iof9345sdfjs
Cant Connect : Loop of Connect and Disconnect
I cant connect to any server, Tried UDP, TCP, SSH. Nothing can connect
. 2015.04.27 01:15:23 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:15:23 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:15:23 - Flushing DNS
I 2015.04.27 01:15:23 - Checking route
E 2015.04.27 01:15:25 - Routing checking failed.
. 2015.04.27 01:15:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:15:25 - Disconnecting
. 2015.04.27 01:15:25 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:15:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:15:25 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:15:25 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:15:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 37.48.80.130 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:15:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:15:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:30 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:15:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:15:30 - Connection terminated.
I 2015.04.27 01:15:30 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:15:33 - Checking authorization ...
! 2015.04.27 01:15:35 - Connecting to Ceres (Netherlands, Amsterdam)
. 2015.04.27 01:15:35 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:15:35 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:15:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:15:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:15:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:15:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:15:35 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:15:35 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:15:35 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.80.130:443
. 2015.04.27 01:15:35 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.80.130:443, sid=11c38fb6 a4234a45
. 2015.04.27 01:15:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:15:36 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:15:36 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:15:36 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:15:36 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:15:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:15:36 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:15:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:15:40 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:15:40 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:15:40 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:15:40 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:15:40 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:15:40 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.80.130:443
. 2015.04.27 01:15:42 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:15:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.2.61 255.255.0.0'
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:15:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:15:43 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:15:43 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:15:43 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:15:43 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:15:43 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.2.61/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:15:43 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.2.61/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.04.27 01:15:43 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:15:48 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:15:48 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.80.130 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:15:48 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:15:48 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:15:48 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:48 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:15:48 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:15:48 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:15:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:15:48 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:48 - Starting Management Interface
. 2015.04.27 01:15:48 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:15:48 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:15:48 - Flushing DNS
I 2015.04.27 01:15:49 - Checking route
E 2015.04.27 01:15:49 - Routing checking failed.
. 2015.04.27 01:15:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:15:49 - Disconnecting
. 2015.04.27 01:15:49 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:15:49 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:15:49 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:15:49 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:15:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 37.48.80.130 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:15:54 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:15:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.04.27 01:15:54 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:15:54 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:15:54 - Connection terminated.
I 2015.04.27 01:15:54 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:15:54 - Cancel requested.
I 2015.04.27 01:15:54 - IPv6 restored.
! 2015.04.27 01:15:54 - Session terminated.
I 2015.04.27 01:16:32 - Session starting.
I 2015.04.27 01:16:33 - IPv6 disabled.
I 2015.04.27 01:16:33 - Checking authorization ...
! 2015.04.27 01:16:34 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:16:34 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:16:34 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:16:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:16:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:16:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:16:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:16:34 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:16:34 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:16:34 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:16:35 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=f5f17708 41d4a8c0
. 2015.04.27 01:16:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:16:38 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:16:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:16:38 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:16:38 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:16:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:16:38 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:16:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:16:42 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:16:42 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:16:42 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:16:42 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:16:42 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:16:42 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:16:44 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:16:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:16:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:16:44 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:16:44 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:16:44 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:16:44 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:16:44 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:16:44 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:16:44 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:16:49 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:16:49 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:16:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:16:49 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:16:49 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:16:49 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:16:49 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:16:49 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:16:49 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:16:49 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:16:49 - Starting Management Interface
. 2015.04.27 01:16:49 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:16:49 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:16:49 - Flushing DNS
I 2015.04.27 01:16:50 - Checking route
E 2015.04.27 01:16:51 - Routing checking failed.
. 2015.04.27 01:16:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:16:51 - Disconnecting
. 2015.04.27 01:16:51 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:16:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:16:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:16:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:16:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:16:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:16:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:16:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:16:56 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:16:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:16:56 - Connection terminated.
I 2015.04.27 01:16:56 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:16:59 - Checking authorization ...
