X22Y55Zbc
Don't know if this is problem or not
Hello all,
Just updated to Eddie 2.8.8
connected and everything APPEARS to be ok, i think.
Ipleak shows good through firefox
dnsleak extended check is 6x6 green
so why am i posting this ? lol
i saw this line in the logs and as i'm a lazy dinosaur and thus am pretty new
to this new interface i don't know how normal or common it is to see
"E 2015.04.17 20:45:30 - OpenVPN Driver - Not available"  in my logs.
all the online checkers say my ip is what i want it to be, no leaks..
so is this ok ?
or am i screwed in a way i can't see ?
Windows 7 64 bit
Thanks.
ohh  another really stupid question from someone who usually is not this dumb..
in the stats tab it says "real ip detected"  is that just because the program is gonna know
because its the program making this possible or is it some other checker i'm unaware of and i'm leaking some how ?
thanks & please excuse my stupidity.
I believed that bux was already fixed. However, you could go to Network Connections on Control Panel on windows and check if a "TAP-Windows adapter V9" device is enabled and connected (Right Click - Status)
You can check your leaks on http://ipleak.net website
