MarleyMouse
Stopping and starting
I have just reinstalled Windows 7 and set up AirVPN I really like the new interface and the network lock is great.
As soon as I connect Im getting good speeds up to 3Mb however after a minute or so the connection drops off and slowly disappears altogether.
here are my logs is there anything I can do? I am not technical at all so I find it difficult to follow some of the steps I have read so far.
thanks
B
. 2015.03.26 12:25:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:25:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.118.130 10.4.118.129'
. 2015.03.26 12:25:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:25:30 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:25:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:25:30 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:25:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:25:30 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:25:30 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:25:31 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:25:31 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:25:31 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.118.130/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.118.129, lease-time: 31536000]
. 2015.03.26 12:25:31 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:25:35 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 12:25:35 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.186.93 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:25:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.03.26 12:25:35 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 12:25:35 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 12:25:35 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.03.26 12:25:35 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 12:25:35 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.118.129
. 2015.03.26 12:25:35 - Starting Management Interface
. 2015.03.26 12:25:35 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:25:35 - Flushing DNS
I 2015.03.26 12:25:35 - Checking route
! 2015.03.26 12:25:38 - Connected.
. 2015.03.26 12:25:38 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:25:38 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:30:33 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:30:33 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:30:33 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:30:33 - Disconnecting
. 2015.03.26 12:30:33 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:30:33 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:30:33 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:30:33 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:30:33 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:30:33 - Connection terminated.
I 2015.03.26 12:31:15 - Checking authorization ...
. 2015.03.26 12:31:21 - Checking authorization ..., 2° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:31:21 - Checking authorization ..., 4° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:31:21 - Checking authorization ..., 5° try failed (Length of the data to decrypt is invalid.)
W 2015.03.26 12:31:21 - Authorization check failed, continue anyway ({1])
! 2015.03.26 12:31:21 - Connecting to Haedi (Netherlands, Amsterdam)
! 2015.03.26 12:31:58 - Disconnecting
. 2015.03.26 12:31:58 - Connection terminated.
I 2015.03.26 12:32:01 - Checking authorization ...
. 2015.03.26 12:32:04 - Checking authorization ..., 2° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:32:04 - Checking authorization ..., 4° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:32:04 - Checking authorization ..., 5° try failed (Length of the data to decrypt is invalid.)
W 2015.03.26 12:32:04 - Authorization check failed, continue anyway ({1])
! 2015.03.26 12:32:04 - Connecting to Haedi (Netherlands, Amsterdam)
. 2015.03.26 12:32:15 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:32:15 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:32:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:32:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:32:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:32:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:32:15 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:32:15 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:32:15 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.10:443
. 2015.03.26 12:32:15 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.03.26 12:32:15 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.26 12:32:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.03.26 12:32:16 - Disconnecting
. 2015.03.26 12:32:16 - Connection terminated.
I 2015.03.26 12:32:19 - Checking authorization ...
. 2015.03.26 12:32:19 - Checking authorization ..., 2° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:32:19 - Checking authorization ..., 4° try failed (Length of the data to decrypt is invalid.)
. 2015.03.26 12:32:19 - Checking authorization ..., 5° try failed (Length of the data to decrypt is invalid.)
W 2015.03.26 12:32:19 - Authorization check failed, continue anyway ({1])
! 2015.03.26 12:32:19 - Connecting to Haedi (Netherlands, Amsterdam)
. 2015.03.26 12:32:19 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:32:19 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:32:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:32:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:32:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:32:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:32:19 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:32:19 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:32:19 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.10:443
. 2015.03.26 12:32:51 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2015.03.26 12:32:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.26 12:32:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2015.03.26 12:32:56 - Disconnecting
. 2015.03.26 12:32:56 - Connection terminated.
I 2015.03.26 12:32:59 - Checking authorization ...
