rkp
Problems Eddie 2.4
I have two problems dealing with Eddie 2.4:
1. When shutting down Windows 8.1, the process is stopped because Windows is not able to shut down AirVPN. Maybe this is a result of the question "Do you really want to exit" when closing AirVPN. This problem did not exist in 2.3.
2. Minimizing in tray still does not work!
Where can I find Eddie 2.3 to go back?  As mentioned, with 2.4 it is not possible to close Windows.
Many thanks
Ya I have the same thing on my OS 7 64 ,, I dont worry about it at all the pc will shut down and thats that ,, nothing els will harm ur pc
there is how ever one small problem , if u start to play around with ur ports Like I did the other day, ur pc will restart or blue screen
99% that was me closing the wrong port ,, the next day while i had my file sharing port open , I was downloading and uploading and I decided to un hook my cat 6 cable while every thing was running and I got the blue screen again ,,,, So if u dont do what I did and leave every thing as is ,, U will be good to go
hop this helps
It is... There will be a fix for this in the upcoming Version 2.5, "[new] Option for exit confirmation", found in the upcoming changelog here: https://airvpn.org/services/changelog.php?software=client&format=html
You will be able to uncheck that option and then Windows will exit without hanging.
HTH...
