imno007
No Traffic When Using VPN
That's it in a nutshell, and just started today. I can connect/authenticate (although I notice it does take a while), but afterward there is no data getting through, in or out. Tried several servers, same problem with all of them. As soon as I disconnect, things return to normal. Any known problems with the service, or is it something on my end?
EDIT: Okay, nevermind, the problem seems to be with Google dns. After changing the dns and rebooting, problem seems to be solved.
