mulvsatri
I can not connect some servers.
Sometimes When I want connect to the server, I see this error.
I 2014.11.26 13:31:26 - AirVPN client version: 2.7, System: Windows, Architecture: x64
. 2014.11.26 13:31:26 - Reading options from C:\Users\XXX\AppData\Local\AirVPN\AirVPN.xml
. 2014.11.26 13:31:26 - Data Path: C:\Users\XXX\AppData\Local\AirVPN
. 2014.11.26 13:31:26 - App Path: C:\Program Files\AirVPN
. 2014.11.26 13:31:26 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2014.11.26 13:31:26 - Command line arguments: path="home"
. 2014.11.26 13:31:27 - Operating System: Microsoft Windows NT 6.2.9200.0
I 2014.11.26 13:31:27 - OpenVPN Driver - TAP-Windows Adapter V9
I 2014.11.26 13:31:27 - OpenVPN - Version: OpenVPN 2.3.4 (C:\Program Files\AirVPN\openvpn.exe)
I 2014.11.26 13:31:27 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2014.11.26 13:31:27 - SSL - Version: stunnel 4.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2014.11.26 13:31:27 - IPV6: Available
! 2014.11.26 13:31:27 - Ready
I 2014.11.26 13:31:42 - Session starting.
! 2014.11.26 13:31:42 - Checking environment
! 2014.11.26 13:31:42 - Checking authorization ...
! 2014.11.26 13:31:43 - Connecting to Ophiuchi (Netherlands, Amsterdam)
. 2014.11.26 13:31:43 - OpenVPN > OpenVPN 2.3.4 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Oct 18 2014
. 2014.11.26 13:31:43 - OpenVPN > library versions: OpenSSL 1.0.1j 15 Oct 2014, LZO 2.05
. 2014.11.26 13:31:43 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.11.26 13:31:43 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.11.26 13:31:43 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.11.26 13:31:43 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.11.26 13:31:43 - OpenVPN > Socket Buffers: R=[65536->65536] S=[65536->65536]
. 2014.11.26 13:31:43 - OpenVPN > UDPv4 link local: [undef]
. 2014.11.26 13:31:43 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.186.65:443
. 2014.11.26 13:31:44 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.186.65:443, sid=b91d538c f258267b
. 2014.11.26 13:31:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.11.26 13:31:44 - OpenVPN > Validating certificate key usage
. 2014.11.26 13:31:44 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.11.26 13:31:44 - OpenVPN > VERIFY KU OK
. 2014.11.26 13:31:44 - OpenVPN > Validating certificate extended key usage
. 2014.11.26 13:31:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.11.26 13:31:44 - OpenVPN > VERIFY EKU OK
. 2014.11.26 13:31:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.11.26 13:31:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.11.26 13:31:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.11.26 13:31:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.11.26 13:31:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.11.26 13:31:47 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.11.26 13:31:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.186.65:443
. 2014.11.26 13:31:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.11.26 13:31:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.169.58 10.4.169.57'
. 2014.11.26 13:31:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.11.26 13:31:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.11.26 13:31:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.11.26 13:31:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.11.26 13:31:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.11.26 13:31:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.11.26 13:31:50 - OpenVPN > open_tun, tt->ipv6=0
. 2014.11.26 13:31:50 - OpenVPN > TAP-WIN32 device [Yerel Ağ Bağlantısı] opened: \\.\Global\{28DB36B8-46A7-4F50-A1B5-9AD1F290E914}.tap
. 2014.11.26 13:31:50 - OpenVPN > TAP-Windows Driver Version 9.9
. 2014.11.26 13:31:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.169.58/255.255.255.252 on interface {28DB36B8-46A7-4F50-A1B5-9AD1F290E914} [DHCP-serv: 10.4.169.57, lease-time: 31536000]
. 2014.11.26 13:31:50 - OpenVPN > Successful ARP Flush on interface [9] {28DB36B8-46A7-4F50-A1B5-9AD1F290E914}
. 2014.11.26 13:31:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:31:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:31:55 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:00 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:02 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:03 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:04 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:05 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:06 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:08 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:09 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:10 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
. 2014.11.26 13:32:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2014.11.26 13:32:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2014.11.26 13:32:11 - AirVPN Windows Interface Hack executed (Yerel Ağ Bağlantısı)
