Redemptor
Issue with Eddie 2.7
I've just updated from 1.9 to 2.7, running on XP. 1.9 worked fine.
I've turned off both the windows and Comodo firewall and disabled anti-virus but despite several re-installs i'm still getting a revolving error that the client cannot update systems and servers data.
I'm at a loss as to what's causing it? Any suggestions for next troubleshooting steps? Any help appreciated!
I 2015.01.13 23:24:29 - AirVPN client version: 2.7, System: Windows, Architecture: x86
. 2015.01.13 23:24:29 - Reading options from C:\AirVPN\AirVPN.xml
. 2015.01.13 23:24:29 - Profile options not found, using defaults.
. 2015.01.13 23:24:29 - Data Path: C:\AirVPN
. 2015.01.13 23:24:29 - App Path: C:\AirVPN
. 2015.01.13 23:24:29 - Executable Path: C:\AirVPN\AirVPN.exe
. 2015.01.13 23:24:29 - Command line arguments:
. 2015.01.13 23:24:31 - Updating systems & servers data ...
. 2015.01.13 23:24:31 - Operating System: Microsoft Windows NT 5.1.2600 Service Pack 3
I 2015.01.13 23:24:31 - OpenVPN Driver - TAP-Windows Adapter V9 - Packet Scheduler Miniport
I 2015.01.13 23:24:31 - OpenVPN - Version: Access is (C:\AirVPN\openvpn.exe)
I 2015.01.13 23:24:31 - SSH - Version: Access is denied (C:\AirVPN\plink.exe)
I 2015.01.13 23:24:31 - SSL - Version: Access is (C:\AirVPN\stunnel.exe)
I 2015.01.13 23:24:31 - IPV6: Not available
! 2015.01.13 23:24:31 - Ready
. 2015.01.13 23:24:51 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.13 23:25:01 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.13 23:25:18 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.13 23:25:28 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.13 23:25:38 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.13 23:25:55 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
! 2015.01.13 23:25:57 - Checking login ...
. 2015.01.13 23:26:12 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.13 23:26:14 - Checking login ..., 1° try failed (The operation has timed out)
. 2015.01.13 23:26:24 - Checking login ..., 2° try failed (The operation has timed out)
. 2015.01.13 23:26:30 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.13 23:26:30 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.13 23:26:41 - Checking login ..., 3° try failed (The operation has timed out)
. 2015.01.13 23:26:51 - Checking login ..., 4° try failed (The operation has timed out)
. 2015.01.13 23:27:01 - Checking login ..., 5° try failed (The operation has timed out)
. 2015.01.13 23:27:19 - Checking login ..., 6° try failed (The operation has timed out)
. 2015.01.13 23:27:35 - Updating systems & servers data ...
. 2015.01.13 23:27:36 - Checking login ..., 7° try failed (The operation has timed out)
. 2015.01.13 23:27:53 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.13 23:27:53 - Checking login ..., 8° try failed (The operation has timed out)
F 2015.01.13 23:27:53 - Cannot login. (The operation has timed out)
. 2015.01.13 23:28:03 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.13 23:28:20 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.13 23:28:30 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.13 23:28:40 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.13 23:28:57 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.13 23:29:14 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.13 23:29:32 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.13 23:29:32 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.13 23:30:37 - Updating systems & servers data ...
. 2015.01.13 23:30:54 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.13 23:31:04 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.13 23:31:22 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.13 23:31:32 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.13 23:31:42 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.13 23:31:59 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.13 23:32:16 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.13 23:32:33 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.13 23:32:33 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
. 2015.01.13 23:33:39 - Updating systems & servers data ...
. 2015.01.13 23:33:56 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2015.01.13 23:34:06 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2015.01.13 23:34:24 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2015.01.13 23:34:34 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2015.01.13 23:34:44 - Updating systems & servers data ..., 5° try failed (The operation has timed out)
. 2015.01.13 23:35:01 - Updating systems & servers data ..., 6° try failed (The operation has timed out)
. 2015.01.13 23:35:18 - Updating systems & servers data ..., 7° try failed (The operation has timed out)
. 2015.01.13 23:35:35 - Updating systems & servers data ..., 8° try failed (The operation has timed out)
W 2015.01.13 23:35:35 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
