bobomatic
Am I connected?
I had a recent system crash and had to reinstall the airvpn client. I am able to login and connect but when I check the bottom on the airvpn webpage, it's says I'm not connected and shows my actual IP address.... even though airvpn client says I'm connected with errors. I click the referenced URL but it doesn't take me to anything that will point me in the direction to resolve. Can you help? Below are the logs:
4/6/2014 - 10:19 PM   AirVPN client version: 1.9
4/6/2014 - 10:19 PM   Reading options from C:\Users\Robert\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
4/6/2014 - 10:19 PM   OpenVPN bundle version: OpenVPN 2.3.2
4/6/2014 - 10:19 PM   OpenVPN current version: OpenVPN 2.3.0
4/6/2014 - 10:19 PM   Ready.
4/6/2014 - 10:19 PM   Login...
4/6/2014 - 10:19 PM   Login success.
4/6/2014 - 10:19 PM   Contacting service...
4/6/2014 - 10:19 PM   Connecting...
4/6/2014 - 10:19 PM   OpenVPN 2.3.0 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan  8 2013
4/6/2014 - 10:19 PM   NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
4/6/2014 - 10:19 PM   Socket Buffers: R=[8192->8192] S=[8192->8192]
4/6/2014 - 10:19 PM   UDPv4 link local: [undef]
4/6/2014 - 10:19 PM   UDPv4 link remote: [AF_INET]108.59.11.194:443
4/6/2014 - 10:19 PM   TLS: Initial packet from [AF_INET]108.59.11.194:443, sid=fe6074d2 77bdac59
4/6/2014 - 10:19 PM   VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
4/6/2014 - 10:19 PM   VERIFY OK: nsCertType=SERVER
4/6/2014 - 10:19 PM   VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
4/6/2014 - 10:19 PM   Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
4/6/2014 - 10:19 PM   Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
4/6/2014 - 10:19 PM   Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
4/6/2014 - 10:19 PM   Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
4/6/2014 - 10:19 PM   Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
4/6/2014 - 10:19 PM   [server] Peer Connection Initiated with [AF_INET]108.59.11.194:443
4/6/2014 - 10:19 PM   SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
4/6/2014 - 10:19 PM   PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.112.34 10.4.112.33'
4/6/2014 - 10:19 PM   OPTIONS IMPORT: timers and/or timeouts modified
4/6/2014 - 10:19 PM   OPTIONS IMPORT: LZO parms modified
4/6/2014 - 10:19 PM   OPTIONS IMPORT: --ifconfig/up options modified
4/6/2014 - 10:19 PM   OPTIONS IMPORT: route options modified
4/6/2014 - 10:19 PM   OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
4/6/2014 - 10:19 PM   do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
4/6/2014 - 10:19 PM   open_tun, tt->ipv6=0
4/6/2014 - 10:19 PM   TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{E7FAF9DC-40FE-42C7-8E04-82AC60C0E4FB}.tap
4/6/2014 - 10:19 PM   TAP-Windows Driver Version 9.9
4/6/2014 - 10:19 PM   Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.112.34/255.255.255.252 on interface {E7FAF9DC-40FE-42C7-8E04-82AC60C0E4FB} [DHCP-serv: 10.4.112.33, lease-time: 31536000]
4/6/2014 - 10:19 PM   NOTE: FlushIpNetTable failed on interface [25] {E7FAF9DC-40FE-42C7-8E04-82AC60C0E4FB} (status=1168) : Element not found.
4/6/2014 - 10:19 PM   TEST ROUTES: 0/2 succeeded len=1 ret=0 a=0 u/d=up
4/6/2014 - 10:19 PM   Route: Waiting for TUN/TAP interface to come up...
4/6/2014 - 10:20 PM   TEST ROUTES: 0/2 succeeded len=1 ret=0 a=0 u/d=up
4/6/2014 - 10:20 PM   Route: Waiting for TUN/TAP interface to come up...
4/6/2014 - 10:20 PM   C:\Windows\system32\route.exe ADD 108.59.11.194 MASK 255.255.255.255 192.168.1.1
4/6/2014 - 10:20 PM   ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
4/6/2014 - 10:20 PM   Route addition via IPAPI succeeded [adaptive]
4/6/2014 - 10:20 PM   C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.112.33
4/6/2014 - 10:20 PM   Warning: route gateway is not reachable on any active network adapters: 10.4.112.33
4/6/2014 - 10:20 PM   Route addition via IPAPI failed [adaptive]
4/6/2014 - 10:20 PM   Route addition fallback to route.exe
4/6/2014 - 10:20 PM   env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
4/6/2014 - 10:20 PM   OK!
4/6/2014 - 10:20 PM   C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.112.33
4/6/2014 - 10:20 PM   C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.112.33
4/6/2014 - 10:20 PM   SYSTEM ROUTING TABLE
4/6/2014 - 10:20 PM   .1 p=0 i=10 t=4 pr=3 a=1187 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   2.33 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
4/6/2014 - 10:20 PM   10.4.112.33 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
4/6/2014 - 10:20 PM   .255 192.168.1.1 p=0 i=10 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
4/6/2014 - 10:20 PM   .0.1 p=0 i=1 t=3 pr=3 a=1942 h=0 m=306/0/0/0/0
4/6/2014 - 10:20 PM   127.0.0.1 p=0 i=1 t=3 pr=3 a=1942 h=0 m=306/0/0/0/0
4/6/2014 - 10:20 PM   55.255 127.0.0.1 p=0 i=1 t=3 pr=3 a=1942 h=0 m=306/0/0/0/0
4/6/2014 - 10:20 PM   112.33 p=0 i=10 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
4/6/2014 - 10:20 PM   192.168.1.18 p=0 i=10 t=3 pr=3 a=1183 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   255 192.168.1.18 p=0 i=10 t=3 pr=3 a=1183 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   .255 192.168.1.18 p=0 i=10 t=3 pr=3 a=1183 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   68.1.18 p=0 i=10 t=3 pr=3 a=1927 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   55.255 192.168.1.18 p=0 i=10 t=3 pr=3 a=1927 h=0 m=276/0/0/0/0
4/6/2014 - 10:20 PM   SYSTEM ADAPTER LIST
4/6/2014 - 10:20 PM   Ethernet
4/6/2014 - 10:20 PM     Index = 10
4/6/2014 - 10:20 PM   4D3-B348-DB9594E7CDEB}
4/6/2014 - 10:20 PM   55.255.0
4/6/2014 - 10:20 PM     MAC = 00:25:11:8e:e2:97
4/6/2014 - 10:20 PM   55.255.255.255
4/6/2014 - 10:20 PM   255.255.255 8.8.4.4/255.255.255.255
4/6/2014 - 10:20 PM   Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
4/6/2014 - 10:20 PM   Starting Management Interface...
4/6/2014 - 10:20 PM   Checking...
4/6/2014 - 10:20 PM   Retrieve statistics...
4/6/2014 - 10:20 PM   Connected.
Wouldn't you know... I figured it out about 5 minutes after opening the this ticket. Thanks anyway.... resetting one of the options on the TAP adapter resolved it. Thanks anyway.
