Not connected, Your IP: 216.73.216.14
retiredpilot
Accessing Air while using a linux live disk
Looking for a suggestion or two.  I am in a situation (at times) where I need to mount a live Ubuntu disk in RAM only for security reasons.  Once linux is mounted it would be nice to connect to Air during my surfing session.  Using 14.04 live, how would it be possible to use my Air account?  The live media doesn't have Air in the build so I would be willing to download the small client each time or have pre-saved configurations to use from a flash.
I seem to remember dependency issues before and I am getting ready to start the process of learning this over again.  Is this doable, or will I need to create a custom live disk?
I normally just sudo apt-get install network-manager-openvpn-gnome and allow all dependencies to be installed. It's only a small download, and you can then sudo cp the usual ovpn and key files to /etc/openvpn and you're away.