! 2015.03.26 12:33:00 - Connecting to Haedi (Netherlands, Amsterdam)
. 2015.03.26 12:33:00 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:33:00 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:33:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:33:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:33:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:33:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:33:00 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:33:00 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:33:00 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.10:443
. 2015.03.26 12:33:00 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.10:443, sid=4296d120 4351823c
. 2015.03.26 12:33:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:33:00 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:33:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:33:00 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:33:00 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:33:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:33:00 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:33:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:33:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:33:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:33:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:33:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:33:01 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:33:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.10:443
. 2015.03.26 12:33:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:33:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.199 255.255.0.0'
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.03.26 12:33:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:33:04 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:33:04 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:33:04 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:33:04 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:33:04 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.199/255.255.0.0 [sUCCEEDED]
. 2015.03.26 12:33:04 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.199/255.255.0.0 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.03.26 12:33:04 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:33:09 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.03.26 12:33:09 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.81.10 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:33:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.03.26 12:33:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 12:33:09 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.03.26 12:33:09 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 12:33:09 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 12:33:09 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 12:33:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 12:33:09 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 12:33:09 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 12:33:09 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 12:33:09 - Starting Management Interface
. 2015.03.26 12:33:09 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:33:09 - Flushing DNS
I 2015.03.26 12:33:09 - Checking route
! 2015.03.26 12:33:09 - Connected.
. 2015.03.26 12:33:09 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:33:09 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:37:18 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:37:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:37:18 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:37:18 - Disconnecting
. 2015.03.26 12:37:18 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:37:18 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:37:18 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:37:18 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:37:18 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:37:18 - Connection terminated.
I 2015.03.26 12:37:21 - Checking authorization ...
! 2015.03.26 12:37:21 - Connecting to Ophiuchi (Netherlands, Amsterdam)
. 2015.03.26 12:37:21 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:37:21 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:37:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:37:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:37:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:37:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:37:22 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:37:22 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:37:22 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.186.65:443
. 2015.03.26 12:37:22 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.186.65:443, sid=d191daff 067c1573
. 2015.03.26 12:37:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:37:22 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:37:22 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:37:22 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:37:22 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:37:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:37:22 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:37:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:37:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:37:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:37:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:37:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:37:26 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:37:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.186.65:443
. 2015.03.26 12:37:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:37:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.214.42 10.4.214.41'
. 2015.03.26 12:37:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:37:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:37:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:37:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:37:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:37:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:37:28 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:37:28 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:37:28 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:37:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.214.42/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.214.41, lease-time: 31536000]
. 2015.03.26 12:37:28 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:37:33 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 12:37:33 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.186.65 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:37:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.03.26 12:37:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 12:37:33 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.214.41
. 2015.03.26 12:37:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.03.26 12:37:33 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.214.41
. 2015.03.26 12:37:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2015.03.26 12:37:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 12:37:34 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.214.41
. 2015.03.26 12:37:34 - Starting Management Interface
. 2015.03.26 12:37:34 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:37:34 - Flushing DNS
I 2015.03.26 12:37:34 - Checking route
! 2015.03.26 12:37:34 - Connected.
. 2015.03.26 12:37:34 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:37:35 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:41:48 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:41:48 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:41:48 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:41:48 - Disconnecting
. 2015.03.26 12:41:48 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:41:48 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:41:48 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:41:48 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:41:48 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:41:48 - Connection terminated.
I 2015.03.26 12:41:51 - Checking authorization ...
! 2015.03.26 12:41:51 - Connecting to Botein (Netherlands, Amsterdam)
. 2015.03.26 12:41:52 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:41:52 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:41:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:41:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:41:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:41:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:41:52 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:41:52 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:41:52 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.74.15:443
. 2015.03.26 12:41:52 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.74.15:443, sid=71e63083 55474cdb
. 2015.03.26 12:41:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:41:52 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:41:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:41:52 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:41:52 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:41:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:41:52 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:41:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:41:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:41:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:41:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:41:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:41:53 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:41:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.74.15:443
. 2015.03.26 12:41:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:41:56 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.42 255.255.0.0'
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.03.26 12:41:56 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:41:56 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:41:56 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:41:56 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:41:56 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:41:56 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.42/255.255.0.0 [sUCCEEDED]
. 2015.03.26 12:41:56 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.42/255.255.0.0 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.03.26 12:41:56 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:42:01 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.03.26 12:42:01 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.74.15 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:42:01 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.03.26 12:42:01 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 12:42:01 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.03.26 12:42:01 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 12:42:01 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 12:42:01 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 12:42:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 12:42:01 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 12:42:01 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 12:42:01 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 12:42:01 - Starting Management Interface
. 2015.03.26 12:42:01 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:42:01 - Flushing DNS
I 2015.03.26 12:42:01 - Checking route
! 2015.03.26 12:42:01 - Connected.