! 2015.04.27 01:17:00 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:17:01 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:17:01 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:17:01 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:17:01 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:17:01 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:01 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:01 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:17:01 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:17:01 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:01 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=7c6e4326 ae06ae10
. 2015.04.27 01:17:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:17:02 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:17:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:17:02 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:17:02 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:17:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:17:02 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:17:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:17:06 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:06 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:06 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:06 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:06 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:17:06 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:08 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:17:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:17:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:17:09 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:17:09 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:17:09 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:17:09 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:17:09 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:17:09 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:17:09 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:17:14 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:17:14 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:17:14 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:14 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:17:14 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:17:14 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:17:14 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:17:14 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:14 - Starting Management Interface
. 2015.04.27 01:17:14 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:17:14 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:17:14 - Flushing DNS
I 2015.04.27 01:17:15 - Checking route
E 2015.04.27 01:17:16 - Routing checking failed.
. 2015.04.27 01:17:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:17:16 - Disconnecting
. 2015.04.27 01:17:16 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:17:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:17:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:17:16 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:17:16 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2015.04.27 01:17:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:17:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:17:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:21 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:21 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:17:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:17:21 - Connection terminated.
I 2015.04.27 01:17:21 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:17:24 - Checking authorization ...
! 2015.04.27 01:17:25 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:17:25 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:17:25 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:17:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:17:26 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:17:26 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:26 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:26 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:17:26 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:17:26 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:26 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=28b78fc7 ebc4405a
. 2015.04.27 01:17:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:17:27 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:17:27 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:17:27 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:17:27 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:17:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:17:27 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:17:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:17:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:30 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:17:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:17:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:17:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:17:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:17:33 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:17:33 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:17:33 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:17:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:17:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:17:33 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:17:38 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:17:38 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:17:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:17:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:17:38 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:38 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:17:38 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:17:38 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:17:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:17:38 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:39 - Starting Management Interface
. 2015.04.27 01:17:39 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:17:39 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:17:39 - Flushing DNS
I 2015.04.27 01:17:39 - Checking route
E 2015.04.27 01:17:40 - Routing checking failed.
. 2015.04.27 01:17:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:17:40 - Disconnecting
. 2015.04.27 01:17:40 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:17:40 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:17:40 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:17:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:17:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:17:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:17:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:17:45 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:17:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:17:46 - Connection terminated.
I 2015.04.27 01:17:46 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:17:49 - Checking authorization ...
! 2015.04.27 01:17:51 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:17:51 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:17:51 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:17:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:17:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:17:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:51 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:17:51 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:17:51 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:51 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=e6abfa14 c724a7cf
. 2015.04.27 01:17:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:17:53 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:17:53 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:17:53 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:17:53 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:17:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:17:53 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:17:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:17:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:17:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:17:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:17:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:17:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:17:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:17:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:17:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:17:59 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:17:59 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:17:59 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:17:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:17:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:17:59 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:18:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:18:04 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:18:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:18:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:18:04 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:04 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:18:04 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:18:04 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:18:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:18:04 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:04 - Starting Management Interface
. 2015.04.27 01:18:04 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:18:04 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:18:04 - Flushing DNS
I 2015.04.27 01:18:05 - Checking route
E 2015.04.27 01:18:05 - Routing checking failed.
. 2015.04.27 01:18:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:18:05 - Disconnecting
. 2015.04.27 01:18:05 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:18:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:18:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:18:05 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:18:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:18:10 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:18:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:10 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:18:10 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:18:10 - Connection terminated.
I 2015.04.27 01:18:10 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:18:13 - Checking authorization ...
