The Equalizer
vuze red faces connecton error using air vpn?
HI all
I just installed  Air Vpn   on my pc and ran vuze tested  the firewall under help firewall test and it times out
I also get a connection error  and red faces with my downloads
I have tried to port forward from the vpn site added the port number it gives me and still no luck
what am I missing
how do I fix this problem?
please help
if I disconnect from the vpn server vuze works fine but I want to using it though a vpn
You grap a free port in the client area, then set vuze to use that port in the advanced network settings of vuze as well as tell vuze to bind only to your vpn adapter.  Google setup vuze for vpn.
