I've followed the pfSense port forwarding guide on this website and everything is working great. The issue that I'm having is setting up port forwarding. I went to the Client Area and setup port forwards on a port. My question is: How do I setup pfSense to work with those ports?
If I have a client on 192.168.1.1 that's listening on port 5000, what do I need to add to the port forward on the website and on the pfSense to be able to perform the port forward correctly. I tried a few suggestions on the forums but nothing worked.
worth checking the main thread out and also this post here:
https://airvpn.org/topic/11245-how-to-set-up-pfsense-21-for-airvpn/page-6?do=findComment&comment=17580
also this post here check the bottom parts with my post about additional port forward mapping settings
https://airvpn.org/topic/11245-how-to-set-up-pfsense-21-for-airvpn/page-10?do=findComment&comment=20755
It may help but not sure, you can also post on the main pfsense thread others maybe able to assist too