! 2015.04.27 01:18:14 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:18:14 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:18:14 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:18:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:18:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:18:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:15 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:18:15 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:18:15 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:18:15 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=e0cf8cf3 7ba3e730
. 2015.04.27 01:18:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:18:16 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:18:16 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:18:16 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:18:16 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:18:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:18:16 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:18:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:18:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:18:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:18:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:20 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:18:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:18:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:18:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:18:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:18:23 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:18:23 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:18:23 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:18:23 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:18:23 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:18:23 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:18:23 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:18:28 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:18:28 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:18:28 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:18:28 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:18:28 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:28 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:18:28 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:18:28 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:18:28 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:18:28 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:28 - Starting Management Interface
. 2015.04.27 01:18:28 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:18:28 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:18:29 - Flushing DNS
I 2015.04.27 01:18:29 - Checking route
E 2015.04.27 01:18:30 - Routing checking failed.
. 2015.04.27 01:18:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:18:30 - Disconnecting
. 2015.04.27 01:18:30 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:18:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:18:30 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:18:30 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:18:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:18:36 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:18:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:36 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:36 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:18:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:18:36 - Connection terminated.
I 2015.04.27 01:18:36 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:18:39 - Checking authorization ...
! 2015.04.27 01:18:40 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:18:40 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:18:40 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:18:40 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:18:40 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:18:40 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:40 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:40 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:18:40 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:18:40 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:18:41 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=79e03f8b 1f87ad79
. 2015.04.27 01:18:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:18:42 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:18:42 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:18:42 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:18:42 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:18:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:18:42 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:18:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:18:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:18:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:18:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:18:45 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:18:45 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:18:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:18:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:18:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:18:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:18:48 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:18:48 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:18:48 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:18:48 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:18:48 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:18:48 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:18:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:18:53 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:18:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:18:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:18:53 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:54 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:18:54 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:18:54 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:18:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:18:54 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:18:54 - Starting Management Interface
. 2015.04.27 01:18:54 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:18:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:18:54 - Flushing DNS
I 2015.04.27 01:18:54 - Checking route
E 2015.04.27 01:18:55 - Routing checking failed.
. 2015.04.27 01:18:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:18:55 - Disconnecting
. 2015.04.27 01:18:55 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:18:55 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:18:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:18:55 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:19:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:19:00 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:19:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:00 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:00 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:19:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:19:00 - Connection terminated.
I 2015.04.27 01:19:01 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:19:04 - Checking authorization ...
! 2015.04.27 01:19:05 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.04.27 01:19:05 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:19:05 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:19:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:19:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:19:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:19:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:19:05 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:19:05 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.27 01:19:05 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.140.100:2018
. 2015.04.27 01:19:06 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.140.100:2018, sid=00bdc47f 1991c998
. 2015.04.27 01:19:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:19:07 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:19:07 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:19:07 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:19:07 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:19:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:19:07 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:19:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:19:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:19:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:19:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:19:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:19:10 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:19:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.140.100:2018
. 2015.04.27 01:19:13 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:19:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.30.0.1,comp-lzo no,route-gateway 10.30.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.30.0.20 255.255.0.0'
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:19:13 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:19:13 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:19:13 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:19:13 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:19:13 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:19:13 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.0.0/10.30.0.20/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:19:13 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.0.20/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.30.255.254, lease-time: 31536000]
. 2015.04.27 01:19:13 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:19:18 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.04.27 01:19:18 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:19:18 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:19:18 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:19:18 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:19 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:19:19 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:19:19 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:19:19 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:19:19 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:19 - Starting Management Interface
. 2015.04.27 01:19:19 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:19:19 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:19:19 - Flushing DNS
I 2015.04.27 01:19:19 - Checking route
E 2015.04.27 01:19:20 - Routing checking failed.
. 2015.04.27 01:19:20 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:19:20 - Disconnecting
. 2015.04.27 01:19:20 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:19:20 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:19:20 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2015.04.27 01:19:20 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:19:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.04.27 01:19:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.140.100 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:19:25 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:19:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:25 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.0.1
. 2015.04.27 01:19:25 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:19:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.04.27 01:19:25 - Connection terminated.
I 2015.04.27 01:19:25 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:19:25 - Cancel requested.
