To whom can help,
I am now starting to see things that don't work in OpenElec on Addon Installer and other addons that use to work with my regular interent connection.  Since these items are found on the web, I am unsure why I could see them with my ISP and now I can not see them with AirVPN?  Could this be a DNS issue? Do I need to change something in my *.ovpn file?  Do I need to a new DNS in to my OpenELEC device that matches the server it is connecting to from AirVPN?
Thanks,
-SF-
I wanted to pass this on since I found out the problem was DNS settings in my OpenElec box settings.  I found out a while ago and forgot to post it that the problem was because I was using the DNS of my ISP provider.  I set the DNS to my local LAN gateway and all of my links and apps worked correctly.
Thanks,
-SF-
