I'm connecting to my recommended server in Canada (with a latency of ~30ms), but every speed test I do shows 15mbps (or lower). Normally on a speedtest without being connected to a VPN i'm getting 100mbps down and 40 mbps up consistently. I tried a variety of servers near my location and it's always around 15mbps. Also, I get stuttering when I stream videos.
I've tried installing different versions of TAP drivers, and increasing my buffer size as well.
Here's my log:
I 2015.06.08 21:37:56 - Session starting.
I 2015.06.08 21:37:56 - IPv6 disabled.
I 2015.06.08 21:37:56 - Checking authorization ...
! 2015.06.08 21:37:57 - Connecting to Kraz (Canada, Toronto, Ontario)
. 2015.06.08 21:37:57 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.06.08 21:37:57 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.06.08 21:37:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.06.08 21:37:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.06.08 21:37:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.08 21:37:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.08 21:37:57 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288]
. 2015.06.08 21:37:57 - OpenVPN > UDPv4 link local: [undef]
. 2015.06.08 21:37:57 - OpenVPN > UDPv4 link remote: [AF_INET]199.19.94.61:443
. 2015.06.08 21:37:57 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.94.61:443, sid=22691dba 2b88545f
. 2015.06.08 21:37:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.06.08 21:37:58 - OpenVPN > Validating certificate key usage
. 2015.06.08 21:37:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2015.06.08 21:37:58 - OpenVPN > VERIFY KU OK
. 2015.06.08 21:37:58 - OpenVPN > Validating certificate extended key usage
. 2015.06.08 21:37:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.06.08 21:37:58 - OpenVPN > VERIFY EKU OK
. 2015.06.08 21:37:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.06.08 21:38:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.06.08 21:38:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.08 21:38:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.06.08 21:38:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.06.08 21:38:01 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.06.08 21:38:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.94.61:443
. 2015.06.08 21:38:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.06.08 21:38:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.19.195 255.255.0.0'
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.06.08 21:38:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.06.08 21:38:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.06.08 21:38:03 - OpenVPN > open_tun, tt->ipv6=0
. 2015.06.08 21:38:03 - OpenVPN > TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{EDC3011F-E818-41B1-B763-6B75A6CFE2A9}.tap
. 2015.06.08 21:38:03 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.06.08 21:38:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.19.195/255.255.0.0 [sUCCEEDED]
. 2015.06.08 21:38:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.19.195/255.255.0.0 on interface {EDC3011F-E818-41B1-B763-6B75A6CFE2A9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.06.08 21:38:03 - OpenVPN > Successful ARP Flush on interface [31] {EDC3011F-E818-41B1-B763-6B75A6CFE2A9}
. 2015.06.08 21:38:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.06.08 21:38:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 199.19.94.61 MASK 255.255.255.255 192.168.1.1
. 2015.06.08 21:38:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.06.08 21:38:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.06.08 21:38:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 8
. 2015.06.08 21:38:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.06.08 21:38:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.06.08 21:38:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.06.08 21:38:08 - Starting Management Interface
. 2015.06.08 21:38:08 - OpenVPN > Initialization Sequence Completed
I 2015.06.08 21:38:08 - Flushing DNS
I 2015.06.08 21:38:08 - Checking route
I 2015.06.08 21:38:09 - Checking DNS
! 2015.06.08 21:38:09 - Connected.
. 2015.06.08 21:38:09 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.06.08 21:38:09 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Any help would be appreciated. Thanks!
Edit: Issue is resolved.
