Not connected, Your IP: 216.73.216.33
Dezorian
DNS-Leak, Showing 2 locations -SOLVED-
Greetings fellow VPN-users,
I have checked this forum for similar problems, but haven't found a solution to my particular problem.
I use Windows 8.1 64 bit.
I test-registered with a 3 days-account, connected to a netherland-server, checked www.ipleak.net (my ip is well hidden), and www.dnsleaktest.com, where
I am presented with 2 servers found on "Standard Test".
One is the fake-netherland one and the second is my own ISP with its server, country, ip. that is being displayed.
When going for an "Extended Test" again there are 2 servers found, first in line is my own ISP and server and then the fake netherland one.
Is my internet connection safe or is there an actual leakage going on?
Thanks for any clarification or solution to this. (:
PS: SOLVED, followed the instructions on www.dnsleaktest.com, thanks for the help! (:
