Guest JWW
FastStone
Guest JWW
Annoyance - this site is the home of the well known image viewer and 'FastStone Capture'. I'm a user of both and have yet to find an AirVPN server that I can access the site from. I tend to use UK only servers though, which are normally pretty reliable with sites that others have found to be blocked.
http://faststone.org/
Message from site:
The requested URL was rejected. If you think this is an error, please contact the webmaster.
Your support ID is: 9310486142392977591
Dorsum - nl.png Netherlands
Your support ID is: 9310486142420944487
Guest JWW
This is still a problem. I get the same response from the site on Carinae.
Guest JWW
Seginus, DE, can view it.
Seems I can connect on Nashira. I'm only interested in UK servers as that's all I connect to. It's a pain to have to keep changing server to view different sites.
Question answered, right?
Guest JWW
I think we posted at the same time! Well, sort of. I white-list the UK as I only wish to connect to UK servers. As above, it's a pain to have to keep changing server for different sites. VPN / Anonymous IP blacklisting seems to be an increasing problem.
It really is.
Guest JWW
Interesting. Thanks for the pointer.
