jimphreak
Port Forwarding Plex / pfSense
I've been trying for more than a day to forward a port for Plex in pfSense.  I've forwarded the port here on AirVPN.org but when I do a test (canyouseeme.org) it doesn't even look like packets getting to my firewall (I've done a package capture on pfSense for my AirVPN WAN interface and nothing is showing up).
My NAT rule in pfSense is as follows:
If:  VPN_WAN
Proto: TCP/UDP
Src. addr:  *
Src. ports:  *
Dest. addr:  *
Dest. ports: 12345 (example of port I chose on AirVPN.org)
NAT IP:  10.x.x.x (Plex Media Server)
NAT Ports:  32400
Can someone help point me towards what I may be doing wrong?
You need to set the port you choose in AirVPN in Plex settings, you must specify that port in the manual port settings in Plex.
pfSense rule is:
If:  VPN_WAN
Proto: TCP (Plex uses TCP) https://support.plex.tv/hc/en-us/articles/201543147-What-network-ports-do-I-need-to-allow-through-my-firewall-
Src. addr:  *
Src. ports:  *
Dest. addr:  *
Dest. ports: 32400 (this is because you already set a port forwarding rules in AirVPN server, mapping 12345 -->32400)
NAT Ports:  32400
Set Firewall accordingly.
Check my solution on Plex forum: https://forums.plex.tv/discussion/comment/885153#Comment_885153
- Router/Firewall pfSense 25.11.1 (11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz)
- Switch Cisco SG350-10 /Zyxel XGS1210-12
- AP Netgear RAX200 (Stock FW)
- NAS Synology DS1621+ (5 x 8TB WD Red)
- ISP: Fiber 1000/300 (PPPoE)
pfSense rule is:
If:  VPN_WAN
Src. addr:  *
Src. ports:  *
Dest. addr:  *
NAT Ports:  32400
I've done exactly as you stated.  Set the port to forward in AirVPN to 12345 with a local port of 32400.  I've configured the VPN_WAN interface NAT port forward in pfSense just as you stated above and a corresponding firewall rule was automatically created to match it.  However when I do a test of the port forward on AirVPN it returns "Reachable on real IP over the local port 12345."  Then if do a test of the same port 12345 on canyouseeme.org I just get a timeout so something is wrong.
