Caliban
Request for help: Using AirVPN with Synology DiskStation (NAS)
Hello.
While it was working fine on an earlier version of my NAS's OS, I am having difficulty getting to stable on the latest version.
I've followed the tutorial many times, which is what I've always done to get it to work, but this time things don't quite work consistently.
What I need is someone's take on exactly how the settings in the AirVPN-generated config file should be melded into the Synology-generated config files.
Note that one of the Synology files includes user name and password info, but in the past I have never used that; I've only used the keys and certs that I receive in the zip file from AirVPN.  I'd like to have things configured so that I don't have to have my user info in the file.
CONFIG FILES
AirVPN Config FIle
client
dev tun
proto udp
remote nl.airvpn.org 53
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
cipher AES-256-CBC
comp-lzo no
route-delay 5
verb 3
explicit-exit-notify 5
-ca "ca.crt"
cert "user.crt"
key "user.key"
tls-auth "ta.key" 1
Synology Config File 1:  client_o1423043191
dev tun
tls-client
pull
proto udp
up /usr/syno/etc.defaults/synovpnclient/scripts/ovpn-up
route-up /usr/syno/etc.defaults/synovpnclient/scripts/route-up
ca ca_o1423043191.crt
comp-lzo
redirect-gateway
script-security 2
float
reneg-sec 0
plugin /lib/openvpn/openvpn-down-root.so /usr/syno/etc.defaults/synovpnclient/scripts/ip-down
auth-user-pass /tmp/ovpn_client_up
Synology Config File 2:  ovpnclient.conf
[o1423043191]
nat=no
protocol=udp
redirect-gateway=yes
comp-lzo=yes
pass=xxxxxxxxxxxx
port=53
reconnect=yes
conf_name=AirVPN_NL
user=Caliban
remote=nl.airvpn.org
Again, what I'm shooting for is the proper addition of the AirVPN config file to the Synology files so that the NAS will still be happy, yet have what it needs to make the connection properly.
Thanks!
