Quacklol
No connection when I'm not at home
I can connect fine when I'm at home, but as soon as I go somewhere else - my parents - friends etc
I just get a reset cycle, I've tried unchecking the DNS tunel check and the check tunel thing in the advanced bit
when both are unchecked I can connect, but I get no download speed.
here is my log thing
I 2015.07.24 13:53:13 - AirVPN client version: 2.9.2, System: Windows, Name: Microsoft Windows NT 6.2.9200.0, Architecture: x64
. 2015.07.24 13:53:14 - Reading options from C:\Users\Dan\Desktop\airvpn_windows8_x64_portable\AirVPN.xml
. 2015.07.24 13:53:14 - Data Path: C:\Users\Dan\Desktop\airvpn_windows8_x64_portable
. 2015.07.24 13:53:14 - App Path: C:\Users\Dan\Desktop\airvpn_windows8_x64_portable
. 2015.07.24 13:53:14 - Executable Path: C:\Users\Dan\Desktop\airvpn_windows8_x64_portable\AirVPN.exe
. 2015.07.24 13:53:14 - Command line arguments (0):
. 2015.07.24 13:53:14 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2015.07.24 13:53:14 - Updating systems & servers data ...
I 2015.07.24 13:53:14 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.07.24 13:53:14 - OpenVPN - Version: OpenVPN 2.3.6 (C:\Users\Dan\Desktop\airvpn_windows8_x64_portable\openvpn.exe)
I 2015.07.24 13:53:14 - SSH - Version: plink 0.63 (C:\Users\Dan\Desktop\airvpn_windows8_x64_portable\plink.exe)
I 2015.07.24 13:53:14 - SSL - Version: stunnel 5.09 (C:\Users\Dan\Desktop\airvpn_windows8_x64_portable\stunnel.exe)
! 2015.07.24 13:53:14 - Ready
. 2015.07.24 13:53:14 - Systems & servers data update completed
I 2015.07.24 13:53:48 - Session starting.
I 2015.07.24 13:53:48 - IPv6 disabled.
I 2015.07.24 13:53:48 - Checking authorization ...
! 2015.07.24 13:53:48 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2015.07.24 13:53:58 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 13:53:58 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 13:53:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 13:53:58 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 13:53:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:53:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:53:58 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 13:53:58 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 13:53:58 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.78:443
. 2015.07.24 13:53:58 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=3e1a63e8 150f66ad
. 2015.07.24 13:53:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 13:53:58 - OpenVPN > Validating certificate key usage
. 2015.07.24 13:53:58 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 13:53:58 - OpenVPN > VERIFY KU OK
. 2015.07.24 13:53:58 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 13:53:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 13:53:58 - OpenVPN > VERIFY EKU OK
. 2015.07.24 13:53:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 13:53:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:53:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:53:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:53:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:53:58 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 13:53:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2015.07.24 13:53:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 13:53:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.26 255.255.0.0'
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 13:53:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 13:53:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 13:53:58 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 13:53:58 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 13:53:58 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 13:53:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.26/255.255.0.0 [sUCCEEDED]
. 2015.07.24 13:53:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.26/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 13:53:58 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 13:53:58 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 13:53:58 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:53:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 13:53:58 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 13:53:58 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 13:53:58 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:53:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 13:53:58 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:53:58 - Starting Management Interface
. 2015.07.24 13:53:58 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 13:53:58 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 13:53:58 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 13:53:58 - Flushing DNS
I 2015.07.24 13:53:58 - Checking DNS
W 2015.07.24 13:54:23 - The remote name could not be resolved: 'alrai_exit.airvpn.org'
! 2015.07.24 13:54:23 - Disconnecting
. 2015.07.24 13:54:23 - Management - Send 'signal SIGTERM'
. 2015.07.24 13:54:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 13:54:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 13:54:23 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 13:54:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:54:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 13:54:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:54:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:54:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:54:28 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 13:54:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 13:54:28 - Connection terminated.
I 2015.07.24 13:54:28 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 13:54:28 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 13:54:28 - Cancel requested.
I 2015.07.24 13:54:28 - IPv6 restored.
! 2015.07.24 13:54:28 - Session terminated.
I 2015.07.24 13:58:24 - Session starting.
I 2015.07.24 13:58:24 - IPv6 disabled.
I 2015.07.24 13:58:24 - Checking authorization ...