I 2015.04.27 01:19:25 - IPv6 restored.
! 2015.04.27 01:19:25 - Session terminated.
I 2015.04.27 01:35:59 - Session starting.
I 2015.04.27 01:35:59 - IPv6 disabled.
I 2015.04.27 01:35:59 - Checking authorization ...
! 2015.04.27 01:36:00 - Connecting to Corvi (Netherlands, Amsterdam)
. 2015.04.27 01:36:00 - SSH > Looking up host "95.211.138.28"
. 2015.04.27 01:36:00 - SSH > Connecting to 95.211.138.28 port 53
. 2015.04.27 01:36:00 - SSH > Server version: SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u2
. 2015.04.27 01:36:00 - SSH > Using SSH protocol version 2
. 2015.04.27 01:36:00 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.63
. 2015.04.27 01:36:01 - SSH > Doing Diffie-Hellman group exchange
. 2015.04.27 01:36:01 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2015.04.27 01:36:02 - SSH > The server's host key is not cached in the registry. You
. 2015.04.27 01:36:02 - SSH > have no guarantee that the server is the computer you
. 2015.04.27 01:36:02 - SSH > think it is.
. 2015.04.27 01:36:02 - SSH > The server's rsa2 key fingerprint is:
. 2015.04.27 01:36:02 - SSH > ssh-rsa 2048 8c:18:c4:0c:25:d8:74:b9:cc:4d:7a:eb:74:f6:9e:21
. 2015.04.27 01:36:02 - SSH > If you trust this host, enter "y" to add the key to
. 2015.04.27 01:36:02 - SSH > PuTTY's cache and carry on connecting.
. 2015.04.27 01:36:02 - SSH > If you want to carry on connecting just once, without
. 2015.04.27 01:36:02 - SSH > adding the key to the cache, enter "n".
. 2015.04.27 01:36:02 - SSH > If you do not trust this host, press Return to abandon the
. 2015.04.27 01:36:02 - SSH > connection.
. 2015.04.27 01:36:02 - SSH > Store key in cache? (y/n) Host key fingerprint is:
. 2015.04.27 01:36:02 - SSH > Initialised AES-256 SDCTR client->server encryption
. 2015.04.27 01:36:02 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2015.04.27 01:36:02 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2015.04.27 01:36:02 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2015.04.27 01:36:03 - SSH > Reading private key file "C:\Users\efgergerlgjhuh\AppData\Local\AirVPN\f3709004c5cf63681f0737d3e68805d6f176cb0c00573d56478565b7df92b042.tmp.ppk"
. 2015.04.27 01:36:03 - SSH > Using username "sshtunnel".
. 2015.04.27 01:36:03 - SSH > Offered public key
. 2015.04.27 01:36:03 - SSH > Offer of public key accepted
. 2015.04.27 01:36:03 - SSH > Authenticating with public key ""
. 2015.04.27 01:36:03 - SSH > Sent public key signature
. 2015.04.27 01:36:04 - SSH > Access granted
. 2015.04.27 01:36:04 - SSH > Local port 57706 forwarding to 127.0.0.1:2018
. 2015.04.27 01:36:04 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:36:04 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:36:04 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:36:04 - SSH > Remote debug message: Pty allocation disabled.
. 2015.04.27 01:36:04 - SSH > Remote debug message: X11 forwarding disabled.
. 2015.04.27 01:36:04 - SSH > Remote debug message: Forced command.
