Ulysses
Can't connect - permanently tries to reconnect from client
Having a problem connecting. I installed latest client but no further forward - any suggestions welcome!
I 2015.08.05 12:01:20 - AirVPN client version: 2.9.2, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Architecture: x64
. 2015.08.05 12:01:20 - Reading options from C:\Users\XXXX\AppData\Local\AirVPN\AirVPN.xml
. 2015.08.05 12:01:21 - Data Path: C:\Users\XXXX\AppData\Local\AirVPN
. 2015.08.05 12:01:21 - App Path: C:\Program Files\AirVPN
. 2015.08.05 12:01:21 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.08.05 12:01:21 - Command line arguments (1): path="home"
. 2015.08.05 12:01:21 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2015.08.05 12:01:21 - Updating systems & servers data ...
W 2015.08.05 12:01:21 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
E 2015.08.05 12:01:22 - OpenVPN Driver - Not available
I 2015.08.05 12:01:22 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.08.05 12:01:22 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.08.05 12:01:22 - SSL - Version: stunnel 5.09 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.08.05 12:01:22 - Ready
. 2015.08.05 12:01:24 - Systems & servers data update completed
I 2015.08.05 12:01:37 - Session starting.
W 2015.08.05 12:01:37 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
! 2015.08.05 12:01:37 - Installing tunnel driver
I 2015.08.05 12:03:36 - IPv6 disabled.
I 2015.08.05 12:03:36 - Checking authorization ...
! 2015.08.05 12:03:37 - Connecting to Dabih (United Kingdom, Manchester)
. 2015.08.05 12:03:37 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.05 12:03:37 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.05 12:03:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.05 12:03:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.05 12:03:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.05 12:03:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.05 12:03:37 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.08.05 12:03:37 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.05 12:03:37 - OpenVPN > UDPv4 link remote: [AF_INET]82.145.37.202:443
. 2015.08.05 12:04:09 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.05 12:04:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.05 12:04:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.05 12:04:14 - Disconnecting
. 2015.08.05 12:04:14 - Connection terminated.
I 2015.08.05 12:04:17 - Checking authorization ...
! 2015.08.05 12:04:18 - Connecting to Sheliak (Netherlands, Alblasserdam)
. 2015.08.05 12:04:18 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.08.05 12:04:18 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.08.05 12:04:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.08.05 12:04:18 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.08.05 12:04:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.05 12:04:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.08.05 12:04:18 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.08.05 12:04:18 - OpenVPN > UDPv4 link local: [undef]
. 2015.08.05 12:04:18 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.113:443
. 2015.08.05 12:04:50 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.08.05 12:04:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.08.05 12:04:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.08.05 12:04:55 - Disconnecting
. 2015.08.05 12:04:55 - Connection terminated.
Thx
F.