! 2015.07.24 13:58:24 - Connecting to Diphda (Netherlands, Alblasserdam)
. 2015.07.24 13:58:24 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 13:58:25 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 13:58:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 13:58:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 13:58:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:58:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:58:25 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 13:58:25 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 13:58:25 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.164:443
. 2015.07.24 13:58:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=b907e096 c503d878
. 2015.07.24 13:58:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 13:58:25 - OpenVPN > Validating certificate key usage
. 2015.07.24 13:58:25 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 13:58:25 - OpenVPN > VERIFY KU OK
. 2015.07.24 13:58:25 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 13:58:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 13:58:25 - OpenVPN > VERIFY EKU OK
. 2015.07.24 13:58:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 13:58:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:58:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:58:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:58:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:58:28 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 13:58:28 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443
. 2015.07.24 13:58:30 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 13:58:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.9.213 255.255.0.0'
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 13:58:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 13:58:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 13:58:30 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 13:58:30 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 13:58:30 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 13:58:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.9.213/255.255.0.0 [sUCCEEDED]
. 2015.07.24 13:58:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.9.213/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 13:58:30 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 13:58:35 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 13:58:35 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.164 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:58:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 13:58:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 13:58:35 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 13:58:35 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:58:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 13:58:35 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:58:35 - Starting Management Interface
. 2015.07.24 13:58:35 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 13:58:35 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 13:58:35 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 13:58:35 - Flushing DNS
! 2015.07.24 13:58:35 - Connected.
. 2015.07.24 13:58:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 13:58:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.07.24 13:59:23 - Disconnecting
. 2015.07.24 13:59:23 - Management - Send 'signal SIGTERM'
. 2015.07.24 13:59:23 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 13:59:23 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 13:59:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.164 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:59:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 13:59:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:59:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:59:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:59:28 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 13:59:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 13:59:28 - Connection terminated.
I 2015.07.24 13:59:28 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 13:59:28 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 13:59:28 - IPv6 restored.
! 2015.07.24 13:59:28 - Session terminated.
I 2015.07.24 13:59:30 - Session starting.
I 2015.07.24 13:59:30 - IPv6 disabled.
I 2015.07.24 13:59:30 - Checking authorization ...
! 2015.07.24 13:59:30 - Connecting to Acubens (Sweden, Uppsala)
. 2015.07.24 13:59:32 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 13:59:32 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 13:59:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 13:59:32 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 13:59:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:59:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:59:32 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 13:59:32 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 13:59:32 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.131:443
. 2015.07.24 13:59:32 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.131:443, sid=2c750e2d 0d0d5e4e
. 2015.07.24 13:59:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 13:59:32 - OpenVPN > Validating certificate key usage
. 2015.07.24 13:59:32 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 13:59:32 - OpenVPN > VERIFY KU OK
. 2015.07.24 13:59:32 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 13:59:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 13:59:32 - OpenVPN > VERIFY EKU OK
. 2015.07.24 13:59:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 13:59:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:59:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:59:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 13:59:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 13:59:38 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 13:59:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.131:443
. 2015.07.24 13:59:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 13:59:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.213 255.255.0.0'
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 13:59:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 13:59:40 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 13:59:40 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 13:59:40 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 13:59:40 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 13:59:40 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.213/255.255.0.0 [sUCCEEDED]
. 2015.07.24 13:59:40 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.213/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 13:59:40 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 13:59:45 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 13:59:45 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.131 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 13:59:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 13:59:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 13:59:45 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 13:59:45 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:59:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 13:59:45 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 13:59:45 - Starting Management Interface
. 2015.07.24 13:59:45 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 13:59:45 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 13:59:45 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 13:59:45 - Flushing DNS
! 2015.07.24 13:59:45 - Connected.
. 2015.07.24 13:59:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 13:59:45 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.07.24 14:00:03 - Disconnecting
. 2015.07.24 14:00:03 - Management - Send 'signal SIGTERM'
. 2015.07.24 14:00:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 14:00:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 14:00:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 62.102.148.131 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:00:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 14:00:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:00:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:00:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:00:08 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 14:00:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 14:00:08 - Connection terminated.
I 2015.07.24 14:00:08 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:00:08 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 14:00:08 - IPv6 restored.
! 2015.07.24 14:00:08 - Session terminated.
I 2015.07.24 14:01:39 - Session starting.
I 2015.07.24 14:01:39 - IPv6 disabled.
I 2015.07.24 14:01:39 - Checking authorization ...
