Not connected, Your IP: 216.73.216.195
[SOLVED]Port forwarding / Iptables / Tomato
Dear all,
I have some troubles to make the port forwarding working. Here is my setup:
[FAI BOX]----->[TOMATO ROUTER]---->[LOCAL WEB SERVER, and several PCs]
The FAI BOX is forwarding the 443 port to the tomato router.
This router is connecting to airvpn. The connection works perfectly (WAN IP and web surfing are OK).
I am using the following iptables rules (Administration/Scripts/Firewall) in order to forward wan request coming on tomato router through port 80 to the local web server:
iptables -I FORWARD -i br0 -o tun12 -j ACCEPT
iptables -I FORWARD -i tun12 -o br0 -j ACCEPT
iptables -I INPUT -i tun12 -j REJECT
iptables -t nat -A POSTROUTING -o tun12 -j MASQUERADE
iptables -t nat -I WANPREROUTING -p tcp --dport 80 -j DNAT --to WEBSERVERIP:80
iptables -I FORWARD -p tcp -d WEBSERVERIP --dport 80 -j ACCEPT
On my cellphone (not connected to my lan) i am trying to connect to my webserver using:
http://WAN_IP:PORT
I have configured on AIRVPN web site a port forwarding: PORT-> 80 (TCP & UDP).
While I can access to my webserver from inside my LAN, I cannot from WAN.
Any suggestion would be welcomed
EDIT:
I solved my issue by switching to ASUS MERLIN WRT following this thread.
I don't know this counts are a resolution, the solution is to change platforms... Mod - can you remove the original post?
Its indexed and not helpful to the solution.
