Ericthered92
ANSWERED Air VPN not connecting on Mac Server Connection loops
Here is a clipboard of the issue
I 2015.03.18 17:02:33 - Session starting.
I 2015.03.18 17:02:33 - Installing tunnel driver
I 2015.03.18 17:02:33 - Checking authorization ...
! 2015.03.18 17:02:34 - Connecting to Castor (Netherlands, Amsterdam)
. 2015.03.18 17:02:34 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.18 17:02:34 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.18 17:02:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.18 17:02:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.18 17:02:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:34 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2015.03.18 17:02:34 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.18 17:02:34 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2015.03.18 17:02:34 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=a1e73b6b 36e54b87
. 2015.03.18 17:02:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.18 17:02:35 - OpenVPN > Validating certificate key usage
. 2015.03.18 17:02:35 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.18 17:02:35 - OpenVPN > VERIFY KU OK
. 2015.03.18 17:02:35 - OpenVPN > Validating certificate extended key usage
. 2015.03.18 17:02:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.18 17:02:35 - OpenVPN > VERIFY EKU OK
. 2015.03.18 17:02:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.18 17:02:42 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:02:42 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:42 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:02:42 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:42 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.18 17:02:42 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2015.03.18 17:02:44 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.18 17:02:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.123.130 10.4.123.129'
. 2015.03.18 17:02:44 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.18 17:02:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.18 17:02:44 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.18 17:02:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.18 17:02:44 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.18 17:02:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.18 17:02:44 - OpenVPN > Opened utun device utun0
. 2015.03.18 17:02:44 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.18 17:02:44 - OpenVPN > /sbin/ifconfig utun0 delete
. 2015.03.18 17:02:45 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.18 17:02:45 - OpenVPN > /sbin/ifconfig utun0 10.4.123.130 10.4.123.129 mtu 1500 netmask 255.255.255.255 up
. 2015.03.18 17:02:45 - OpenVPN > /sbin/route add -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:02:45 - OpenVPN > add net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:02:45 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:02:45 - OpenVPN > add net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:02:45 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:02:45 - OpenVPN > add net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:02:45 - OpenVPN > /sbin/route add -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:02:45 - OpenVPN > add net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:02:45 - Starting Management Interface
. 2015.03.18 17:02:45 - OpenVPN > Initialization Sequence Completed
I 2015.03.18 17:02:45 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.03.18 17:02:45 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.18 17:02:45 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.03.18 17:02:45 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.03.18 17:02:45 - Flushing DNS
I 2015.03.18 17:02:45 - Checking route
W 2015.03.18 17:02:45 - Checking route, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:02:45 - Checking route, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:02:45 - Checking route, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:02:45 - Checking route, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:02:45 - Checking route, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:02:45 - Error: ConnectFailure (Connection refused)
! 2015.03.18 17:02:45 - Disconnecting
. 2015.03.18 17:02:45 - Management - Send 'signal SIGTERM'
. 2015.03.18 17:02:45 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.18 17:02:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.18 17:02:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.18 17:02:50 - OpenVPN > /sbin/route delete -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:02:50 - OpenVPN > delete net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:02:50 - Connection terminated.
I 2015.03.18 17:02:50 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2015.03.18 17:02:50 - OpenVPN > /sbin/route delete -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:02:50 - OpenVPN > delete net 95.211.169.3: gateway 192.168.1.1
I 2015.03.18 17:02:50 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2015.03.18 17:02:50 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.123.129 128.0.0.0
I 2015.03.18 17:02:50 - DNS of a network adapter restored to original settings (Bluetooth PAN)
. 2015.03.18 17:02:50 - OpenVPN > delete net 0.0.0.0: gateway 10.4.123.129
I 2015.03.18 17:02:50 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
. 2015.03.18 17:02:50 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:02:51 - OpenVPN > delete net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:02:51 - OpenVPN > Closing TUN/TAP interface
. 2015.03.18 17:02:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2015.03.18 17:02:54 - Checking authorization ...
