flat4 93 Posted ... Ref: unRaid Dockers One of the members has created a dockers for sab and it includes openvpn to connect to vpn from that applications only. My question is, if you setup this up and make your connection to AIR then sab connects to your Usenet provider but is configure to have 50 connections. Do the connections to your Usenet provider count towards the number of total connections to AIR? I think i know the answer but i just wanted verified. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
InactiveUser 188 Posted ... They don't count against the number of total AirVPN connections. Only the (one) VPN connection you establish within that container does!Within that tunnel, it's entirely up to your usenet provider how many concurrent connections you can establish. On a side note: 50 seems like overkill for most internet connections and most usenet providers, try and start with a lower value and work your way up until you don't notice any difference in speed. An unnecessarily high number of concurrent connections will likely impact your internet connection's latency. Quote Hide InactiveUser's signature Hide all signatures all of my content is released under CC-BY-SA 2.0 Share this post Link to post
flat4 93 Posted ... They don't count against the number of total AirVPN connections. Only the (one) VPN connection you establish within that container does!Within that tunnel, it's entirely up to your usenet provider how many concurrent connections you can establish. On a side note: 50 seems like overkill for most internet connections and most usenet providers, try and start with a lower value and work your way up until you don't notice any difference in speed. An unnecessarily high number of concurrent connections will likely impact your internet connection's latency.i have a small number already just throwing that out for anyone else that wanted to know. thank you for the quick reply. Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
zhang888 1067 Posted ... The usenet connections are per user account, not per actual network connections from sources and destinations. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