. 2015.04.27 01:36:04 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:36:04 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:04 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:04 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:36:04 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:57706 [nonblock]
. 2015.04.27 01:36:04 - SSH > Opening connection to 127.0.0.1:2018 for forwarding
. 2015.04.27 01:36:04 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:57706
. 2015.04.27 01:36:04 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.04.27 01:36:04 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:57706
. 2015.04.27 01:36:04 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:57706, sid=ac78b4d0 71fdcb48
. 2015.04.27 01:36:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:36:08 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:36:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:36:08 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:36:08 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:36:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:36:08 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:36:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:36:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:36:16 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:36:16 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:16 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:36:16 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:57706
. 2015.04.27 01:36:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:36:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.192 255.255.0.0'
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:36:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:36:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:36:19 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:36:20 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:36:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:36:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.192/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:36:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.192/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2015.04.27 01:36:20 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:36:24 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.04.27 01:36:24 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:36:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:36:24 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:24 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:36:24 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:36:24 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:36:24 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:36:24 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:24 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:24 - Starting Management Interface
. 2015.04.27 01:36:24 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:36:24 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:36:24 - Flushing DNS
I 2015.04.27 01:36:25 - Checking route
E 2015.04.27 01:36:26 - Routing checking failed.
. 2015.04.27 01:36:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:36:26 - Disconnecting
. 2015.04.27 01:36:26 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:36:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:36:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:36:26 - SSH > Forwarded port closed due to local error
. 2015.04.27 01:36:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:36:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:26 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:36:26 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2015.04.27 01:36:26 - Connection terminated.
I 2015.04.27 01:36:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:36:29 - Checking authorization ...
! 2015.04.27 01:36:30 - Connecting to Corvi (Netherlands, Amsterdam)
. 2015.04.27 01:36:30 - SSH > Looking up host "95.211.138.28"
. 2015.04.27 01:36:30 - SSH > Connecting to 95.211.138.28 port 53
. 2015.04.27 01:36:31 - SSH > Server version: SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u2
. 2015.04.27 01:36:31 - SSH > Using SSH protocol version 2
. 2015.04.27 01:36:31 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.63
. 2015.04.27 01:36:31 - SSH > Doing Diffie-Hellman group exchange
. 2015.04.27 01:36:32 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2015.04.27 01:36:33 - SSH > Host key fingerprint is:
. 2015.04.27 01:36:33 - SSH > ssh-rsa 2048 8c:18:c4:0c:25:d8:74:b9:cc:4d:7a:eb:74:f6:9e:21
. 2015.04.27 01:36:33 - SSH > Initialised AES-256 SDCTR client->server encryption
. 2015.04.27 01:36:33 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2015.04.27 01:36:33 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2015.04.27 01:36:33 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2015.04.27 01:36:33 - SSH > Reading private key file "C:\Users\efgergerlgjhuh\AppData\Local\AirVPN\8b19930da9ae6951b166bd7ff54be22d8d72610eb0128362d12b3ec4cafec12b.tmp.ppk"
. 2015.04.27 01:36:33 - SSH > Using username "sshtunnel".
. 2015.04.27 01:36:33 - SSH > Offered public key
. 2015.04.27 01:36:34 - SSH > Offer of public key accepted
. 2015.04.27 01:36:34 - SSH > Authenticating with public key ""
. 2015.04.27 01:36:34 - SSH > Sent public key signature
. 2015.04.27 01:36:34 - SSH > Access granted
. 2015.04.27 01:36:34 - SSH > Local port 22617 forwarding to 127.0.0.1:2018
. 2015.04.27 01:36:34 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:36:34 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:36:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:36:34 - SSH > Remote debug message: Pty allocation disabled.
. 2015.04.27 01:36:34 - SSH > Remote debug message: X11 forwarding disabled.
. 2015.04.27 01:36:34 - SSH > Remote debug message: Forced command.