! 2015.03.18 17:02:54 - Connecting to Castor (Netherlands, Amsterdam)
. 2015.03.18 17:02:54 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.18 17:02:55 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.18 17:02:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.18 17:02:55 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.18 17:02:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:55 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2015.03.18 17:02:55 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.18 17:02:55 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2015.03.18 17:02:55 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=2761ba88 b78af699
. 2015.03.18 17:02:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.18 17:02:55 - OpenVPN > Validating certificate key usage
. 2015.03.18 17:02:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.18 17:02:56 - OpenVPN > VERIFY KU OK
. 2015.03.18 17:02:56 - OpenVPN > Validating certificate extended key usage
. 2015.03.18 17:02:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.18 17:02:56 - OpenVPN > VERIFY EKU OK
. 2015.03.18 17:02:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.18 17:02:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:02:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:02:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:02:58 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.18 17:02:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:00 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.18 17:03:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.123.130 10.4.123.129'
. 2015.03.18 17:03:00 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.18 17:03:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.18 17:03:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.18 17:03:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.18 17:03:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.18 17:03:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.18 17:03:01 - OpenVPN > Opened utun device utun0
. 2015.03.18 17:03:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.18 17:03:01 - OpenVPN > /sbin/ifconfig utun0 delete
. 2015.03.18 17:03:01 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.18 17:03:01 - OpenVPN > /sbin/ifconfig utun0 10.4.123.130 10.4.123.129 mtu 1500 netmask 255.255.255.255 up
. 2015.03.18 17:03:01 - OpenVPN > /sbin/route add -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:01 - OpenVPN > add net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:01 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:01 - OpenVPN > add net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:01 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:01 - OpenVPN > add net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:01 - OpenVPN > /sbin/route add -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:01 - OpenVPN > add net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:01 - Starting Management Interface
. 2015.03.18 17:03:01 - OpenVPN > Initialization Sequence Completed
I 2015.03.18 17:03:01 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.03.18 17:03:01 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.18 17:03:01 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.03.18 17:03:01 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.03.18 17:03:02 - Flushing DNS
I 2015.03.18 17:03:02 - Checking route
W 2015.03.18 17:03:02 - Checking route, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:02 - Checking route, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:02 - Checking route, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:02 - Checking route, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:02 - Checking route, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:02 - Error: ConnectFailure (Connection refused)
! 2015.03.18 17:03:02 - Disconnecting
. 2015.03.18 17:03:02 - Management - Send 'signal SIGTERM'
. 2015.03.18 17:03:02 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.18 17:03:02 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.18 17:03:02 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.18 17:03:07 - OpenVPN > /sbin/route delete -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:07 - OpenVPN > delete net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:08 - OpenVPN > /sbin/route delete -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:08 - Connection terminated.
I 2015.03.18 17:03:08 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2015.03.18 17:03:08 - OpenVPN > delete net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:08 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.123.129 128.0.0.0
I 2015.03.18 17:03:08 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2015.03.18 17:03:08 - OpenVPN > delete net 0.0.0.0: gateway 10.4.123.129
I 2015.03.18 17:03:08 - DNS of a network adapter restored to original settings (Bluetooth PAN)
. 2015.03.18 17:03:08 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.123.129 128.0.0.0
I 2015.03.18 17:03:08 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
. 2015.03.18 17:03:08 - OpenVPN > delete net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:08 - OpenVPN > Closing TUN/TAP interface
. 2015.03.18 17:03:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2015.03.18 17:03:11 - Checking authorization ...
