I know this is an old thread, so I apologize for Necroposting.
Make sure you do *NOT* ever use the OpenDNS servers in DNSCrypt. They do in fact log. They even admit this.
And remember that if anyone running a site can see that your IP is an AirVPN IP, then if you are doing lookups that do not match those of other AirVPN users, you have just given them a way to single you out a bit.
(This would require a trap site, but many do in fact exist today. Be very careful.)
Isn't there a way that AirVPN can implement DNS encryption, or is it done by default when connection is established.
When you are connected to a server, all your traffic, including the DNS one, is encrypted.
When you use Air's DNS servers, you also benefit from the fact that there are no logs.
this and and i had DNScrypt one time on my pc and it used between 5-25% of Cpu sometimes pretty overkill specially if you want to game on that machine.
( i5 Processor so nothing old. )
