Not connected, Your IP: 216.73.216.33
gr498
AirVPN on Raspberry-Pi OR AirVPN & TOR on Raspberry Pi
I was wondering that how can i setup AirVPN on Raspberry Pi, a cheap Single Board Computer at ~40$ or less
it features a nice processor at 700MHz (which you will get in expensive routers)
512Mb RAM
Runs Linux
A VGA Card with HDMI and Component Out
Two USB Ports
1 Ethernet Port
You can use it as a Firewall, or Wireless Access Point
What i was wondering that how can i securely setup AirVPN on Raspberry Pi
i have some tutorials on seting up OpenVPN on raspberry Pi but not AirVPN specific(I am low to mid level tch guy)
here are some pages i have found out
http://www.raspberrypi.org/forums/viewtopic.php?t=20916
http://lifehacker.com/5978098/turn-a-raspberry-pi-into-a-personal-vpn-for-secure-browsing-anywhere-you-go
http://readwrite.com/2014/04/10/raspberry-pi-vpn-tutorial-server-secure-web-browsing
http://readwrite.com/2014/04/11/building-a-raspberry-pi-vpn-part-two-creating-an-encrypted-client-side#awesm=~oET3yhEaIvwinz
The second option which i was thinking about was a Raspberry Pi runing TOR over AirVPN and then use this "Pi" as wireless access point
I have found tutorials on how to make a TOR Router using Raspberry here
http://spectrum.ieee.org/geek-life/hands-on/a-diy-tor-wifi-access-point
http://makezine.com/projects/make-36-boards/how-to-bake-an-onion-pi/
www.instructables.com/id/Raspberry-Pi-Tor-relay/
So i need guidance on two things
1- How to setup AirVPN on Raspberry Pi ?
2- Once i have installed Tor on the NOOB Raspberry OS, how do i router all TOR Trafic through AirVPN ?
I think this will make a very secure Hardware solution for all the security paranoid here while still being cheap.
Thanks to the Great AirVPN Team and the Great Guys Helping here
Ok, i have researched on the Topic More.
It seems there is another SBC (Single Board Computer) more powerful than Raspberry-Pi
and it is "BeagleBone Black"
http://beagleboard.org/Products/BeagleBone+Black
It has got a more powerful CPU at 1GHz
Hardware Crypto Acceleration
http://datko.net/2013/10/03/howto_crypto_beaglebone_black/
Here are OpenVPN speed test
http://datko.net/2013/11/27/bbb_openvpn/
Also see
http://prig.ch/prig-blogs/linux-applications/virtual-private-network/index.php
I prefer BeagleBone Black because it has a more powerful CPU and Hardware Crypto Acceleration which means
it will push more OpenVPN traffic than Raspberry Pi
