darkshady
Automatically switched servers?
I was recently connected to Netherlands server. I think 3 hours later, I found out that I switched automatically to a Canadian server!
Is this okay? Why did this happen?
Thank you
I know your post is a little old, but you didn't get a reply so I'll tell you what little I do know for sure. When my client occasionally disconnects (whether because my ISP dropped and resynced or the machine went into standby etc) the AirVPN client will attempt to automatically reconnect. If it doesn't for any reason (ISP still coming back up, machine still powering on services or even a temporary issue with an Air server, etc) then Eddie - AirVPN's client software - will go through the list of available servers until it gets a connection that works. In your case this happened to be a Canadian server. Nothing to worry about.