! 2015.07.24 14:01:39 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2015.07.24 14:01:39 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 14:01:39 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 14:01:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 14:01:39 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 14:01:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:01:39 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:01:39 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 14:01:39 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 14:01:39 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.78:443
. 2015.07.24 14:01:39 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=771b2509 d9ade5d6
. 2015.07.24 14:01:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 14:01:39 - OpenVPN > Validating certificate key usage
. 2015.07.24 14:01:39 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 14:01:39 - OpenVPN > VERIFY KU OK
. 2015.07.24 14:01:39 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 14:01:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 14:01:39 - OpenVPN > VERIFY EKU OK
. 2015.07.24 14:01:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 14:01:44 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:01:44 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:01:44 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:01:44 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:01:44 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 14:01:44 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2015.07.24 14:01:47 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 14:01:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.26 255.255.0.0'
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 14:01:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 14:01:47 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 14:01:47 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 14:01:47 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 14:01:47 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 14:01:47 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.26/255.255.0.0 [sUCCEEDED]
. 2015.07.24 14:01:47 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.26/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 14:01:47 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 14:01:52 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 14:01:52 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:01:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 14:01:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 14:01:52 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 14:01:52 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:01:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 14:01:52 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:01:52 - Starting Management Interface
. 2015.07.24 14:01:52 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 14:01:52 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:01:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 14:01:52 - Flushing DNS
I 2015.07.24 14:01:52 - Checking route
W 2015.07.24 14:02:17 - The remote name could not be resolved: 'alrai_exit.airvpn.org'
! 2015.07.24 14:02:17 - Disconnecting
. 2015.07.24 14:02:17 - Management - Send 'signal SIGTERM'
. 2015.07.24 14:02:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 14:02:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 14:02:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 14:02:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:02:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 14:02:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:02:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:02:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:02:22 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 14:02:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 14:02:22 - Connection terminated.
I 2015.07.24 14:02:22 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:02:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 14:02:22 - Cancel requested.
I 2015.07.24 14:02:22 - IPv6 restored.
! 2015.07.24 14:02:22 - Session terminated.
! 2015.07.24 14:03:12 - Activation of Network Lock - Windows Firewall
I 2015.07.24 14:03:19 - Session starting.
I 2015.07.24 14:03:19 - IPv6 disabled.
I 2015.07.24 14:03:19 - Checking authorization ...
! 2015.07.24 14:03:19 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2015.07.24 14:03:19 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 14:03:19 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 14:03:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 14:03:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 14:03:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:03:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:03:19 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 14:03:19 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 14:03:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.78:443
. 2015.07.24 14:03:19 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=9ba545d2 6d2b69a4
. 2015.07.24 14:03:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 14:03:19 - OpenVPN > Validating certificate key usage
. 2015.07.24 14:03:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 14:03:19 - OpenVPN > VERIFY KU OK
. 2015.07.24 14:03:19 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 14:03:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 14:03:19 - OpenVPN > VERIFY EKU OK
. 2015.07.24 14:03:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 14:03:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:03:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:03:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:03:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:03:22 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 14:03:22 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2015.07.24 14:03:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 14:03:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.26 255.255.0.0'
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 14:03:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 14:03:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 14:03:25 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 14:03:25 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 14:03:25 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 14:03:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.26/255.255.0.0 [sUCCEEDED]
. 2015.07.24 14:03:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.26/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 14:03:25 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 14:03:30 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 14:03:30 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:03:30 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 14:03:30 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 14:03:30 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 14:03:30 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:03:30 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 14:03:30 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:03:30 - Starting Management Interface
. 2015.07.24 14:03:30 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 14:03:30 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:03:30 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 14:03:30 - Flushing DNS
I 2015.07.24 14:03:30 - Checking route
W 2015.07.24 14:03:55 - The remote name could not be resolved: 'alrai_exit.airvpn.org'
! 2015.07.24 14:03:55 - Disconnecting
. 2015.07.24 14:03:55 - Management - Send 'signal SIGTERM'
. 2015.07.24 14:03:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 14:03:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 14:03:55 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 14:04:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 14:04:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:00 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 14:04:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 14:04:00 - Connection terminated.
I 2015.07.24 14:04:00 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:04:00 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 14:04:03 - Checking authorization ...
