Errico 0 Posted ... Hi,I added forwarded ports for ssh connection, http too (and for p2p). And only the port for the p2p client seems to work (local and extern port are the same).When I type : ssh -p xxxxx xx.xx.xx.xx (the external ip right, not the ip what I have ?), I have a connection timed out.Protocol: TCP&UDPLocal Port: 22DDNS: / It seems to be the same problem for the http's forwarded ports.Protocol: TCPLocal Port: 80DDNS: alias May be I use the wrong ip, but both are not working. Thanks in advance. Quote Share this post Link to post
Staff 9691 Posted ... @Errico Hello, exit-IP, correct. Kind regards Quote Share this post Link to post
Errico 0 Posted ... Right. I use the exit-ip. But why I can't connect with ssh. What I have to do? And so on for the others services.It's not because I'm using the VPN and testing the port with the VPN IP?Thanks. Quote Share this post Link to post
verax 0 Posted ... Hello, I'd like to work with a current user who is all setup with Ubuntu Linux and successfully connecting to servers in Asia. I have been experiencing issues establishing a connections that could be an SSH forwarding issue, but I'm not for sure. Would like to walk through step-by-step and figure out what the problem is. I've got all the current output from many failed attempts and may generate new config files and see if that makes any difference. It would be great to identify this connection issue, so I can use this VPN service that I think is exactly what I'm looking for in a service provider. Quote Share this post Link to post
////////////////////////// 3 Posted ... If you believe you are having a port forwarding issue you should probably read the thread dedicated to this issue: https://airvpn.org/topic/9315-port-forwarding-tester/ Quote Share this post Link to post