. 2015.03.26 12:42:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:42:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:46:29 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:46:29 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:46:29 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:46:29 - Disconnecting
. 2015.03.26 12:46:29 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:46:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:46:29 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:46:29 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:46:29 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:46:29 - Connection terminated.
I 2015.03.26 12:46:34 - Checking authorization ...
! 2015.03.26 12:46:35 - Connecting to Propus (Netherlands, Amsterdam)
. 2015.03.26 12:46:35 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:46:35 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:46:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:46:35 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:46:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:46:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:46:35 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:46:35 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:46:35 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.8:443
. 2015.03.26 12:46:35 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.8:443, sid=7db3ee23 1a6f1272
. 2015.03.26 12:46:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:46:36 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:46:36 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:46:36 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:46:36 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:46:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:46:36 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:46:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:46:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:46:39 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:46:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:46:39 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:46:39 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:46:39 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.8:443
. 2015.03.26 12:46:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:46:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.171.126 10.4.171.125'
. 2015.03.26 12:46:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:46:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:46:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:46:41 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:46:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:46:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:46:41 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:46:42 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:46:42 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:46:42 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.171.126/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.171.125, lease-time: 31536000]
. 2015.03.26 12:46:42 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:46:46 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 12:46:46 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.81.8 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:46:46 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 12:46:46 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 12:46:46 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 12:46:46 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 12:46:46 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.171.125
. 2015.03.26 12:46:46 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 12:46:46 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.171.125
. 2015.03.26 12:46:46 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.171.125
. 2015.03.26 12:46:46 - Starting Management Interface
. 2015.03.26 12:46:46 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:46:46 - Flushing DNS
I 2015.03.26 12:46:46 - Checking route
! 2015.03.26 12:46:46 - Connected.
. 2015.03.26 12:46:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:46:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6093 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6094 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6095 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6097 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6098 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6099 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6100 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6101 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6102 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6103 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6104 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6105 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6106 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6107 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6108 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6109 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6110 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6112 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6113 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6114 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6115 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6117 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6116 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6118 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6119 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6120 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6121 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6122 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6124 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6125 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6126 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6128 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:46:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #6129 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23830 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23831 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23833 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23834 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23835 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23836 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23837 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23838 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23839 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23840 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23841 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23842 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23843 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23844 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23845 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23846 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23847 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23848 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23849 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23850 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23851 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23852 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23853 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23854 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23855 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23856 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23857 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23858 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23859 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23860 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23861 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23862 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23863 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23864 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23865 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23866 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23867 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23868 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23870 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23871 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23875 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23876 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23879 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23882 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:09 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23914 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31853 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31854 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31855 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31856 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31857 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:47:16 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #31858 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:50:44 - Updating systems & servers data ...
. 2015.03.26 12:50:56 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:50:56 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:50:56 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:50:56 - Disconnecting
. 2015.03.26 12:50:56 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:50:56 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:50:56 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:50:56 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:50:56 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:50:56 - Connection terminated.
I 2015.03.26 12:50:59 - Checking authorization ...