! 2015.07.24 14:04:03 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2015.07.24 14:04:03 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 14:04:03 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 14:04:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 14:04:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 14:04:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:03 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 14:04:03 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 14:04:03 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.78:443
. 2015.07.24 14:04:03 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=07cf3573 71b566b1
. 2015.07.24 14:04:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 14:04:03 - OpenVPN > Validating certificate key usage
. 2015.07.24 14:04:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 14:04:03 - OpenVPN > VERIFY KU OK
. 2015.07.24 14:04:03 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 14:04:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 14:04:03 - OpenVPN > VERIFY EKU OK
. 2015.07.24 14:04:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 14:04:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:04:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:04:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:08 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 14:04:08 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2015.07.24 14:04:11 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 14:04:11 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.26 255.255.0.0'
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 14:04:11 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 14:04:11 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 14:04:11 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 14:04:11 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 14:04:11 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 14:04:11 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.26/255.255.0.0 [sUCCEEDED]
. 2015.07.24 14:04:11 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.26/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 14:04:11 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 14:04:16 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 14:04:16 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 14:04:16 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 14:04:16 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 14:04:16 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:16 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 14:04:16 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:16 - Starting Management Interface
. 2015.07.24 14:04:16 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 14:04:16 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:04:16 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 14:04:16 - Flushing DNS
I 2015.07.24 14:04:16 - Checking route
W 2015.07.24 14:04:40 - The remote name could not be resolved: 'alrai_exit.airvpn.org'
! 2015.07.24 14:04:41 - Disconnecting
. 2015.07.24 14:04:41 - Management - Send 'signal SIGTERM'
. 2015.07.24 14:04:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 14:04:41 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 14:04:41 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.07.24 14:04:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:46 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.07.24 14:04:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:46 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:46 - OpenVPN > Closing TUN/TAP interface
. 2015.07.24 14:04:46 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.07.24 14:04:46 - Connection terminated.
I 2015.07.24 14:04:46 - DNS of a network adapter restored to original settings (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:04:46 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.07.24 14:04:49 - Checking authorization ...
! 2015.07.24 14:04:49 - Connecting to Alrai (Netherlands, Alblasserdam)
. 2015.07.24 14:04:49 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.07.24 14:04:49 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.07.24 14:04:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.07.24 14:04:49 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.07.24 14:04:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:49 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.07.24 14:04:49 - OpenVPN > UDPv4 link local: [undef]
. 2015.07.24 14:04:49 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.78:443
. 2015.07.24 14:04:49 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.78:443, sid=2aed0078 96687a20
. 2015.07.24 14:04:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.07.24 14:04:49 - OpenVPN > Validating certificate key usage
. 2015.07.24 14:04:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.07.24 14:04:49 - OpenVPN > VERIFY KU OK
. 2015.07.24 14:04:49 - OpenVPN > Validating certificate extended key usage
. 2015.07.24 14:04:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.07.24 14:04:49 - OpenVPN > VERIFY EKU OK
. 2015.07.24 14:04:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.07.24 14:04:52 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:04:52 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:52 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.07.24 14:04:52 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.07.24 14:04:52 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.07.24 14:04:52 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.78:443
. 2015.07.24 14:04:54 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.07.24 14:04:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.14.26 255.255.0.0'
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.07.24 14:04:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.07.24 14:04:54 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.07.24 14:04:54 - OpenVPN > open_tun, tt->ipv6=0
. 2015.07.24 14:04:54 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{575A1A9E-1589-4558-BF1D-17D7D1DB6E70}.tap
. 2015.07.24 14:04:54 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.07.24 14:04:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.14.26/255.255.0.0 [sUCCEEDED]
. 2015.07.24 14:04:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.14.26/255.255.0.0 on interface {575A1A9E-1589-4558-BF1D-17D7D1DB6E70} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.07.24 14:04:54 - OpenVPN > Successful ARP Flush on interface [22] {575A1A9E-1589-4558-BF1D-17D7D1DB6E70}
. 2015.07.24 14:04:59 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.07.24 14:04:59 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.78 MASK 255.255.255.255 192.168.0.1
. 2015.07.24 14:04:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.07.24 14:04:59 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.07.24 14:04:59 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 3
. 2015.07.24 14:04:59 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:59 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.07.24 14:04:59 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.07.24 14:04:59 - Starting Management Interface
. 2015.07.24 14:04:59 - OpenVPN > Initialization Sequence Completed
I 2015.07.24 14:04:59 - DNS of a network adapter forced (Broadcom 802.11ac Network Adapter)
I 2015.07.24 14:04:59 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.07.24 14:04:59 - Flushing DNS
I 2015.07.24 14:04:59 - Checking route
W 2015.07.24 14:05:23 - The remote name could not be resolved: 'alrai_exit.airvpn.org'
! 2015.07.24 14:05:24 - Disconnecting
. 2015.07.24 14:05:24 - Management - Send 'signal SIGTERM'
. 2015.07.24 14:05:24 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.07.24 14:05:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.07.24 14:05:24 - OpenVPN > SIGTERM received, sending exit notification to peer
Any help much appreciated!