! 2015.03.18 17:03:12 - Connecting to Castor (Netherlands, Amsterdam)
. 2015.03.18 17:03:12 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.18 17:03:12 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.18 17:03:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.18 17:03:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.18 17:03:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:12 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2015.03.18 17:03:12 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.18 17:03:12 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:12 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=49b09de1 0a77706d
. 2015.03.18 17:03:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.18 17:03:12 - OpenVPN > Validating certificate key usage
. 2015.03.18 17:03:12 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.18 17:03:13 - OpenVPN > VERIFY KU OK
. 2015.03.18 17:03:13 - OpenVPN > Validating certificate extended key usage
. 2015.03.18 17:03:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.18 17:03:13 - OpenVPN > VERIFY EKU OK
. 2015.03.18 17:03:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.18 17:03:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:15 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.18 17:03:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.18 17:03:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.123.130 10.4.123.129'
. 2015.03.18 17:03:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.18 17:03:18 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.18 17:03:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.18 17:03:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.18 17:03:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.18 17:03:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.18 17:03:18 - OpenVPN > Opened utun device utun0
. 2015.03.18 17:03:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.18 17:03:18 - OpenVPN > /sbin/ifconfig utun0 delete
. 2015.03.18 17:03:18 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.18 17:03:18 - OpenVPN > /sbin/ifconfig utun0 10.4.123.130 10.4.123.129 mtu 1500 netmask 255.255.255.255 up
. 2015.03.18 17:03:18 - OpenVPN > /sbin/route add -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:18 - OpenVPN > add net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:18 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:18 - OpenVPN > add net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:18 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:18 - OpenVPN > add net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:18 - OpenVPN > /sbin/route add -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:18 - OpenVPN > add net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:18 - Starting Management Interface
. 2015.03.18 17:03:18 - OpenVPN > Initialization Sequence Completed
I 2015.03.18 17:03:18 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.03.18 17:03:19 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.18 17:03:19 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.03.18 17:03:19 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.03.18 17:03:19 - Flushing DNS
I 2015.03.18 17:03:19 - Checking route
W 2015.03.18 17:03:19 - Checking route, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:19 - Checking route, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:19 - Checking route, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:19 - Checking route, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:19 - Checking route, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:19 - Error: ConnectFailure (Connection refused)
! 2015.03.18 17:03:19 - Disconnecting
. 2015.03.18 17:03:19 - Management - Send 'signal SIGTERM'
. 2015.03.18 17:03:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.18 17:03:19 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.18 17:03:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.18 17:03:24 - OpenVPN > /sbin/route delete -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:24 - OpenVPN > delete net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:24 - OpenVPN > /sbin/route delete -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:24 - OpenVPN > delete net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:24 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:24 - Connection terminated.
I 2015.03.18 17:03:24 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2015.03.18 17:03:24 - OpenVPN > delete net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:24 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.123.129 128.0.0.0
I 2015.03.18 17:03:24 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2015.03.18 17:03:24 - OpenVPN > delete net 128.0.0.0: gateway 10.4.123.129
I 2015.03.18 17:03:24 - DNS of a network adapter restored to original settings (Bluetooth PAN)
. 2015.03.18 17:03:24 - OpenVPN > Closing TUN/TAP interface
I 2015.03.18 17:03:24 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
. 2015.03.18 17:03:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2015.03.18 17:03:27 - Checking authorization ...