! 2015.03.26 12:50:59 - Connecting to Corvi (Netherlands, Amsterdam)
. 2015.03.26 12:50:59 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:50:59 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:50:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:51:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:51:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:51:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:51:00 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:51:00 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:51:00 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.138.19:443
. 2015.03.26 12:51:00 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.138.19:443, sid=50a6629c a9d7ab7e
. 2015.03.26 12:51:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:51:00 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:51:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:51:00 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:51:00 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:51:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:51:00 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:51:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:51:03 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:51:03 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:51:03 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:51:03 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:51:03 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:51:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.138.19:443
. 2015.03.26 12:51:05 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.03.26 12:51:05 - Systems & servers data update completed
. 2015.03.26 12:51:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:51:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.49.62 10.4.49.61'
. 2015.03.26 12:51:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:51:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:51:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:51:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:51:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:51:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:51:06 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:51:06 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:51:06 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:51:06 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.49.62/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.49.61, lease-time: 31536000]
. 2015.03.26 12:51:06 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:51:11 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 12:51:11 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.138.19 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:51:11 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 12:51:11 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 12:51:11 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 12:51:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 12:51:11 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.49.61
. 2015.03.26 12:51:11 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 12:51:11 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.49.61
. 2015.03.26 12:51:11 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.49.61
. 2015.03.26 12:51:11 - Starting Management Interface
. 2015.03.26 12:51:11 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:51:11 - Flushing DNS
I 2015.03.26 12:51:11 - Checking route
! 2015.03.26 12:51:11 - Connected.
. 2015.03.26 12:51:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:51:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14236 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14237 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14238 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14239 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14241 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14242 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14243 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14244 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14245 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14246 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14247 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14248 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14249 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14250 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14251 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14252 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14253 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14254 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14255 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14256 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14258 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14259 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14260 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14261 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14262 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14263 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14264 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14265 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14266 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14267 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14268 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14270 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14271 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14272 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14273 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14274 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14275 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14276 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14277 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14278 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14279 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14281 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14288 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34861 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34862 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34863 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34864 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34865 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34866 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34867 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34868 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34869 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34870 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34871 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34872 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34873 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34874 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34875 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34876 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34877 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34879 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34878 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34880 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34882 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34883 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34884 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34885 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34886 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34887 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34888 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34889 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34891 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34890 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34894 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34895 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34896 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34897 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34898 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34900 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34901 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #34904 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61967 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61968 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61969 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61970 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61971 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61972 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61973 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61974 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61975 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61977 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61976 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61978 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61979 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61982 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61983 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61984 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61985 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61986 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61987 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61988 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61989 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61991 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61992 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61993 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61994 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61995 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61996 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61990 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61997 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61998 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #61999 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62000 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62002 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62003 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62001 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62004 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62005 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62006 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62007 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62008 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62009 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62010 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62011 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62012 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62013 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62014 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62016 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62015 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62017 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62018 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62019 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62021 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62020 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62022 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62023 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62024 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62025 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62026 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62027 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62028 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62068 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62069 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62070 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62071 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62072 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62073 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62074 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62075 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62076 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62077 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62079 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62080 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:51:53 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #62081 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:25 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:55:25 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:55:25 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:55:25 - Disconnecting
. 2015.03.26 12:55:25 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:55:25 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:55:25 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:55:25 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:55:25 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:55:25 - Connection terminated.
I 2015.03.26 12:55:28 - Checking authorization ...
! 2015.03.26 12:55:28 - Connecting to Lyncis (Netherlands, Amsterdam)
. 2015.03.26 12:55:28 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:55:28 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:55:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:55:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:55:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:55:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:55:29 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:55:29 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:55:29 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.149.200:443
. 2015.03.26 12:55:29 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.149.200:443, sid=85374a6d f6220237
. 2015.03.26 12:55:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:55:29 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:55:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:55:29 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:55:29 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:55:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:55:29 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:55:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:55:34 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:55:34 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:55:34 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:55:34 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:55:34 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:55:34 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.149.200:443
. 2015.03.26 12:55:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:55:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.1.10 10.4.1.9'
. 2015.03.26 12:55:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:55:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:55:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:55:36 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:55:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:55:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:55:36 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 12:55:36 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 12:55:36 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 12:55:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.10/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.1.9, lease-time: 31536000]
. 2015.03.26 12:55:36 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 12:55:41 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 12:55:41 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.149.200 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 12:55:41 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 12:55:41 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 12:55:41 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 12:55:41 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 12:55:41 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.1.9
. 2015.03.26 12:55:41 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 12:55:41 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.1.9
. 2015.03.26 12:55:41 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.1.9
. 2015.03.26 12:55:41 - Starting Management Interface
. 2015.03.26 12:55:41 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 12:55:41 - Flushing DNS
I 2015.03.26 12:55:41 - Checking route
! 2015.03.26 12:55:41 - Connected.
