Floswen
Air Vpn won't connect
Hey guys,
I have a problem with Air Vpn, it was working fine last month, then I updated to Win 10 preview, and now It wont connect anymore, this is my log :
. 2015.04.08 18:19:48 - Updating systems & servers data ...
. 2015.04.08 18:19:49 - Systems & servers data update completed
I 2015.04.08 18:20:02 - Session starting.
I 2015.04.08 18:20:02 - Installing tunnel driver
I 2015.04.08 18:20:02 - Checking authorization ...
! 2015.04.08 18:20:03 - Connecting to Botein (Netherlands, Amsterdam)
. 2015.04.08 18:20:03 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.04.08 18:20:03 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.04.08 18:20:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.04.08 18:20:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.04.08 18:20:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 18:20:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 18:20:03 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2015.04.08 18:20:03 - OpenVPN > UDPv4 link local: [undef]
. 2015.04.08 18:20:03 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.74.15:443
. 2015.04.08 18:20:03 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.74.15:443, sid=fcff753e 0c904c5c
. 2015.04.08 18:20:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.04.08 18:20:03 - OpenVPN > Validating certificate key usage
. 2015.04.08 18:20:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.04.08 18:20:03 - OpenVPN > VERIFY KU OK
. 2015.04.08 18:20:03 - OpenVPN > Validating certificate extended key usage
. 2015.04.08 18:20:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.04.08 18:20:03 - OpenVPN > VERIFY EKU OK
. 2015.04.08 18:20:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.04.08 18:20:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.08 18:20:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 18:20:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.04.08 18:20:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.04.08 18:20:04 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.04.08 18:20:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.74.15:443
. 2015.04.08 18:20:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.04.08 18:20:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.244 255.255.0.0'
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.04.08 18:20:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.04.08 18:20:06 - OpenVPN > There are no TAP-Windows adapters on this system.  You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter.
. 2015.04.08 18:20:06 - OpenVPN > Exiting due to fatal error
! 2015.04.08 18:20:06 - Disconnecting
. 2015.04.08 18:20:06 - Connection terminated.
I suppose that I have a problem with Tap-Windows adapter, but I dont know what to do. Could someone help me?
Cheers!
You don't know what to do when you use a Windows beta? No offense, mate, but why do you think is it called a preview? It's not safe for daily use, several things are not optimized, software and especially drivers are very likely not running,.. that said, TAP won't work correctly as well.
Raaah guys, dont flame, me I was in a hurry
Anyway, I know I run a preview, and it still unstable in some ways, but it dont hurt to try to understand how things work
Thanks for your answers anyway.
