Not connected, Your IP: 18.216.135.3
serleejus
Remote Login to my Synology NAS while connected to AirVpn
[Edited by Staff to remove ads]
I wanted to switch to Airvpn.
I have my Synology connected to Airvpn, but am UNABLE to access it through wither its's quickconnect, or DDNS.
I am unfamiliar how to access it while it's connected to AIRvpn.
Any help would be greatly appreciated.
Thank you
(I am not too familiar with the port forwarding option through Airvpn) this may be the issue?
Thank you
I've read somewhere that a dedicated IP is also required in order for remote access to Synology box to be possible once it's connected to VPN. Is this really required or just port forwarding is sufficient? I'm hoping to still be able to access my Synology box via web and the DS apps. Thanks.
