Not connected, Your IP: 216.73.216.169
Mr_MIagi
Prevent leaks from Diskstation
Hi all,
I followed the suggested how to guide and set up Synology DiskStation to connect to AirVPN.  It was a convoluted set-up but this was not fault of the guide or author, it was a just a pain and a little over my head.
Anyway, I am successfully connected, but is there a way to prevent leaks if they occur, and secondly, other that viewing connections in client area of the AiVPN website, is there anyway to confirm that I am actually connected?
Thanks MM
Hey where did you find the guide ??
Maybe that one. Found by searching for synology, but no offense.
If someone is still looking for a script...i found this one but it has to be changed for airvpn...
#!/bin/ash
# wget https://gist.githubusercontent.com/aelveborn/e0faab9185256eeb86ad/raw/ -O ipredator-iptables.sh
# chmod 755 ipredator-iptables.sh
# and modify your local ip in the script
enableRules() {
    if [ -f /etc/ipredator/iptables.orig ]; then
        echo "Ipredator iptables rules already enabled!"
    else
        if [ ! -d /etc/ipredator ]; then
            mkdir /etc/ipredator/
        fi
        iptables-save > /etc/ipredator/iptables.orig
        # Flush iptables and add tunnel and localhost
        iptables -F
        iptables -A INPUT -i tun+ -j ACCEPT
        iptables -A OUTPUT -o tun+ -j ACCEPT
        iptables -A INPUT -s 127.0.0.0/8 -j ACCEPT
        iptables -A OUTPUT -d 127.0.0.0/8 -j ACCEPT
        # Add local subnet for LAN access
        # Modify these ips for your local network
        iptables -A INPUT -s 10.0.0.0/24 -j ACCEPT
        iptables -A OUTPUT -d 10.0.0.0/24 -j ACCEPT
        iptables -A INPUT -s 10.8.0.0/24 -j ACCEPT
        iptables -A OUTPUT -d 10.8.0.0/24 -j ACCEPT
        iptables -A INPUT -s 192.168.1.0/24 -j ACCEPT
        iptables -A OUTPUT -d 192.168.1.0/24 -j ACCEPT
        # Add Ipredators IP's
        iptables -A INPUT -s 46.246.32.0/19 -j ACCEPT
        iptables -A OUTPUT -d 46.246.32.0/19 -j ACCEPT
        # Add current IP, in case currently connected server IP isn't in server list for some reason
        # Also allows script to handle individual servers from other VPN providers
        #CURRENT_SERVER_IP=$(wget https://duckduckgo.com/?q=whats+my+ip -q -O - | grep -Eo '\<[[:digit:]]{1,3}(\.[[:digit:]]{1,3}){3}\>')
        #iptables -A INPUT -s $CURRENT_SERVER_IP -j ACCEPT
        #iptables -A OUTPUT -d $CURRENT_SERVER_IP -j ACCEPT
        # Drop everything else
        iptables -A INPUT -j DROP
        iptables -A OUTPUT -j DROP
        echo "Ipredator iptables rules activated"
    fi
disableRules() {
        iptables-restore /etc/ipredator/iptables.orig
        rm /etc/ipredator/iptables.orig
        echo "Ipredator iptables rules deactivated"
    else
        echo "Ipredator iptables rules already disabled!"
    fi
help () {
echo "Ipredator iptables"
echo "  Based on PIA IPTables Leak Blocker 0.5 - coded by Colonel Panic"
echo "  and on scripts created by ShadowSpectre (PIA Iptables Manager)"
echo "  and Windom (iptables-vpnon-update)"
echo ""
echo "Usage: $0 [OPTION]"
echo "  start      Replace current iptables rules to accept Ipredator servers and LAN, dropping all other connections"
echo "  stop       Reset iptables rules to original values"
echo "  {no option}  Display this help text"
if [ $# -gt 1 ]; then
    echo "Too many arguments"
elif [ $# -eq 1 ]; then
    case $1 in
        start) enableRules;;
        stop) disableRules;;
        *) echo "Invalid option: $1"
    esac
else
    help
fi
I'f tested the script and it prevents the ip leak, but only there is no traffic working at all...[/size]
It looks like this at the moment:
#!/bin/ash
# chmod 755 airvpn-iptables.sh
enableRules() {
    if [ -f /etc/airvpn/iptables.orig ]; then
        echo "AirVPN iptables rules already enabled!"
    else
        if [ ! -d /etc/airvpn ]; then
            mkdir /etc/airvpn/
        fi
        iptables-save > /etc/airvpn/iptables.orig
        iptables -F
        #iptables -A INPUT -s 10.0.0.0/24 -j ACCEPT
        #iptables -A OUTPUT -d 10.0.0.0/24 -j ACCEPT
        iptables -A INPUT -s MY.LOCAL.NETWORK.RANGE/24 -j ACCEPT
        iptables -A OUTPUT -d MY.LOCAL.NETWORK.RANGE/24 -j ACCEPT
        # Add AirVPNs IP's
        iptables -A INPUT -s AIR.VPN.SERVER.IP -j ACCEPT
        iptables -A OUTPUT -d AIR.VPN.SERVER.IP -j ACCEPT
        echo "AirVPN iptables rules activated"
    fi
disableRules() {
        iptables-restore /etc/airvpn/iptables.orig
        rm /etc/airvpn/iptables.orig
        echo "AirVPN iptables rules deactivated"
    else
        echo "AirVPN iptables rules already disabled!"
    fi
help () {
echo "AirVPN iptables"
echo ""
echo "  start      Replace current iptables rules to accept AirVPN servers and LAN, dropping all other connections"
    case $1 in
    esac
else
    help
fi
Do i miss something?