! 2015.03.18 17:03:28 - Connecting to Castor (Netherlands, Amsterdam)
. 2015.03.18 17:03:28 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.18 17:03:28 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.18 17:03:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.18 17:03:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.18 17:03:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:28 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2015.03.18 17:03:28 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.18 17:03:28 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:28 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=62b1d8cf c0442490
. 2015.03.18 17:03:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.18 17:03:29 - OpenVPN > Validating certificate key usage
. 2015.03.18 17:03:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.18 17:03:29 - OpenVPN > VERIFY KU OK
. 2015.03.18 17:03:29 - OpenVPN > Validating certificate extended key usage
. 2015.03.18 17:03:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.18 17:03:29 - OpenVPN > VERIFY EKU OK
. 2015.03.18 17:03:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.18 17:03:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:36 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.18 17:03:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.18 17:03:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.123.130 10.4.123.129'
. 2015.03.18 17:03:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.18 17:03:38 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.18 17:03:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.18 17:03:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.18 17:03:38 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.18 17:03:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.18 17:03:38 - OpenVPN > Opened utun device utun0
. 2015.03.18 17:03:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.18 17:03:38 - OpenVPN > /sbin/ifconfig utun0 delete
. 2015.03.18 17:03:38 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.18 17:03:38 - OpenVPN > /sbin/ifconfig utun0 10.4.123.130 10.4.123.129 mtu 1500 netmask 255.255.255.255 up
. 2015.03.18 17:03:38 - OpenVPN > /sbin/route add -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:38 - OpenVPN > add net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:38 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:38 - OpenVPN > add net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:38 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:38 - OpenVPN > add net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:38 - OpenVPN > /sbin/route add -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:38 - OpenVPN > add net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:38 - Starting Management Interface
. 2015.03.18 17:03:38 - OpenVPN > Initialization Sequence Completed
I 2015.03.18 17:03:38 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.03.18 17:03:39 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.18 17:03:39 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.03.18 17:03:39 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.03.18 17:03:39 - Flushing DNS
I 2015.03.18 17:03:39 - Checking route
W 2015.03.18 17:03:39 - Checking route, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:39 - Checking route, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:39 - Checking route, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:39 - Checking route, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:39 - Checking route, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:39 - Error: ConnectFailure (Connection refused)
! 2015.03.18 17:03:39 - Disconnecting
. 2015.03.18 17:03:39 - Management - Send 'signal SIGTERM'
. 2015.03.18 17:03:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.18 17:03:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.18 17:03:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.03.18 17:03:44 - OpenVPN > /sbin/route delete -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:44 - OpenVPN > delete net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:44 - OpenVPN > /sbin/route delete -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:44 - OpenVPN > delete net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:44 - Connection terminated.
I 2015.03.18 17:03:44 - DNS of a network adapter restored to original settings (Bluetooth DUN)
. 2015.03.18 17:03:44 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:44 - OpenVPN > delete net 0.0.0.0: gateway 10.4.123.129
I 2015.03.18 17:03:44 - DNS of a network adapter restored to original settings (Wi-Fi)
. 2015.03.18 17:03:44 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.4.123.129 128.0.0.0
I 2015.03.18 17:03:44 - DNS of a network adapter restored to original settings (Bluetooth PAN)
. 2015.03.18 17:03:44 - OpenVPN > delete net 128.0.0.0: gateway 10.4.123.129
I 2015.03.18 17:03:44 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
. 2015.03.18 17:03:44 - OpenVPN > Closing TUN/TAP interface
. 2015.03.18 17:03:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2015.03.18 17:03:47 - Checking authorization ...
