BarbecueGamer
How do I use AirVPN?
Hello, I just purchased AirVPN but I have absolutely no idea how to use it or how to set it up. Can someone please help me out and post a step by step guide? I would greatly appreciate it!
Well, to give a completely rudimentary course in how to get it up and running: Assuming you use windows you go to the "Enter" tab on this site while logged in, click on the windows icon and download the client from there. You then install the client. Then you find the "AirVPN" icon on your desktop and click it, then choose "connect to a recommended server" and wait for it to finish connecting. Then point your web browser to https://ipleak.net/ to confirm it's working, and it doesn't show your real info anymore.
This should get you started using it, at least. You should be safe with the default settings. I then recommend searching the forum for any specific features you wonder about with the client, if you need port forwarding to work you can look at some of my recent posts on here for example. Oh, you might want to turn on the network lock on the login screen as well.
