D4raph 0 Posted ... Hi, I am trying to setup Airvpn on a Raspberry Pi, running the Raspbmc distribution. I've found this post and followed the following steps to configure : 1/ Install opevnpn sudo apt-get install openvpn 2/ Download the conf file *.ovpn generated on my airvpn web interface. 3/ Place it on the /etc/openvpn folder 4/ Rename it from *.ovpn to *.conf 5/ Restart Now openvpn seem running fine (checked with "service openvpn status" command and I'm even able to see a connection on the airvpn web interface status. But I'm not able to ping any site.I discovered Raspbmc comes with its own iptables rules, so to test I've deleted all of them with the "iptables --flush" command. But it'm still not able to ping anything. Any idea where to look next ?? Thanks, Quote Share this post Link to post
merlix 0 Posted ... I'm also trying to setup raspbmc with airvpn. It appears the connection is ok (no error) and also this show up in airvpn status. But still not able to access the content I was expected. It is as if raspbmc app have not picked up the vpn somehow... Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... I ran into the same problems setting up OpenVPN on a Fritz!Box router, since they are using Linux. Your problem is, you forgot to configure iptables, OpenVPN does not do it on its own. You need to MASQUERADE traffic to tun0. If I remember it right, execute this command when you are connected to AirVPN: iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