! 2015.03.18 17:03:48 - Connecting to Castor (Netherlands, Amsterdam)
. 2015.03.18 17:03:48 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.18 17:03:48 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.18 17:03:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.18 17:03:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.18 17:03:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:48 - OpenVPN > Socket Buffers: R=[196724->65536] S=[9216->65536]
. 2015.03.18 17:03:48 - OpenVPN > UDPv4 link local: [undef]
. 2015.03.18 17:03:48 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:48 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.169.3:443, sid=1a529cdd b44e8a26
. 2015.03.18 17:03:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.18 17:03:49 - OpenVPN > Validating certificate key usage
. 2015.03.18 17:03:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.18 17:03:49 - OpenVPN > VERIFY KU OK
. 2015.03.18 17:03:49 - OpenVPN > Validating certificate extended key usage
. 2015.03.18 17:03:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.18 17:03:49 - OpenVPN > VERIFY EKU OK
. 2015.03.18 17:03:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.18 17:03:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.18 17:03:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.18 17:03:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.18 17:03:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.169.3:443
. 2015.03.18 17:03:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.18 17:03:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.123.130 10.4.123.129'
. 2015.03.18 17:03:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.18 17:03:58 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.18 17:03:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.18 17:03:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.18 17:03:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.18 17:03:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.18 17:03:58 - OpenVPN > Opened utun device utun0
. 2015.03.18 17:03:58 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.18 17:03:58 - OpenVPN > /sbin/ifconfig utun0 delete
. 2015.03.18 17:03:58 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.18 17:03:59 - OpenVPN > /sbin/ifconfig utun0 10.4.123.130 10.4.123.129 mtu 1500 netmask 255.255.255.255 up
. 2015.03.18 17:03:59 - OpenVPN > /sbin/route add -net 95.211.169.3 192.168.1.1 255.255.255.255
. 2015.03.18 17:03:59 - OpenVPN > add net 95.211.169.3: gateway 192.168.1.1
. 2015.03.18 17:03:59 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:59 - OpenVPN > add net 0.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:59 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.123.129 128.0.0.0
. 2015.03.18 17:03:59 - OpenVPN > add net 128.0.0.0: gateway 10.4.123.129
. 2015.03.18 17:03:59 - OpenVPN > /sbin/route add -net 10.4.0.1 10.4.123.129 255.255.255.255
. 2015.03.18 17:03:59 - OpenVPN > add net 10.4.0.1: gateway 10.4.123.129
. 2015.03.18 17:03:59 - Starting Management Interface
. 2015.03.18 17:03:59 - OpenVPN > Initialization Sequence Completed
I 2015.03.18 17:03:59 - DNS of a network adapter forced (Bluetooth DUN)
I 2015.03.18 17:03:59 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.18 17:03:59 - DNS of a network adapter forced (Bluetooth PAN)
I 2015.03.18 17:03:59 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2015.03.18 17:03:59 - Flushing DNS
I 2015.03.18 17:03:59 - Checking route
W 2015.03.18 17:03:59 - Checking route, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:03:59 - Checking route, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:04:00 - Checking route, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:04:00 - Checking route, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:04:00 - Checking route, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.18 17:04:00 - Error: ConnectFailure (Connection refused)
! 2015.03.18 17:04:00 - Disconnecting
. 2015.03.18 17:04:00 - Management - Send 'signal SIGTERM'
. 2015.03.18 17:04:00 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.18 17:04:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.18 17:04:00 - OpenVPN > SIGTERM received, sending exit notification to peer
I'm not too tech savvy with why this is not working but this happens when I try to connect to a server and it loops attempting to disconnect then reconnect.
What Mac OS version are you using? The AirVPN "Eddie" client is designed to only works on OSX Mavericks and Yosemite.
I fixed the issue, from doing research i found that if you go into preferences, advanced, i simply unchecked check if the tunnel effectively works, i went onto a test my ip website and it finally works! =)
I am also having the same problem....but it depends on the network I'm attached to.  Log entries:
I 2015.03.19 07:49:59 - Session starting.
I 2015.03.19 07:49:59 - Installing tunnel driver
I 2015.03.19 07:49:59 - Checking authorization ...
