cooooly15
Connection timeout
I have problems with my connection. The log below goes from 17:20 until 20.54. This problem happens every day.
Sun Oct 26 17:20:13 2014 us=551605 Attempting to establish TCP connection with [AF_INET]46.165.208.65:80 [nonblock]
Sun Oct 26 17:20:23 2014 us=554186 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:20:38 2014 us=561530 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:20:53 2014 us=568848 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:21:08 2014 us=577377 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:21:23 2014 us=584879 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:21:38 2014 us=591740 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:21:53 2014 us=598941 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:22:08 2014 us=606322 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:22:23 2014 us=613217 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:22:38 2014 us=620662 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:22:53 2014 us=628377 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:23:08 2014 us=635588 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:23:23 2014 us=642270 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:23:38 2014 us=649289 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:23:53 2014 us=656261 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:24:08 2014 us=663007 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:24:23 2014 us=669816 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:24:38 2014 us=676748 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:24:53 2014 us=683581 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:25:08 2014 us=690767 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:25:23 2014 us=698409 TCP: connect to [AF_INET]46.165.208.65:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:25:38 2014 us=820815 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:25:53 2014 us=826986 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:26:08 2014 us=834137 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:26:23 2014 us=840974 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:26:38 2014 us=848588 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:26:53 2014 us=855393 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:27:08 2014 us=862419 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:27:23 2014 us=869050 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:27:38 2014 us=876718 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:27:53 2014 us=883451 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 17:28:08 2014 us=889981 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:45:43 2014 us=103140 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:45:58 2014 us=110234 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:46:13 2014 us=117222 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:46:28 2014 us=123829 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:46:43 2014 us=130543 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:46:58 2014 us=137674 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:47:13 2014 us=144632 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:47:28 2014 us=151545 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:47:43 2014 us=158617 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:47:58 2014 us=165816 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:48:13 2014 us=172406 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:48:28 2014 us=179702 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:48:43 2014 us=187279 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:48:58 2014 us=194144 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:49:13 2014 us=200808 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:49:28 2014 us=207696 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:49:43 2014 us=214285 TCP: connect to [AF_INET]46.165.208.69:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:49:58 2014 us=324336 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:50:13 2014 us=331644 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:50:28 2014 us=338435 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:50:43 2014 us=345400 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:50:58 2014 us=352222 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:51:13 2014 us=358797 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:51:28 2014 us=365770 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:51:43 2014 us=372660 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:51:58 2014 us=379478 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:52:13 2014 us=386776 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:52:28 2014 us=393727 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:52:43 2014 us=400711 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:52:58 2014 us=407936 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:53:13 2014 us=414633 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:53:28 2014 us=421954 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:53:43 2014 us=429152 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:53:58 2014 us=435121 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:54:13 2014 us=442062 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:54:28 2014 us=448558 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
Sun Oct 26 20:54:43 2014 us=455819 TCP: connect to [AF_INET]178.162.198.103:80 failed, will try again in 5 seconds: Connection timed out
The service could not connect to the different kind of vpn servers.
Mike
