Not connected, Your IP: 3.135.201.190
myairact
Stunnel connection reset every 20 min
I am using stunnel to connect via ssl to American servers only. The connection is being reset -- "SSL_read Connection reset by peer (WSAECONNRESET) (10054)" -- every 20 minutes.  I have lost connectivity (?) or ability to request webpage when this happens. It seems the tunnel may be going down for 5 secs every 20 mins:   a reset by peer as stated above, then 5 secs later renegotiation "Service [openvpn] accepted connection..."
Has occurred on different Airvpn US servers, may have started 3/16.  When I first started using stunnel the renegotiation was every hour, no connection resets.  Or is this s a problem with openvpn program iteslf?
Any help or guidance is appreciated.
EDIT: The whole thing goes down, openvpn and stunnel -- but I cannot determine which fails first. The automatic reconnect after 5 secs.
openvpn:
Tue Mar 17 16:12:06 2015 Connection reset, restarting [-1]
Tue Mar 17 16:12:06 2015 SIGUSR1[soft,connection-reset] received, process restarting
Tue Mar 17 16:12:06 2015 Restart pause, 5 second(s)
Stunnel:
2015.03.17 16:12:06 LOG3[3816:3908]: SSL_read: Connection reset by peer (WSAECON
NRESET) (10054)
2015.03.17 16:12:06 LOG5[3816:3908]: Connection reset: 253767 byte(s) sent to SS
L, 1147201 byte(s) sent to socket
2015.03.17 16:12:14 LOG5[3816:4204]: Service [openvpn] accepted connection from
127.0.0.1:55580