. 2015.03.19 07:50:09 - Checking authorization ..., 1° try failed (The request timed out)
! 2015.03.19 07:50:10 - Connecting to Alkaid (United States, Chicago, Illinois)
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: stunnel 5.09 on x86_64-apple-darwin14.0.0 platform
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: Compiled/running with OpenSSL 1.0.1k 8 Jan 2015
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: Threading:PTHREAD Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: Reading configuration from file /Users/jkratz/.airvpn/523db24989d3852f43387d6209740924feebab4aabcd120a3cdec7db6fed9cd1.tmp.ssl
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: UTF-8 byte order mark not detected
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG6[140735201669888]: Initializing service [openvpn]
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[140735201669888]: Configuration successful
. 2015.03.19 07:50:10 - OpenVPN > OpenVPN 2.3.6 x86_64-apple-darwin14.0.0 [sSL (OpenSSL)] [LZO] [MH] [iPv6] built on Jan 12 2015
. 2015.03.19 07:50:10 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2015.03.19 07:50:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.03.19 07:50:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.03.19 07:50:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.19 07:50:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.19 07:50:10 - OpenVPN > Socket Buffers: R=[131072->65536] S=[131072->65536]
. 2015.03.19 07:50:10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:15444 [nonblock]
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[4386291712]: Service [openvpn] accepted connection from 127.0.0.1:49463
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG6[4386291712]: s_connect: connecting 46.21.154.84:443
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[4386291712]: s_connect: connected 46.21.154.84:443
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG5[4386291712]: Service [openvpn] connected remote server from 10.250.96.22:49464
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG6[4386291712]: SNI: sending servername: 46.21.154.84
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG6[4386291712]: SSL connected: new session negotiated
. 2015.03.19 07:50:10 - SSL > 2015.03.19 07:50:10 LOG6[4386291712]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption)
. 2015.03.19 07:50:11 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:15444
. 2015.03.19 07:50:11 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.03.19 07:50:11 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:15444
. 2015.03.19 07:50:11 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:15444, sid=82af03b1 1eb2cd81
. 2015.03.19 07:50:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.03.19 07:50:11 - OpenVPN > Validating certificate key usage
. 2015.03.19 07:50:11 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.03.19 07:50:11 - OpenVPN > VERIFY KU OK
. 2015.03.19 07:50:11 - OpenVPN > Validating certificate extended key usage
. 2015.03.19 07:50:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.03.19 07:50:11 - OpenVPN > VERIFY EKU OK
. 2015.03.19 07:50:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.03.19 07:50:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.19 07:50:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.19 07:50:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.03.19 07:50:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.03.19 07:50:12 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.03.19 07:50:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:15444
. 2015.03.19 07:50:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.03.19 07:50:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.50.0.1,comp-lzo no,route 10.50.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.50.6.58 10.50.6.57'
. 2015.03.19 07:50:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.03.19 07:50:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.03.19 07:50:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.03.19 07:50:14 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.03.19 07:50:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.03.19 07:50:14 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2015.03.19 07:50:14 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2015.03.19 07:50:14 - OpenVPN > Opened utun device utun1
. 2015.03.19 07:50:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.03.19 07:50:14 - OpenVPN > /sbin/ifconfig utun1 delete
