Syrma - nl.png Netherlands
The connection was reset
The connection to the server was reset while the page was loading.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer's network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Try Again
Check routes feature reports every server except Carinae and Nunki, UK, doesn't work. Just tried a connection with Nunki; I can view the site in question.