. 2015.04.27 01:36:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:36:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:34 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:36:34 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:22617 [nonblock]
. 2015.04.27 01:36:34 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:22617
. 2015.04.27 01:36:34 - SSH > Opening connection to 127.0.0.1:2018 for forwarding
. 2015.04.27 01:36:34 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.04.27 01:36:34 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:22617
. 2015.04.27 01:36:35 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:22617, sid=5e77bb96 d3dee4b7
. 2015.04.27 01:36:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:36:38 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:36:38 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:36:38 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:36:38 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:36:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:36:38 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:36:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:36:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:36:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:36:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:36:47 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:36:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:22617
. 2015.04.27 01:36:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:36:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.192 255.255.0.0'
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:36:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:36:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:36:50 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:36:50 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:36:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:36:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.192/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:36:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.192/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2015.04.27 01:36:50 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:36:55 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.04.27 01:36:55 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:36:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:36:55 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:55 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:36:55 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:36:55 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:36:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:36:55 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:55 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:55 - Starting Management Interface
. 2015.04.27 01:36:55 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:36:55 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:36:55 - Flushing DNS
I 2015.04.27 01:36:56 - Checking route
E 2015.04.27 01:36:56 - Routing checking failed.
. 2015.04.27 01:36:56 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:36:56 - Disconnecting
. 2015.04.27 01:36:56 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:36:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:36:57 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:36:57 - SSH > Forwarded port closed due to local error
. 2015.04.27 01:36:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:36:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:36:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:36:57 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:36:57 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2015.04.27 01:36:57 - Connection terminated.
I 2015.04.27 01:36:57 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:37:00 - Checking authorization ...
! 2015.04.27 01:37:01 - Connecting to Corvi (Netherlands, Amsterdam)
. 2015.04.27 01:37:01 - SSH > Looking up host "95.211.138.28"
. 2015.04.27 01:37:01 - SSH > Connecting to 95.211.138.28 port 53
. 2015.04.27 01:37:02 - SSH > Server version: SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u2
. 2015.04.27 01:37:02 - SSH > Using SSH protocol version 2
. 2015.04.27 01:37:02 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.63
. 2015.04.27 01:37:02 - SSH > Doing Diffie-Hellman group exchange
. 2015.04.27 01:37:02 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2015.04.27 01:37:03 - SSH > Host key fingerprint is:
. 2015.04.27 01:37:03 - SSH > ssh-rsa 2048 8c:18:c4:0c:25:d8:74:b9:cc:4d:7a:eb:74:f6:9e:21
. 2015.04.27 01:37:03 - SSH > Initialised AES-256 SDCTR client->server encryption
. 2015.04.27 01:37:03 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2015.04.27 01:37:03 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2015.04.27 01:37:03 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2015.04.27 01:37:04 - SSH > Reading private key file "C:\Users\efgergerlgjhuh\AppData\Local\AirVPN\64187dd742d130c6e48129982f7ede9612842baffe640dc6355467b5756407e1.tmp.ppk"
. 2015.04.27 01:37:04 - SSH > Using username "sshtunnel".
. 2015.04.27 01:37:04 - SSH > Offered public key
. 2015.04.27 01:37:04 - SSH > Offer of public key accepted
. 2015.04.27 01:37:05 - SSH > Authenticating with public key ""
. 2015.04.27 01:37:05 - SSH > Sent public key signature
. 2015.04.27 01:37:05 - SSH > Access granted
. 2015.04.27 01:37:05 - SSH > Local port 29062 forwarding to 127.0.0.1:2018
. 2015.04.27 01:37:05 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.27 01:37:05 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.27 01:37:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.27 01:37:05 - SSH > Remote debug message: Pty allocation disabled.
. 2015.04.27 01:37:05 - SSH > Remote debug message: X11 forwarding disabled.
. 2015.04.27 01:37:05 - SSH > Remote debug message: Forced command.
