18 18:49:19 - OpenVPN > Validating certificate key usage
. 2015.08.18 18:49:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.08.18 18:49:19 - OpenVPN > VERIFY KU OK
. 2015.08.18 18:49:19 - OpenVPN > Validating certificate extended key usage
. 2015.08.18 18:49:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.08.18 18:49:19 - OpenVPN > VERIFY EKU OK
. 2015.08.18 18:49:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.08.18 18:49:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:49:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:49:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.08.18 18:49:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.18 18:49:25 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.08.18 18:49:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.202.103.169:443
. 2015.08.18 18:49:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.08.18 18:49:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.134 255.255.0.0'
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.08.18 18:49:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.08.18 18:49:27 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.08.18 18:49:27 - OpenVPN > open_tun, tt->ipv6=0
. 2015.08.18 18:49:27 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{DFB59C59-0B35-4BDD-84CA-EC1477C4D851}.tap
. 2015.08.18 18:49:27 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.08.18 18:49:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.134/255.255.0.0 [sUCCEEDED]
. 2015.08.18 18:49:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.134/255.255.0.0 on interface {DFB59C59-0B35-4BDD-84CA-EC1477C4D851} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.08.18 18:49:27 - OpenVPN > Successful ARP Flush on interface [19] {DFB59C59-0B35-4BDD-84CA-EC1477C4D851}
. 2015.08.18 18:49:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.08.18 18:49:32 - OpenVPN > C:\Windows\system32\route.exe ADD 109.202.103.169 MASK 255.255.255.255 192.168.1.1
. 2015.08.18 18:49:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.08.18 18:49:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.08.18 18:49:32 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 6
. 2015.08.18 18:49:32 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:49:32 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.08.18 18:49:32 - Starting Management Interface
. 2015.08.18 18:49:32 - OpenVPN > Initialization Sequence Completed
I 2015.08.18 18:49:32 - Flushing DNS
I 2015.08.18 18:49:32 - Checking route
! 2015.08.18 18:49:33 - Connected.
. 2015.08.18 18:49:33 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.08.18 18:49:33 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
