Guest JWW
Detected Torrent Address Not Working with Vuze
Guest JWW
As the Topic Title suggests: Latest version of Vuze installed, clicking on 'Add this magnet link' on ipleak.net starts Vuze (so the association is working), but Vuze gets stuck at that point and eventually times out with 'Error :  no sources found for torrent'. Is there any solution to this?
Thanks.
Did you check for the torrent IP in both Vuze and IPleak?
Guest JWW
I'm not able to do either. Vuze fails to load it so there's no information to see. Eventually Vuze gives up with the error above and removes the torrent. I found another site that does a similar thing: http://ipmagnet.services.cbcdn.com/
Vuze behaves in the same way but ipmagnet does show the IP address correctly unlike ipleak which shows nothing at all.
Guest JWW
Yes, I've used that but I've told it isn't reliable (for a reason I can't remember  ). As I mentioned back in this thread, http://ipmagnet.services.cbcdn.com/ seems to work before Vuze gives up on it 'not being a real download'. You need to use the 'Update' button on the site to get a result - if you try to announce the tracker in Vuze, Vuze removes the download.
