Not connected, Your IP: 3.143.168.172
xer
ANSWERED OpenVPN not connecting with my config?
Mon Sep 16 23:06:33 2013 Warning: cannot open --log file: C:\Program Files\OpenVPN\log\AirVPN_Singapore_TCP-443.log: Access is denied.   (errno=5)
Mon Sep 16 23:06:33 2013 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013
Mon Sep 16 23:06:33 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Mon Sep 16 23:06:33 2013 Need hold release from management interface, waiting...
Mon Sep 16 23:06:33 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Mon Sep 16 23:06:33 2013 MANAGEMENT: CMD 'state on'
Mon Sep 16 23:06:33 2013 MANAGEMENT: CMD 'log all on'
Mon Sep 16 23:06:33 2013 MANAGEMENT: CMD 'hold off'
Mon Sep 16 23:06:33 2013 MANAGEMENT: CMD 'hold release'
Mon Sep 16 23:06:33 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Sep 16 23:06:33 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9150
Mon Sep 16 23:06:33 2013 MANAGEMENT: >STATE:1379369193,TCP_CONNECT,,,
Mon Sep 16 23:06:34 2013 TCP: connect to [AF_INET]127.0.0.1:9150 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Sep 16 23:06:39 2013 MANAGEMENT: >STATE:1379369199,TCP_CONNECT,,,
Mon Sep 16 23:06:40 2013 TCP: connect to [AF_INET]127.0.0.1:9150 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Mon Sep 16 23:06:45 2013 MANAGEMENT: >STATE:1379369205,TCP_CONNECT,,,
Mon Sep 16 23:06:46 2013 TCP: connect to [AF_INET]127.0.0.1:9150 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED)
Why is this not working?
Apparently your local proxy is not running or not listening to port 9150, can you please check? Can you tell us which proxy are you running, is it a TOR proxy?
EDIT: I disconnected then reconnected and now it works just fine
Ok. Please remember that you need to run OpenVPN GUI with administrator privileges. From the piece of log you sent us, OpenVPN had "access denied" to interfaces.
