Not connected, Your IP: 216.73.217.154
Watts
Connecting the Torbrowser
Hi!
After connecting to AirVPN on Linux, I started Torbrowser as instructed at https://www.torproject.org/projects/torbrowser.html.en under "Linux Instructions" and regardless of the AirVPN server I was connected to, inside the terminal I see a message:
Jan 11 *:*:*.* [notice] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
With this message, the Torbrowser wouldn't directly connect. After closing and restarting the Torbrowser and then selecting a pluggable transport prior to actually connecting to Tor, the Torbrowser worked OK.
Will someone discuss/explain this?
