Suade12
Problem with Rukbat server
When I connect to the Rukbat server from the Netherlands, ipleak.net shows the same IP and DNS address, but from the United Kingdom. Actually some IP lookup sites show the Netherlands, and others show the UK. It's also worth noting that other Netherlands AirVPN servers aren't experiencing this, but are using failsafe amazonaws.com DNS servers (address starting with 54) from Ireland and the United States, while Rukbat is still using its normal DNS server (from Global Layer B.V. and matches my AirVPN server IP address).
Does this raise any concerns? Just making sure. Thanks.
