Not connected, Your IP: 216.73.216.33
Grazzy
SIGUSR1 [soft.ping-restart]
I get occasional breaks in communications and Eddie 2.8 takes quite a long time to reconnect at the point of the failure I get SIGUSR1 and SIGTERM messages in the log which are unusual.  Full log attached, extract below- failure at 07/02/2015 20:54
Why is this? The system was being used quite heavily at the point of failure and it seemed to have issues trying to reconnect!
. 2015.02.07 20:49:56 - Updating systems & servers data ...
. 2015.02.07 20:49:58 - Systems & servers data update completed
I 2015.02.07 20:50:44 - Renewing TLS key
. 2015.02.07 20:50:44 - OpenVPN > TLS: tls_process: killed expiring key
. 2015.02.07 20:50:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.02.07 20:50:49 - OpenVPN > Validating certificate key usage
. 2015.02.07 20:50:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.02.07 20:50:49 - OpenVPN > VERIFY KU OK
. 2015.02.07 20:50:49 - OpenVPN > Validating certificate extended key usage
. 2015.02.07 20:50:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.02.07 20:50:49 - OpenVPN > VERIFY EKU OK
. 2015.02.07 20:50:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.02.07 20:50:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.02.07 20:50:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.02.07 20:50:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.02.07 20:50:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.02.07 20:50:55 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.02.07 20:54:51 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2015.02.07 20:54:51 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2015.02.07 20:54:51 - OpenVPN > Restart pause, 2 second(s)
! 2015.02.07 20:54:51 - Disconnecting
. 2015.02.07 20:54:51 - Management - Send 'signal SIGTERM'
. 2015.02.07 20:54:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.02.07 20:54:51 - OpenVPN > MANAGEMENT: Client disconnected
. 2015.02.07 20:54:51 - OpenVPN > Assertion failed at misc.c:788
. 2015.02.07 20:54:51 - OpenVPN > Exiting due to fatal error
. 2015.02.07 20:54:51 - Connection terminated.
I 2015.02.07 20:55:27 - Checking authorization ...
. 2015.02.07 20:55:27 - Checking authorization ..., 1° try failed (The remote name could not be resolved: 'auth.airvpn.org')
. 2015.02.07 20:55:48 - Checking authorization ..., 2° try failed (Unable to connect to the remote server)
. 2015.02.07 20:55:48 - Checking authorization ..., 3° try failed (The remote name could not be resolved: 'airvpn.org')
. 2015.02.07 20:56:03 - Checking authorization ..., 4° try failed (The operation has timed out)
. 2015.02.07 20:56:13 - Checking authorization ..., 5° try failed (The operation has timed out)
. 2015.02.07 20:56:13 - Checking authorization ..., 6° try failed (The remote name could not be resolved: 'airvpn.info')
. 2015.02.07 20:56:13 - Checking authorization ..., 7° try failed (The remote name could not be resolved: 'airvpn.ch')
. 2015.02.07 20:56:13 - Checking authorization ..., 8° try failed (The remote name could not be resolved: 'airvpn.eu')
W 2015.02.07 20:56:13 - Authorization check failed, continue anyway ({1])
! 2015.02.07 20:56:13 - Connecting to Julliet (Netherlands, Amsterdam)
AirVPN_20150207_211448.txt