. 2015.03.19 07:50:14 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2015.03.19 07:50:14 - OpenVPN > /sbin/ifconfig utun1 10.50.6.58 10.50.6.57 mtu 1500 netmask 255.255.255.255 up
. 2015.03.19 07:50:14 - OpenVPN > /sbin/route add -net 127.0.0.1 10.250.99.254 255.255.255.255
. 2015.03.19 07:50:14 - OpenVPN > add net 127.0.0.1: gateway 10.250.99.254
. 2015.03.19 07:50:14 - OpenVPN > /sbin/route add -net 0.0.0.0 10.50.6.57 128.0.0.0
. 2015.03.19 07:50:14 - OpenVPN > add net 0.0.0.0: gateway 10.50.6.57
. 2015.03.19 07:50:14 - OpenVPN > /sbin/route add -net 128.0.0.0 10.50.6.57 128.0.0.0
. 2015.03.19 07:50:14 - OpenVPN > add net 128.0.0.0: gateway 10.50.6.57
. 2015.03.19 07:50:14 - OpenVPN > /sbin/route add -net 46.21.154.84 10.250.99.254 255.255.255.255
. 2015.03.19 07:50:14 - OpenVPN > add net 46.21.154.84: gateway 10.250.99.254
. 2015.03.19 07:50:14 - OpenVPN > /sbin/route add -net 10.50.0.1 10.50.6.57 255.255.255.255
. 2015.03.19 07:50:14 - OpenVPN > add net 10.50.0.1: gateway 10.50.6.57
. 2015.03.19 07:50:14 - Starting Management Interface
. 2015.03.19 07:50:14 - OpenVPN > Initialization Sequence Completed
I 2015.03.19 07:50:15 - DNS of a network adapter forced (Bluetooth DUN 2)
I 2015.03.19 07:50:15 - DNS of a network adapter forced (Wi-Fi)
I 2015.03.19 07:50:15 - Flushing DNS
I 2015.03.19 07:50:15 - Checking route
W 2015.03.19 07:50:15 - Checking info, 1° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.19 07:50:15 - Checking info, 2° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.19 07:50:15 - Checking info, 3° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.19 07:50:15 - Checking info, 4° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.19 07:50:15 - Checking info, 5° try failed (Error: ConnectFailure (Connection refused))
W 2015.03.19 07:50:15 - Error: ConnectFailure (Connection refused)
! 2015.03.19 07:50:15 - Disconnecting
. 2015.03.19 07:50:16 - Management - Send 'signal SIGTERM'
. 2015.03.19 07:50:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.03.19 07:50:16 - SSL > 2015.03.19 07:50:16 LOG6[4386291712]: Read socket closed (readsocket)
. 2015.03.19 07:50:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.03.19 07:50:16 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2015.03.19 07:50:16 - SSL > 2015.03.19 07:50:16 LOG6[4386291712]: SSL_shutdown successfully sent close_notify alert
. 2015.03.19 07:50:16 - OpenVPN > /sbin/route delete -net 10.50.0.1 10.50.6.57 255.255.255.255
. 2015.03.19 07:50:16 - SSL > 2015.03.19 07:50:16 LOG3[4386291712]: transfer: s_poll_wait: TIMEOUTclose exceeded: closing
. 2015.03.19 07:50:16 - OpenVPN > delete net 10.50.0.1: gateway 10.50.6.57
. 2015.03.19 07:50:16 - SSL > 2015.03.19 07:50:16 LOG5[4386291712]: Connection closed: 59251 byte(s) sent to SSL, 83370 byte(s) sent to socket
. 2015.03.19 07:50:16 - OpenVPN > /sbin/route delete -net 46.21.154.84 10.250.99.254 255.255.255.255
. 2015.03.19 07:50:16 - OpenVPN > delete net 46.21.154.84: gateway 10.250.99.254
. 2015.03.19 07:50:16 - OpenVPN > /sbin/route delete -net 127.0.0.1 10.250.99.254 255.255.255.255
. 2015.03.19 07:50:16 - OpenVPN > delete net 127.0.0.1: gateway 10.250.99.254
. 2015.03.19 07:50:16 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.50.6.57 128.0.0.0
. 2015.03.19 07:50:16 - OpenVPN > delete net 0.0.0.0: gateway 10.50.6.57
. 2015.03.19 07:50:16 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.50.6.57 128.0.0.0
. 2015.03.19 07:50:16 - OpenVPN > delete net 128.0.0.0: gateway 10.50.6.57
. 2015.03.19 07:50:16 - OpenVPN > Closing TUN/TAP interface
. 2015.03.19 07:50:16 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2015.03.19 07:50:16 - Connection terminated.
I 2015.03.19 07:50:16 - DNS of a network adapter restored to original settings (Bluetooth DUN 2)
I 2015.03.19 07:50:16 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2015.03.19 07:50:17 - Cancel requested.
! 2015.03.19 07:50:17 - Session terminated.
This is on my connection at work (which blocks OpenVPN traffic...but with tunnel this shouldnt be an issue and vpn.ac client works just fine with tunnel).  On my home network or tethered on my phone this same setup works just fine.
I put in a help ticket and the suggested fix worked for me.
In the client go to Preferences->Advanced and uncheck "Check if the tunnel effectively works".  After that try connecting again.  If the connection now works make sure you're actually tunneled by going to airvpn.org and making sure the second box at the bottom is green.
