Not connected, Your IP: 216.73.216.245
Hi all, i've searched many terms on the forum and couldn't find a solution, any suggestions are welcome
I cannot remotely access my Calibre server (ebook management software), and Utorrent Webui while connected to AirVPN
  • I have forwarded the ports on AirVPN and input them into the programs
  • canyouseeme.org says those ports are open
  • cannot connect via ip:port (for calibre) and ip:port/gui (for webui) - both programs are open and running
  • cannot connect via AirVPN DDNS using name.airvpn.org - have waited 3 hours
  • cannot connect using my no-ip ddns - correct AirVPN IP address is showing
  • CAN connect via localhost:port and localhost:port/gui
  • CAN connect via ip address or no-ip ddns when disabling AirVPN
i am so confused! is there something really obvious i'm missing?
thank you