. 2015.03.26 12:55:41 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 12:55:41 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3716 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3717 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3719 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3720 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3721 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3722 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3725 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3724 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3727 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3728 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3730 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3732 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3734 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3733 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3735 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3736 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3737 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3738 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3739 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3740 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3741 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:55:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #3742 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 12:59:50 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.03.26 12:59:50 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.03.26 12:59:50 - OpenVPN > Restart pause, 2 second(s)
! 2015.03.26 12:59:50 - Disconnecting
. 2015.03.26 12:59:50 - Management - Send 'signal SIGTERM'
. 2015.03.26 12:59:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 12:59:50 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.03.26 12:59:50 - OpenVPN > Assertion failed at misc.c:788
. 2015.03.26 12:59:50 - OpenVPN > Exiting due to fatal error
. 2015.03.26 12:59:50 - Connection terminated.
I 2015.03.26 12:59:53 - Checking authorization ...
! 2015.03.26 12:59:54 - Connecting to Taygeta (Netherlands, Amsterdam)
. 2015.03.26 12:59:54 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 12:59:54 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 12:59:54 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 12:59:54 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 12:59:54 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:59:54 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:59:54 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 12:59:54 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 12:59:54 - OpenVPN > UDPv4 link remote: [AF_INET]37.48.81.6:443
. 2015.03.26 12:59:54 - OpenVPN > TLS: Initial packet from [AF_INET]37.48.81.6:443, sid=917556e3 95acbdbf
. 2015.03.26 12:59:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 12:59:54 - OpenVPN > Validating certificate key usage
. 2015.03.26 12:59:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 12:59:54 - OpenVPN > VERIFY KU OK
. 2015.03.26 12:59:54 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 12:59:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 12:59:54 - OpenVPN > VERIFY EKU OK
. 2015.03.26 12:59:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 12:59:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:59:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:59:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 12:59:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 12:59:57 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 12:59:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]37.48.81.6:443
. 2015.03.26 12:59:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 12:59:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.111 255.255.0.0'
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.03.26 12:59:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 12:59:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 12:59:59 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 13:00:00 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 13:00:00 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 13:00:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.111/255.255.0.0 [sUCCEEDED]
. 2015.03.26 13:00:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.111/255.255.0.0 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2015.03.26 13:00:00 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 13:00:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2015.03.26 13:00:04 - OpenVPN > C:\Windows\system32\route.exe ADD 37.48.81.6 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 13:00:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.03.26 13:00:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.03.26 13:00:04 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 11
. 2015.03.26 13:00:04 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 13:00:04 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 13:00:04 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 13:00:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 13:00:04 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 13:00:04 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 13:00:04 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 13:00:04 - Starting Management Interface
. 2015.03.26 13:00:04 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 13:00:04 - Flushing DNS
I 2015.03.26 13:00:05 - Checking route
! 2015.03.26 13:00:05 - Connected.
. 2015.03.26 13:00:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 13:00:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.26 13:00:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1610 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 13:00:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1613 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 13:00:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1615 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2015.03.26 13:00:13 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1616 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
! 2015.03.26 13:02:40 - Disconnecting
. 2015.03.26 13:02:40 - Management - Send 'signal SIGTERM'
. 2015.03.26 13:02:40 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 13:02:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.26 13:02:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 37.48.81.6 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 13:02:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.03.26 13:02:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 13:02:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 13:02:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2015.03.26 13:02:45 - OpenVPN > Closing TUN/TAP interface
. 2015.03.26 13:02:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.03.26 13:02:45 - Connection terminated.
