Not connected, Your IP: 216.73.216.18
tomato_user12123
Webserver from WAN site not reachable
im using tomato from shibby and installed debian (wheezy) - running Apache2 and Mysql -> LAN access works great!!
i did a port forwarding for the WAN Port 12345 (for TCP and UDP) to my specific IP 192.168.1.1 on port 91 (GUI) and enabled it and saved it.
then i opened up the specific port on firewall under administration / scripts
iptables -t filter -A INPUT -p tcp --dport 12345 -j ACCEPTiptables -t filter -A OUTPUT -p tcp --dport 12345 -j ACCEPT
then i rebootet the router a few times……nothing -> i get an timeout if i want to get acces from wan site.
i mean trying to get access to the webserver page by typing:
xxx.xxx.x.x:12345
On LAN Site everything works fine. even if i try to get access from LAN site by using the wan external IP Adress. everything is great. only accessing from wan site doesn´t work -> TIME OUT!!
The Apache log says nothing. no connection from outside incoming.
What can i do ??
Solution :i only had to disable the forwarding and open the port from wan site. then it works. so the problem was the forwarding. Forwarding is only needed to devices which are connected to the lan ports.