. 2015.04.27 01:37:05 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.27 01:37:05 - SSH > Opening connection to 127.0.0.1:2018 for forwarding
. 2015.04.27 01:37:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:37:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:37:05 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.27 01:37:05 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:29062 [nonblock]
. 2015.04.27 01:37:05 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:29062
. 2015.04.27 01:37:05 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.04.27 01:37:05 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:29062
. 2015.04.27 01:37:06 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:29062, sid=de737d37 ec215a27
. 2015.04.27 01:37:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.27 01:37:09 - OpenVPN > Validating certificate key usage
. 2015.04.27 01:37:09 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.27 01:37:09 - OpenVPN > VERIFY KU OK
. 2015.04.27 01:37:09 - OpenVPN > Validating certificate extended key usage
. 2015.04.27 01:37:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.27 01:37:09 - OpenVPN > VERIFY EKU OK
. 2015.04.27 01:37:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.27 01:37:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:37:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:37:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.27 01:37:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.27 01:37:17 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.27 01:37:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:29062
. 2015.04.27 01:37:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.27 01:37:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.0.192 255.255.0.0'
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.27 01:37:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.27 01:37:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.04.27 01:37:20 - OpenVPN > open_tun, tt->ipv6=0
. 2015.04.27 01:37:20 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}.tap
. 2015.04.27 01:37:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.04.27 01:37:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.0.192/255.255.0.0 [sUCCEEDED]
. 2015.04.27 01:37:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.0.192/255.255.0.0 on interface {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2015.04.27 01:37:20 - OpenVPN > Successful ARP Flush on interface [20] {67B3C5E8-1CF9-4ED6-841A-DFF2CE33E234}
. 2015.04.27 01:37:25 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.04.27 01:37:25 - OpenVPN > C:\Windows\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:37:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:37:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:37:25 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:37:26 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: One or more arguments are not correct.   [status=160 if_index=20]
. 2015.04.27 01:37:26 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.04.27 01:37:26 - OpenVPN > Route addition fallback to route.exe
. 2015.04.27 01:37:26 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.04.27 01:37:26 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:37:26 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:37:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
. 2015.04.27 01:37:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.04.27 01:37:26 - Starting Management Interface
. 2015.04.27 01:37:26 - OpenVPN > Initialization Sequence Completed
I 2015.04.27 01:37:26 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.04.27 01:37:26 - Flushing DNS
I 2015.04.27 01:37:26 - Checking route
E 2015.04.27 01:37:27 - Routing checking failed.
. 2015.04.27 01:37:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2015.04.27 01:37:27 - Disconnecting
. 2015.04.27 01:37:27 - Management - Send 'signal SIGTERM'
. 2015.04.27 01:37:27 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.04.27 01:37:27 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.04.27 01:37:27 - SSH > Forwarded port closed due to local error
. 2015.04.27 01:37:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.138.28 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:37:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.04.27 01:37:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 39.34.173.122
. 2015.04.27 01:37:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:37:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.04.27 01:37:27 - OpenVPN > Closing TUN/TAP interface
. 2015.04.27 01:37:27 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2015.04.27 01:37:27 - Connection terminated.
I 2015.04.27 01:37:27 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2015.04.27 01:37:27 - Cancel requested.
I 2015.04.27 01:37:27 - IPv6 restored.
! 2015.04.27 01:37:28 - Session terminated.
Have you tried running as administrator might be a installation of the driver issue.
im having the same damn issue. the this is, it was working flawlessly for a week or two. then i couldn't connect to any server. but i am able to connect to a server on another computer. i wish i had some help on this. I'm not finding an answer on the forums.
I get this same log message every time i try to connect to something:
. 2015.05.29 23:25:12 - OpenVPN > Closing TUN/TAP interface
. 2015.05.29 23:25:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.05.29 23:25:12 - Connection terminated.
I 2015.05.29 23:25:12 - DNS of a network adapter restored to original settings (Bluetooth DUN)
I 2015.05.29 23:25:12 - DNS of a network adapter restored to original settings (Ethernet)
I 2015.05.29 23:25:12 - DNS of a network adapter restored to original settings (FireWire)
I 2015.05.29 23:25:12 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2015.05.29 23:25:12 - DNS of a network adapter restored to original settings (iPhone USB)
I 2015.05.29 23:25:13 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2015.05.29 23:25:13 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2015.05.29 23:25:15 - Cancel requested.
! 2015.05.29 23:25:15 - Session terminated.
and it just restarts the connection