! 2015.03.26 13:02:46 - Session terminated.
I 2015.03.26 13:02:47 - Session starting.
I 2015.03.26 13:02:47 - Installing tunnel driver
I 2015.03.26 13:02:51 - Checking authorization ...
! 2015.03.26 13:02:52 - Connecting to Riguel (Netherlands, Amsterdam)
. 2015.03.26 13:02:52 - OpenVPN > OpenVPN 2.3.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2015.03.26 13:02:52 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.26 13:02:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.26 13:02:52 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.26 13:02:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 13:02:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 13:02:52 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2015.03.26 13:02:52 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.26 13:02:52 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.186.93:443
. 2015.03.26 13:02:52 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.186.93:443, sid=178dafa8 3f5b01d5
. 2015.03.26 13:02:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.26 13:02:52 - OpenVPN > Validating certificate key usage
. 2015.03.26 13:02:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.26 13:02:52 - OpenVPN > VERIFY KU OK
. 2015.03.26 13:02:52 - OpenVPN > Validating certificate extended key usage
. 2015.03.26 13:02:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.26 13:02:52 - OpenVPN > VERIFY EKU OK
. 2015.03.26 13:02:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.26 13:02:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 13:02:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 13:02:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.26 13:02:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.26 13:02:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.26 13:02:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.186.93:443
. 2015.03.26 13:02:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.26 13:02:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.118.130 10.4.118.129'
. 2015.03.26 13:02:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.26 13:02:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.26 13:02:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.26 13:02:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.26 13:02:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.26 13:02:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.26 13:02:58 - OpenVPN > open_tun, tt->ipv6=0
. 2015.03.26 13:02:59 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{72719A7A-7904-41E9-AF07-3DA2B8524374}.tap
. 2015.03.26 13:02:59 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.03.26 13:02:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.118.130/255.255.255.252 on interface {72719A7A-7904-41E9-AF07-3DA2B8524374} [DHCP-serv: 10.4.118.129, lease-time: 31536000]
. 2015.03.26 13:02:59 - OpenVPN > Successful ARP Flush on interface [25] {72719A7A-7904-41E9-AF07-3DA2B8524374}
. 2015.03.26 13:03:03 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2015.03.26 13:03:03 - OpenVPN > C:\Windows\system32\route.exe ADD 95.211.186.93 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 13:03:03 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=11]
. 2015.03.26 13:03:03 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.03.26 13:03:03 - OpenVPN > Route addition fallback to route.exe
. 2015.03.26 13:03:03 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.03.26 13:03:03 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 13:03:03 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=25]
. 2015.03.26 13:03:03 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 13:03:03 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.118.129
. 2015.03.26 13:03:03 - Starting Management Interface
. 2015.03.26 13:03:03 - OpenVPN > Initialization Sequence Completed
I 2015.03.26 13:03:03 - Flushing DNS
I 2015.03.26 13:03:03 - Checking route
! 2015.03.26 13:03:06 - Connected.
. 2015.03.26 13:03:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.03.26 13:03:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2015.03.26 13:05:59 - Disconnecting
. 2015.03.26 13:05:59 - Management - Send 'signal SIGTERM'
. 2015.03.26 13:05:59 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.26 13:05:59 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.26 13:06:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.118.129
. 2015.03.26 13:06:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.03.26 13:06:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 95.211.186.93 MASK 255.255.255.255 192.168.1.254
. 2015.03.26 13:06:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 13:06:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.118.129
. 2015.03.26 13:06:04 - OpenVPN > Closing TUN/TAP interface
. 2015.03.26 13:06:04 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.03.26 13:06:04 - Connection terminated.
! 2015.03.26 13:06:05 - Session terminated.
! 2015.03.26 13:06:05 - Deactivation of Network Lock
